Old 03-09-2010, 12:13 PM   #1
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Default Changing Timing Belt etc. What about Oil Pump?
Hi Everyone,
Doing the timing belt maintenance including all the other things usually replaced in preventative maintenance.
Is it easy or worth it to put in an 11mm oil pump at this point? I'm at 100k and no problems oil related.
The only reason I am considering it is for future builds and setup.
Many Thanks,
notjustforshow is online now   Reply With Quote
Old 03-09-2010, 02:07 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You don't need that oil pump and you don't need to change it during that maintenance action. Going with a bigger pump is when you build a motor only.
Old 03-09-2010, 02:50 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Don't need the pump, but it would be a good idea to change out your oil pickup
Old 03-09-2010, 02:58 PM   #4
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Thanks guys, wow the big guns replied.
much appreciated
Old 03-09-2010, 07:35 PM   #5
98outbacksprt
Member#: 130263
2006 WRX Stage 2
wrb
im sure ur already thinking this but a water pump and idlers arent a bad idea too..sorry if that was too obvious
98outbacksprt is offline   Reply With Quote
Old 03-09-2010, 07:49 PM   #6
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
nothing is too obvious !
but yes those are on the list.
It's a sad time to hit 100k, kind of feels like the car isn't new anymore
Old 03-10-2010, 09:59 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
If it were me, since you're right there, I'd check the tip, side, and case clearances to make sure they are still within the service wear limits. Not a bad idea to check the free length on the pressure relief spring too.
If/when you build the motor, that is when you should consider another pump.
KillerBMotorsport is offline   Reply With Quote
Old 03-10-2010, 03:02 PM   #8
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Thanks KillerB
I'm going to ask my local trusty mechanic at this point to work on this. I have the manuals and guides but a mistake will prove costly
Old 03-10-2010, 04:24 PM   #9
04BlkREX
Member#: 240800
04 WRX
I did mine recently too, nor did i have any previous problems with it so i didnt change it and nothing has gone wrong so far. Haven't heard of anything going wrong with the oil cooler anyway.
04BlkREX is offline   Reply With Quote
finally got a setup..now what about oil pump... jonnies Built Motor Discussion 3 05-04-2009 06:09 PM
Just changed timing belt, water pump, thermostat...overheating now efiniluvr Service & Maintenance 2 01-17-2009 11:18 PM
Time for changing timing belt??? Elminster Service & Maintenance 3 09-06-2008 06:58 PM
What shop around NYC for changing timing belt, water pump and tune-up? nycsubaruwrx Tri-State Area Forum 12 10-11-2007 09:02 PM
Changing Timing belt & other belts at 95K Outback Help! Mad Aaron Normally Aspirated Powertrain 4 03-01-2007 04:24 PM
Message Board Statistics All times are GMT -4. The time now is 05:46 PM.
