Old 05-30-2002, 03:26 PM   #1
all4wheels
Member#: 4932
2002 Silver wRXagon
Default Help! Stripped a wheel stud. How hard is it to replace?
So, to make a long story short, the store that mounted my snows last fall cross threaded one of the studs. When I put my summer wheels on, I noticed that nut was hard to remove, relative to the others, but didn't think anything of it until I was unable to reinstall the nut. In trying to do so, I stripped the stud pretty good. I have maybe a three eighths of an inch of good threads left at the base of the stud.
Can I have a new stud pressed in? Should I file off the messed up threads and try to catch the good ones with a new nut?
What should I do? Any ideas considered.
TIA
all4wheels
all4wheels is offline   Reply With Quote
Old 05-30-2002, 03:32 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default Re: Help! Stripped a wheel stud. How hard is it to replace?
TIA
all4wheels
You should replace that stripped stud. At least we've got a 5-bolt setup so I'd put a wheel back on it, tighten down the 4 good lugnuts, and then take it to a wheel shop/dealership/mechanic etc to get the stripped stud replaced.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 05-30-2002, 03:48 PM   #3
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
The studs aren't that hard to replace. On the GC8 cars you had to remove the ABS sensor ring. Then you have to hammer the bad stud out the back side of the hub. To get the new one in you can either use an impact wrench, or muscle it by hand with a long handled socket. The studs have splines on them so that they don't spin inside of their mounting hole. You can use your regular lug nuts to help pull it up tight but you will have to stack a handfull of washers on the stud so that you don't bottom out the nut (since it's got the cute little chrome cap on the end).
I changed one of mine the morning of an autocross, and it probably didn't take me more than 30 minutes. But having an impact wrench probably made a big difference there. Overall it's pretty easy though.
Good luck
Travis R is offline   Reply With Quote
Old 05-31-2002, 07:59 AM   #4
all4wheels
Member#: 4932
2002 Silver wRXagon
Default thanks
thanks for the help! If I can find a local dealership that has a stud in stock, I'll fix it this weekend.
all4wheels
Old 05-31-2002, 09:30 AM   #5
Ethan
Member#: 246
Or Tire shops can do it too (i.e Schucks, Les Scwhab)
Ethan is offline   Reply With Quote
How hard is it to replace the speed sensor? ski mobile Transmission (AT/MT) & Driveline 1 08-01-2004 02:41 PM
How hard is it to replace front WRX bumper? Sandkicker Interior & Exterior Modification 2 03-15-2003 04:07 PM
how hard is it to replace a driveshaft? nqwan Brakes, Steering & Suspension 1 11-15-2002 08:09 PM
How hard is it to replace steering rack bushing? Keiho Brakes, Steering & Suspension 4 07-10-2002 05:01 PM
('93-'01) How hard is it to replace a front axle? plurbe Impreza Forum 10 11-05-2001 11:28 PM
