Old 03-12-2010, 01:22 PM   #1
teh POD
Member#: 90195
Default 2012 Ford Police Interceptor unveiled, second utility model announced
http://www.autoblog.com/2010/03/12/p...ford-unveiled/
gallery: http://www.autoblog.com/gallery/2012...erceptor/full/
Originally Posted by Autoblog
The Ford Crown Victoria has been the chariot of choice (well necessity really) for police officers and cabbies all over America since the demise of its numero uno competitor, the Chevrolet Caprice, back in the mid-'90s. The Crown Vic and its ancestors have been around with a minimum of mechanical changes since roughly the same time as the Model T, or at least it seems that way. However, in recent years the Crown Vic has been increasingly challenged by the Dodge Charger and Chevrolet Impala. Even more troubling for Ford is the impending arrival of a new rear-wheel-drive drive police car from Chevrolet based on the departed Pontiac G8.
At a private fleet sales event in Las Vegas today, Ford finally took the wraps off a new generation Police Interceptor model based on the 2010 Taurus. The new car has big shoes to fill as the Crown Vic has accounted for 70 percent of all police vehicle sales over the past five years. Read on for more on the new Police Interceptor.
This isn't the first time the Taurus has been offered in law enforcement guise. Back in the late '80s and early '90s, a special service package was available and featured prominently as the preferred ride in RoboCop. But aside from that celluloid appearance, those Tauruses didn't really have a full interceptor configuration. First-generation cop Tauruses got beefier brakes and cooling systems, but the powertrain was not up to the task of high-speed highway pursuits.
With the Taurus now assuming the mantle of top cop at Ford, things are a bit different this time around. There were some big hurdles to overcome since police agencies generally shy away from unibody designs like the Taurus over durability concerns. Ford president Mark Fields emphasized that the engineering teams worked closely with police agencies to build a car that met their needs. As such, the unibody structure of the Police Interceptor has been upgraded to meet twice the body durability requirements of the Crown Vic model, which should help alleviate some of the concerns of police agencies.
Safety is job 1 for police cars and Ford has developed the new Police Interceptor to withstand a 75-mile-per-hour rear collision. Fields claimed the car is the first in the industry to meet this standard. The Police Interceptor also retains all of the standard electronic stability and roll stability control systems featured in the Taurus. The systems, however, have been re-calibrated to meet the needs of police use.
As Jake and Elwood said, a cop car needs a cop motor, cop brakes and cop suspension. As we speculated earlier today, the Police Interceptor will get two powertrain options. The base model gets the 3.5-liter V6 found in other Tauruses with over 263 horsepower and 250+ lb-ft of torque. This naturally aspirated 3.5-liter engine is flex-fuel capable and gets 25-percent better fuel efficiency than the 4.6-liter V8 in the Crown Vic. The base models are available with either front- or all-wheel-drive. The top end pursuit version of the new Police Interceptor gets the full SHO powertrain including its 365-hp twin-turbo EcoBoost 3.5-liter V6 and all-wheel-drive as standard.
The Police Interceptor's brakes also have 60 percent more swept area than a standard Taurus and 20 percent more thermal mass to help resist fade. While police officers have generally favored rear-wheel-drive cars for their handling characteristics, Ford officials claim the newly calibrated stability control has been tuned to meet their needs.
Inside Ford has optimized the standard Taurus interior for Police Interceptor duty with new seats claimed to offer better comfort while easing egress with smaller lateral bolsters. They even have cut-outs for police-issue utility belts. The transmission shifter has also been moved from the console to the steering column to make room for all the gear that today's officers require be mounted in the center. Ford has even maintained the same nine-inch width between the seats to allow existing equipment to be mounted from older Crown Vic Interceptors. The switches on the steering wheel can also be re-mapped to control extra aftermarket equipment like lights, sirens and spot-lights.
The Police Interceptor's back seat has a new roomier bench to make getting prisoners in and out easier. The rear door panels have also been slimmed down to make entry/exit easier and they swing out an extra-wide 71 degrees,10 degrees more than a regular Taurus.
The Taurus is not the only new Police Interceptor coming from Ford this year. Fields promised a second un-named vehicle, though did say it would share most parts with the Taurus and be available in a utility version. That indicates it will be either the Flex or the new Explorer, both of which are based on the same platform as the Taurus.
Ford hasn't announced pricing for the new Police Interceptor yet, though did promise it will be price competitive with the outgoing Crown Vic and other vehicles in the segment. Service costs are another issue. Police agencies like the Crown Vic because they can easily swap out banged up body panels. Ford has worked closely with police agencies to keep service costs down on these new models as well. It will also work with agencies to help them upgrade their service facilities to straighten damaged unibodies, a process that is very different from straightening a body-on-frame vehicle.
The new Police Interceptor launches in late 2011, so don't worry about seeing a Taurus glowing blue and red in your rearview mirror just yet.
teh POD is offline   Reply With Quote
Old 03-12-2010, 01:23 PM   #2
teh POD
Member#: 90195
Old 03-12-2010, 01:27 PM   #3
tacomaprime
Member#: 70572
2005 Tacoma
good lord, those seats have less bolstering then a bean bag chair.
tacomaprime is offline   Reply With Quote
Old 03-12-2010, 01:34 PM   #4
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
Dude, have you seen some cops??? You put any bolster in them, you're gonna piss off 50% of the force.
Can't say I like this Taurus police pkg. I still much prefer the "looks" of the Charger (I do not care about other crap, please don't start).
express_wagon is offline   Reply With Quote
Old 03-12-2010, 01:35 PM   #5
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
Ya, i dont know how a cop would feel about fabric covered seats?
If i was a cop i wouldnt been terribly keen on that idea.
moosecakes is offline   Reply With Quote
Old 03-12-2010, 02:00 PM   #6
slvr bullet
Member#: 52400
2004 WRX Wagon
Platinum Silver Metallic
With regard to the seats, cloth is pretty standard in crown Vic interceptors at the moment so that doesn't depart from the norm. And, actually, the lack of significant bolstering on the back of the seat is a good thing for police users. If it had bolsters it would do very bad things to the posture of anyone wearing a duty belt (when your equipment rests on a bolster and it pushes on your back in an awkward way for several hours a day, the effects can really add up).
I actually took note of the seats and was very excited about one thing... Ford moved the female end of the seat belt to the outside of the
seat entirely. The one intergrated into the seat ala crown Vic did similar things as the bolstering problem discussed above.
slvr bullet is offline   Reply With Quote
Old 03-12-2010, 02:50 PM   #7
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
My Caprice ex-cop car had fabric seats too, they seemed to hold up pretty well.
WhiteKnightSTi is offline   Reply With Quote
Old 03-12-2010, 02:56 PM   #8
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
I kind of want one............
SilverSubaab is offline   Reply With Quote
Old 03-12-2010, 03:24 PM   #9
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Sounds like you're a cop!
SWP n Gold is offline   Reply With Quote
Old 03-12-2010, 03:33 PM   #10
ahowell
Member#: 152106
'96 One More Part
For State Of The Art
Well, it looks pretty mean like a cop car should. It is a great idea to have the awd option.
ahowell is offline   Reply With Quote
Old 03-12-2010, 04:06 PM   #11
Yotsuya
Member#: 935
Jack Soo Fan Club
What really sucks is they'll all turn up five years later as taxis...
Yotsuya is offline   Reply With Quote
Old 03-12-2010, 04:14 PM   #12
fourmicah
Member#: 128760
2015 STI
It actually doesn't look bad.
fourmicah is offline   Reply With Quote
Old 03-12-2010, 04:42 PM   #13
gungaslow
Member#: 144906
they should put bench seats in there, so the fat bastards can take a nap after eating a box of donuts..
gungaslow is offline   Reply With Quote
Old 03-12-2010, 04:51 PM   #14
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Robocop would like it.
subyski is offline   Reply With Quote
Old 03-12-2010, 04:56 PM   #15
Lboogie
Member#: 171611
2014 FiST
Blk
Lboogie is offline   Reply With Quote
Old 03-12-2010, 06:09 PM   #16
Damon
Member#: 2902
nice one, i lold.
Damon is offline   Reply With Quote
Old 03-12-2010, 06:23 PM   #17
Dubya R Ex
Member#: 119223
2006 WRX
i dont think side bolsters while wearing a bullet proof vest work to well together.
Dubya R Ex is offline   Reply With Quote
Old 03-12-2010, 06:50 PM   #18
Rootus
Member#: 89821
2015 STI LE
Good point.
I'd also think that given how much a cop gets in and out of the car, having a lot of bolstering would be irritating, and it would probably wear much faster.
Rootus is offline   Reply With Quote
Old 03-12-2010, 08:06 PM   #19
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
I never understood why a vehicle with a thirsty V8 became the hallmark taxi vehicle. For the price, how bout a 2.5L Subaru Outback. Spacious yet efficient.
SLegacy99 is offline   Reply With Quote
Old 03-12-2010, 08:09 PM   #20
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
Apparently it was a joke on the set too.
Old 03-12-2010, 09:14 PM   #21
Tim-H
Member#: 65751
'10 VULVA
It's too bad for Ford, the government already owns a police car manufacturer. They just have to get them imported from AUS.
Tim-H is offline   Reply With Quote
Old 03-12-2010, 10:39 PM   #22
daveyboy
Member#: 35419
Isn't the Taurus SHO around $40K? Yeah, that is exactly what governments with massive budget shortfalls should be buying... .
daveyboy is offline   Reply With Quote
Old 03-12-2010, 11:00 PM   #23
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I figure Ford will be taking a loss on these, at least initially.
Mike Wevrick is offline   Reply With Quote
Old 03-13-2010, 06:55 PM   #24
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
the sho is also loaded to the gills with every option possible. this will be a striped down work car with a good power train built to take abuse. id put the price somewhere around 29-30. same price as a standard issue crown vic police interceptor.
even in a N/A version this 3.5 is a great engine.
timeXlost is offline   Reply With Quote
Old 03-14-2010, 11:11 AM   #25
arghx7
Member#: 232940
I'm glad they're moving to more fuel efficient engines. Think about how much gas (paid for by tax dollars) cops use idling or just cruising around not utilizing much horsepower.
arghx7 is offline   Reply With Quote
FS: 1999 Crown Victoria Police Interceptor spankaveli Private Vehicle 'For Sale' Classifieds 1 07-17-2007 01:29 PM
Ford Police Interceptor (Crown Vic) Fire suppression system (video) munkis Off-Topic 2 04-13-2006 03:59 PM
Local FS - MA State Trooper Police Interceptor Sean New England Impreza Club Forum -- NESIC 24 02-14-2004 12:20 PM
Police interceptors? Billy Canada Region Forum 22 12-25-2001 04:20 AM
