Old 03-09-2010, 04:17 AM   #1
07evok1lr
Member#: 230695
2007 STI
Default Dyno Tune: 2.5L + HTA3582 + Topspeed (Doug) makes 605whp
Event: dyno pull
Ambient Temp: 42 I believe
Elevation: 1300
Weather: Gray and Chilly
Tires: Star Specs, 235/45/17
Car: 2007 STI
Tuner: Doug from Topspeed FTW!!!!!!!!!
Dyno Info: Dynojet
Peak HP at RPM: 604 (597 uncorrected with 93/meth) and 503(497 uncorrected on 93)
Peak Torque at RPM: 534 and 425
Baseline hp/tq for a stock on same dyno: 238/262- 07 STI- Stg 1 I believe
Target Boost: 28.5 and 21PSI respectively
Target AFR: 11.2
Fuel: 93 unleaded and 100% methanol / and just 93
Engine/Power Modifications: HTA gt3582R Turbo with .82 hotside, V-band Turbo kit, Perrin Fmic, 1000cc Dw's, AEM Standalone, Gsc Stg 2 Cams, Topspeed Head Porting (custom porting Topspeed does designed around gsc cams)
07evok1lr is offline   Reply With Quote
Old 03-09-2010, 10:38 AM   #2
kheff46
Member#: 66739
2002 WRX wagon
seeing these #'s makes me wanna give up my JDm STi and get some 2.5L USDM action!
great numbers! any video/pics?
--keith
kheff46 is offline   Reply With Quote
Old 03-09-2010, 11:07 AM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
wow nice! it spools faster than Coolrex's 35r with a .63AR WTF
Old 03-09-2010, 11:17 AM   #4
07evok1lr
Member#: 230695
2007 STI
I donno- Hta, v-band, meth......
got a few vids and lots of pics I can post later after work, same username on IWSTI as well with a fairly complete Journal too
Old 03-09-2010, 11:29 AM   #5
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
Originally Posted by kheff46 View Post
great numbers!
x2
these numbers are great. I've had big hopes for this turbo. looks like you have a tuner who knows what hes doing.
WREX88 is offline   Reply With Quote
Old 03-09-2010, 11:30 AM   #6
juanmedina
Member#: 133146
It is actually a very similar setup minus the cams of and porting, which will actually hurts spool but increase top end.
35R, V-band, meth, and same tuner
http://forums.nasioc.com/forums/show...hlight=coolrex
Your car is sick
Old 03-09-2010, 03:26 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
500whp on 93oct = very nice!!
jays05 is offline   Reply With Quote
Old 03-09-2010, 03:30 PM   #8
07evok1lr
Member#: 230695
2007 STI
Taught by the best
Old 03-10-2010, 01:43 AM   #9
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I assume meth really helps that much. Damn, I was always against doing it on my setup but if it has such great results I may just go for it.
D Money is offline   Reply With Quote
Old 03-10-2010, 01:44 AM   #10
07evok1lr
Member#: 230695
2007 STI
guys notice how much power it kept making even past 7300?
Old 03-10-2010, 02:06 AM   #11
tplumsti
Member#: 144791
2004 Forester XT
meth made a 100 hp difference?
tplumsti is offline   Reply With Quote
Old 03-10-2010, 02:19 AM   #12
07evok1lr
Member#: 230695
2007 STI
yes and no....you guys know how meth works and how you can make power with it right??
the 93 tune is at 21 psi to be safe and conservative only using pump gas, using 100 perc meth (and a lot of it- twin nozzles) It was possible to advance the timing somewhat and increase boost to 28 psi which is what netted 100 hp
just adding meth without tuning for it will actually decrease power most likely, and we could have easily run the 93 tune at 23 psi and the meth tune at 26psi and only had 40 hp difference so don't everybody think meth is the answer to everything, PLUS it is a highly modified car with a large turbo so the increased boost/timing will have a larger effect as opposed to the same changes with say a stock turbo
Old 03-10-2010, 02:58 AM   #13
aussiecrum
Member#: 217191
2002 WRX sedan
thanks for the meth info (sounds bad out of context)
any pics of the system?
aussiecrum is offline   Reply With Quote
Old 03-10-2010, 03:08 AM   #14
07evok1lr
Member#: 230695
2007 STI
yea I have been too lazy especially since I don't have any completely up to date pics of the whole engine bay but here is a link to my journal on IWSTI with tons of photos, some old some real old some newer etc etc
AND a couple vids in there too
http://www.iwsti.com/forums/gd-membe...speed-ftw.html
Old 03-10-2010, 11:05 AM   #15
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
So essentially you think if you ran this car on pump gas around 23-24psi, you would have made what power? The meth tune increased so much because your pump gas tune was soo conservative?
What motor are you running?
Old 03-10-2010, 02:50 PM   #16
TopSpeed
Member#: 78884
Go faster
at TopSpeed
AVCS FTW
Doug
TopSpeed is offline   Reply With Quote
Old 03-10-2010, 03:35 PM   #17
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Originally Posted by TopSpeed View Post
AVCS FTW
Doug
hell yaaa!
This thing must come on fast on the street.
BUILTSTI is offline   Reply With Quote
Old 03-10-2010, 04:59 PM   #18
kheff46
Member#: 66739
2002 WRX wagon
Talking
meth... good for cars bad for teeth!
--keith
Old 03-10-2010, 05:02 PM   #19
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
So is this thing going to see the dragstrip or road course,if drag would like to see some good et's to back up the power.Nice car and sweet graphs.good job Doug.
john 1badSTI is offline   Reply With Quote
Old 03-10-2010, 07:29 PM   #20
NIGO
Member#: 184267
NICE!!!
Very noob question but, wat can be done for to allow subarus to carry power to and beyond 8000 rpm.
NIGO is offline   Reply With Quote
Old 03-11-2010, 01:48 AM   #21
07evok1lr
Member#: 230695
2007 STI
sure is sometime soon, I already P-boxed it which is very accurate and it trapped 130.xx just sliding it into 1st, so with the LC setup it should pick up another couple mph- best 1/4 was 11.2 but again I had a 2.2 60ft on that run lol without launching it
Old 03-11-2010, 01:49 AM   #22
07evok1lr
Member#: 230695
2007 STI
Originally Posted by NIGO View Post
NICE!!!
drysump oiling system-
Old 03-11-2010, 01:53 AM   #23
07evok1lr
Member#: 230695
2007 STI
I'm saying the 93 tune might have been able to be pushed a little farther and we easily could have done the meth tune to 25 or 26 psi but with the fully built longblock and amount of meth it would have been silly to stop there
also that the effects are increased when put on with a large 35r turbo and such great flowing heads etc etc
I had meth on stg2 and it inc 9whp, and w/ a dom3 and netted around 50 whp fwiw
Old 03-11-2010, 04:46 AM   #24
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Great comparison of two boost settings and two outcomes! Very informative and GREAT results. Tnx!
Is there maybe a boost versus rpm graph somewhere? That would be great.
How much lbs/min does the HTA 3582R compressor wheel flow? (could not find that info on FP's website..)
TIA,
Walter
Beetspeed is offline   Reply With Quote
Old 03-11-2010, 06:38 AM   #25
07evok1lr
Member#: 230695
2007 STI
TIA,
Walter
no boost/rpm graph, well sort of, logging boost and engine speed in 4th gear showed I floored it at 3600 rpm and got 27 psi at 41xx rpm so full boost comes on anywhere between 5-700 rpms before peak tq
no idea on the turbo, either equal to or only a couple lb/min more than a standard 35r is my guess
Dyno Tune: 2.5L, GT35R, E85-Tuned STI Makes 540whp! Cobb Tuning Proven Power Bragging 45 04-25-2013 05:42 AM
Dyno Tune: 2.5L '09 WRX Completely stock, makes 263whp. <-- dyno reading incorrectly Breezio Proven Power Bragging 114 10-12-2010 10:00 PM
Dyno Tune: 2.5L + Blouch EvoIII 16G makes 354whp jonpark Proven Power Bragging 8 05-31-2010 11:02 PM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-09-2009 12:18 AM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 09:32 AM
