Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Legacy Specific Parts
Old 03-12-2010, 02:39 PM   #1
crrider80
Member Sales Rating: (1)
Member#: 184789
Default FS (NYC): Intake mani, BPV, EJ255 long block, etc.
Hi everyone. I have the following for sale.
EJ255 longblock: $950 picked up obo.
202k miles, cyl #3 misfire, cyl #3 low compression @30 psi, all other cyls are @130 psi +/- a couple psi. I concluded the low compression is due to a burnt exhaust valve from a recent leak down test. I believe the timing belt has been changed around 100k miles and will need to be changed again. Although the problem is a small issue I would suggest a rebuild solely due to the age of the motor. The motor does neither knock nor ping. However it has a funky "Jiggling" feel due to the misfire.
05' LGT plastic intake manifold: $120 shipped obo.
Good for STI guys looking for a inverted manifold conversion
05' LGT BPV: $50 shipped
05' VF40 Turbo: $140 shipped obo
Wastegate door off centered, The wastegate shaft sleeve needs to be pressed further into the housing. Minimal shaft play. No coolant lines or oil lines. Needs e-clip, and the 3 w/g actuator bolts. Essentially good for a core swap.
05' Catted Uppipe: best offer
05' Inlet pipe: best offer
No tears
05' EJ255 cross over pipe: best offer
05' Throttle body coupler: best offer
-Steve
crrider80 is offline   Reply With Quote
FS (NYC):EJ255 longblock, Intake mani, TMIC, BPV etc. crrider80 Engine/Power/Exhaust 12 08-16-2012 02:42 PM
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
FS STI Intake OEM BPV DBW TB Fuel Rails Caps BlackFlame Engine/Power/Exhaust 11 09-24-2009 07:34 PM
pe850, intake mani, tgv, ebc,jdm20k&usdm blocks c'dalerider Engine/Power/Exhaust 12 08-21-2009 03:34 AM
CNJ: Many parts (shortblock, long block, coil packs, uppipe, etc) Lonn17 Tri-State Area Private Classifieds 5 10-29-2008 09:55 AM
