Old 03-12-2010, 01:11 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ Tuning: 04 WRX, EQ Built Engine, ATP3076, 91 Octane - 352whp!
This is an 04 WRX that we built a while ago. The customer got the break-in done but we couldn't make any decent power on the setup. Upon further inspection, we found that his cat-back had a couple custom crush bent pieces that were causing a major restriction at anything over 300whp. The customer finally swapped it out to a MadDad whisper cat-back which really opened things up. This car is still on the stock 5 speed, so we kept boost and torque down a bit to try to keep the tranny alive until the customer can get the 6 speed in
Event: Custom Tune/Road Dyno
Ambient Temp: 58 degrees Fahrenheit
Elevation: ~180ft above sea level
Car: 2004 Subaru WRX Sedan
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 352whp @ 5820RPM
Peak Torque at RPM: 348ft-lbs @ 4700RPM
Target Boost: 19psi peak
Fuel: California 91 Octane
Engine/Power Modifications:
- EQ S1 Shortblock
- EQ S2 Heads w/ BC 272 cams
- SSAC FMIC w/ EQ Blow-Through MAF
- ATP Stock Location GT3076 (IWG)
- DW850cc Injectors
- Perrin Downpipe
- MadDad Cat-Back
- Walbro Fuel Pump
- Hallman Pro RX MBC
- EQ Tuning Custom Tune
Here's the chart:
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 122-123mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-12-2010, 10:36 PM   #2
subenerd
Member#: 72630
2004 STi
Awesome, I've been wanting to see how the iwg version of this turbo would perform. Powerband looks good, 300ftlbs before 4k rpms and the hp keeps going.
Ed, what is the power difference on these ATP between the iwg and ewg versions? 10, 15whp?
subenerd is offline   Reply With Quote
Old 03-17-2010, 11:59 AM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep this is a very nice turbo. Also remember that this car doesn't have AVCS and has aftermarket cams that generally inhibit spool a bit. I would imagine this turbo to spool a bit quicker on an STI. Its also absolutely begging for more octane!
I honestly can't say what the power difference would be with EWG. So far all the cars I've worked with with these turbos have had very different setups, so its tough to pin point the actual gains or losses from the EWG/IWG.
Thanks
-- Ed
Old 03-17-2010, 02:20 PM   #4
rasheedn
Member#: 123333
2009 STi
DMG
is this a 2.0 or 2.5 ?
the chart looks like a 2.5
tell him to add meth and turn some boost
rasheedn is offline   Reply With Quote
Old 03-17-2010, 02:24 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Its a built EJ257 shortblock with EJ205 heads.
Yep, the turbo could really use some more octane, but the customer is taking care of the tranny first.
Thanks
-- Ed
EQ Tuning: 2003 WRX + Full JDM V8 Swap + 18g + 91 Octane = 308whp Equilibrium Tuning Proven Power Bragging 12 04-27-2010 05:17 PM
EQ Tuning: 04 STI, ATP35R, ID2000cc, AEM EMS, E85, 26psi preliminary tune Equilibrium Tuning Proven Power Bragging 34 04-15-2010 10:50 PM
EQ Tuning: - 2009 WRX Simple Setup, Great Power! Equilibrium Tuning Proven Power Bragging 20 03-04-2010 03:07 PM
WI For Sale 2004 WRX STI Built Engine Modified Hayaboosted Private Vehicle 'For Sale' Classifieds 7 11-11-2008 03:32 PM
Will the new legacy be able to use 02-04 wrx parts? Suspension, engine, etc SinhCredible Legacy Forum 18 01-14-2004 06:02 PM
