Old 03-09-2010, 10:14 PM   #1
lordizzy626
Member#: 234611
2006 WRX
Default Would A Missing Nut On The Up Pipe To Turbo Cause Issue
So my car was running strong after getting tuned by Keith Fields. It ran good for about a week or two until I started noticing a loss in power and the ECU had learned to pull about 10% fuel. Well, to notice, I look at all my exhaust gaskets and notice that I am missing a nut on my up pipe to turbo.. Out of three, I am missing one. LOL.. Would this cause a problem like causing the car to run crappy and make the ecu pull fuel? Also, I think I have a DP to midpipe leak as well as a dp to turbo leak. I'm replacing all the gaskets in the car over spring break and re-setting the ECU to see how it runs.... So my question is, would the missing nut cause that issue?
lordizzy626 is offline   Reply With Quote
Old 03-09-2010, 11:54 PM   #2
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
Yes I had the same problem when I got tuned my car ran really lean because of the uppipe leak. Fix that leak and def the turbo to dp leak also. As for the dp to midpipe leak I have alittle leak there as well but it will not affect performance at all it will just sound like crap.
under0athh51189 is offline   Reply With Quote
Old 03-10-2010, 01:23 AM   #3
constantino7491
Member#: 187358
08 BMW 328
anything after the turbo will not affect performance (for the most part, take this with a grain of salt)
on the other hand pre turbo exhaust leak = tune being completely off, exhaust gasses are not pushing the turbo as they should be.
constantino7491 is offline   Reply With Quote
Old 03-10-2010, 01:58 AM   #4
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
Yes, thread a nut on there asap.
575rider is offline   Reply With Quote
Old 03-10-2010, 09:59 AM   #5
lordizzy626
Member#: 234611
2006 WRX
Well the problem is that is is the nut on the backside of the turbo. I'll have to remove the DP to get to where i need to be and I don't have any extra gaskets. I'm ordering some from Josh at import image today. Be taking on this project soon. It'll most likely require a re tune though. UGH! More money. LOL... I'm helping to make Keith's house payment. LOL When it got tuned it ran like a champ for about a week. I guess it needed time for the gasket to blow... This sucks. The
Old 03-10-2010, 11:23 AM   #6
Twrxman
Member#: 211439
do this fast
Twrxman is offline   Reply With Quote
Old 03-10-2010, 11:26 AM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
And? Reuse the DP gasket. You don't have to replace an exhaust gasket everytime you take it off.
i_c_the_light is offline   Reply With Quote
Old 03-10-2010, 12:53 PM   #8
lordizzy626
Member#: 234611
2006 WRX
Well that makes it alot better.... I guess I was dealing with a lot of picky Subaru owners becuase from what everyone told me it is most likely a good idea to go ahead and use a new gasket every time you take one out... LOL.... So in light of this I'm actually going to go ahead and thread that other nut on there right now!
Old 03-10-2010, 12:55 PM   #9
Badler
Member#: 133597
If I am going through the hassle of taking it all apart I am not going to chance it with a $15 gasket.
Badler is online now   Reply With Quote
Old 03-10-2010, 01:45 PM   #10
lordizzy626
Member#: 234611
2006 WRX
Yeah... Well I put the other nut back on but I fear it is too late.. LOL..... I'm most likely going to have to replace the up-pipe turbo gasket. LOL. May as well replace the DP to turbo as well as DP to midpipe gasket too!
Old 03-10-2010, 02:34 PM   #11
adam_elkcip
Member#: 151329
2002 Wrx Wagon
AW
im missing one of the nuts from when i installed the uppipie i dropped one, havent had any problems yet
adam_elkcip is offline   Reply With Quote
Old 03-10-2010, 07:02 PM   #12
lordizzy626
Member#: 234611
2006 WRX
You are missint one of the nuts that secures your turbo to the up-pipe and haven't had a problem yet? Hmmmmmmmmm..... Interesting. LOL... Well it has definately caused me issues.... The gasket is pretty much gone. LOL... That particular area is probably the area of the exahust with the most pressure so it's hard to believe you haven't had a problem yet.
Old 03-10-2010, 09:04 PM   #13
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
If it's the OP's case where it's freshly put on there would be no problem reusing it. But it's been on for 3 years then it might be worth it. It really depends on the condition of the gasket when things are pulled off.
Old 03-10-2010, 09:48 PM   #14
boosted06
Member#: 144143
03 Wrx Wagon
i hate the sound of the exhaust leaks. can you hear anything coming out of it? i would replace it with a new one asap.
boosted06 is offline   Reply With Quote
Old 03-10-2010, 10:57 PM   #15
575rider
Member#: 112024
03 hybrid 6spd wgn
try to reach it from under the car, or pull the TMIC and go at it that way
Up pipe to Turbo flanges...whats the deal? arminyack Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-20-2010 10:52 AM
WTB: gaskets... Up pipe to turbo and manifold to uppipe Wookie768 NESIC Private Classifieds 2 06-09-2008 01:50 PM
anyone know the dimensions of the up pipe to turbo flange? philip_g Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-09-2007 10:26 PM
vf39 missing bolt on the down pipe? natoli4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2004 12:12 AM
up pipe to turbo studs ErikAnderson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-12-2003 04:18 AM
