Old 03-09-2010, 07:01 PM   #1
pasths
Member#: 113878
2004 STi
Default Need Help ASAP
Hi ALL,
My downpipe is in and ready to flash stage II. I am already stage I. Do I go throught the process I went through to get to Stage 1?
Key off
green connectors then turn on AP?
I'm basically doing map changing and the directions state I need to be in ECU programming mode which I'm guessing is the green connectors and the key in the "on" position?
Thanks!
pasths is offline   Reply With Quote
Old 03-09-2010, 07:11 PM   #2
Cobb Tuning
Member#: 4803
If you want to flash a new basemap on then yes, you have to go through the reflash process like you did to install the AccessPORT initially. However, you can flash a map on as realtime and it will work just as well. However, if you reset your ECU or lose power etc, the map will revert back to whatever the basemap is.
Travis
COBB Tuning
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
!!help help ! i need help ASAP yuboyus Mid West Subaru Owners Club Forum -- MWSOC 3 10-17-2006 03:16 PM
$1500 to build a friends computer... only newegg need help asap needs built by mon 2k2 Off-Topic 15 10-06-2004 11:26 AM
need help asap. i need a really good subaru dealership to work on my car. need info! bubba03wrx Southern California Impreza Club Forum -- SCIC 12 02-25-2004 03:31 AM
('93-'01) Help! I Screwed Up My Door? Need Help ASAP ejicon Impreza Forum 7 04-27-2001 12:03 AM
