Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 03-09-2010, 04:34 PM   #1
ForcedInductionPhool
Member#: 217930
2004 STI
Default Overboosting Stage1?
To start my car is a 04 STi
I just put the Cobb Stage1 93 octane map on my car as the base map and I have noticed that if I am in third or fourth at around 3000-4000RPM and floor it, it will spike to around 18psi. Dont get me wrong it pulls nice at 18psi but should I be worried about this? In the map notes it states that a target boost of 16.5psi should be achived +/- 0.5psi. So I am assuming that something needs to be changed to lower the boost by 1psi.
1st and 2nd I get a strong 15-16psi.
Mods are, completely stock with a APV1 Stage 1 tune.
I am also throwing the ever soo popular P0457 code with my car (this has been going on for a long time and have not found a cure for it yet)
I plan on putting a non catted TBE this weekend and flashing the stage2 tune. But if I am having problems with the stage1 tune I will try to fix this first.
Thanks,
ForcedInductionPhool is offline   Reply With Quote
Old 03-09-2010, 06:07 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I wouldn't worry too much about it, 1 Psi is not that much over. JMO
wrxdrvr is offline   Reply With Quote
Old 03-09-2010, 06:44 PM   #3
Member#: 217930
2004 STI
Ok thanks, I ended up doing some testing today with the cobb tuner set to read boost in real time and it showed that I was hitting no higher than around 17.3psi. So I guess my gauge is off by a tad.
Just a little over cautious I guess.
Thanks,
SOCAL BNIB Exedy stage1 Clutch 15804 06-10wrx $350 shipped Wannascooby Drivetrain 20 08-28-2010 08:15 PM
Stage1 93 vs. Stage1 93 MT ?? MarkRx AccessPort 8 02-08-2007 05:05 PM
AT drivers waiting for TurboXS stage1 enphorcerWRX Factory 2.0L Turbo Powertrain 4 10-18-2001 12:29 PM
APS stage1 gtech-pro results jmott Factory 2.0L Turbo Powertrain 11 09-24-2001 05:56 PM
Feedback from COBB Stage1 owners? H8YNERS Factory 2.0L Turbo Powertrain 4 09-06-2001 06:35 PM
Message Board Statistics All times are GMT -4. The time now is 01:07 AM.
