Old 03-10-2010, 09:36 PM   #1
Rally Monkey
Member#: 36310
03 WRX Sedan
Default Fan on temperature adjustment
Can you adjust the temperature setting that turns the fans on with the Accessport?
Rally Monkey is offline   Reply With Quote
Old 03-10-2010, 10:31 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Not that I know of...
wrxdrvr is offline   Reply With Quote
Old 03-22-2010, 04:29 PM   #3
bikepoet
Member#: 201878
2008 STI
With AccessTuner Race, you can change the settings in the map and upload a new map.
Why would you want to change it though? Install a new thermostat?
bikepoet is offline   Reply With Quote
Old 03-28-2010, 10:00 PM   #4
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo
In Access tuner race, I think theres a table where you can tell it when to come on.
Ysidro is offline   Reply With Quote
Old 03-29-2010, 03:55 PM   #5
JF824
Member#: 71460
2007 WRX/STi
HTA Green 11.89 @ 119
If you download AccessTuner Race, in the folder "Miscellaneous Tables" you can view and change the temperatures that will turn on the radiator fans. However if you are pro-tuned you won't be able to do this as the map will be locked. You'll only be able to adjust the map if its a OTS map from Cobb, or a map that you created on AccessTuner Race.
JF824 is offline   Reply With Quote
Cooling Fans / Water Temperature Gauge / Who's reponsible for this mess? crystalhelix Electrical & Lighting 11 06-03-2011 05:57 PM
The effect on temperature to boost... sizzflair Newbies & FAQs 16 03-15-2006 05:00 PM
Any fans of fans on NASIOC? eurojax Off-Topic 50 06-08-2005 03:50 AM
Any Fans of Fans on NASIOC? binky Off-Topic 18 06-08-2005 03:46 AM
Fan turn on temp... adjustable? Hit Man X Factory 2.0L Turbo Powertrain 14 01-27-2004 09:08 PM
Message Board Statistics All times are GMT -4. The time now is 01:15 AM.
