Old 03-12-2010, 03:34 PM   #1
UpSideDownDesi
Member#: 148372
02 WRX,FD,S2K,M5
Hybrid,07 6spd, BW Roated
Default Borg Warner Registry, post your BW setup & #'s here.
BW S256
Event: Dyno pull
Ambient Temp: 101* (this was done last year in june)
Elevation: About 1100
Weather: Hot
Wheels/Tires: 225/45/17
Car: 2002 WRX/Hybrid
Mileage: 20k on engine
Tuner: Mike @ Killshot Performance (formaly known as Sargent Power & Performance)
Dyno Info: Land and Sea, putting out identical number to Dynojet.
Peak HP at RPM: 379whp corrected
Peak Torque at RPM: 385wtq
Baseline hp/tq for a stock on same dyno: 220-230whp
Target Boost: 21psi
Target AFR: 11.1
Fuel: 93 unleaded
Tranny: 06 STI 6spd
Engine/Power Modifications: 2.5l ej257 stock hybrid motor, Sargent Power & Performace (SP) S256 Roated kit :> S256 4" inlet, 58lb/.63 ar , SP 3" down pipe, SP upipe, SP 3" intake, 930cc 07 STI modded injectors, Greddy Counter clock Front mount kit, and rest of supporting mods.
Software: Cobb
3rd gear pull
UpSideDownDesi is offline   Reply With Quote
Old 03-12-2010, 04:59 PM   #2
MRX WRX
Member#: 114566
2005 STI
aspen white
Event: Jtran studios
Ambient Temp: 73
Elevation: sea level
Weather: clear
Car: 2005 STI
Tuner: me
Dyno Info: heartbreaker mustang
Peak HP at RPM: 506
Peak Torque at RPM: 411
Baseline hp/tq for a stock on same dyno: no idea
Target Boost: 24
Target AFR: 11.2
Fuel: e85
Engine/Power Modifications: self assembled the entire car. CP's,carrillos,ACL race,self ported heads (my first suby attempt) BC 272,stock springs,EBAY intake manifold,EBAY modified EL header, five-oh 1000cc sidefeeds,single walbro,perrrin rails,custom engine bay -6 fuel lines. greddy evo midpipe, custom 3" magnaflow axleback and last but not least a borg 177283 turbo with a t3 .7 hotside and the race cover, cobb AP2 with race-tuner
MRX WRX is offline   Reply With Quote
Old 03-13-2010, 10:49 AM   #3
25rsti
Member#: 166324
ive been waiting to see a thread like this. that and a holset one :-)
Old 03-13-2010, 01:17 PM   #4
crashtke
Member#: 120912
Event: dyno pull
Ambient Temp: 64 degrees +-
Elevation: 1,043 FT above sea level
Weather: mostly sunny
Car: 2004 STI
Tuner: Mike Sargent
Dyno Info: Dynojet
Peak HP at RPM: 394 @6250 Standard correction, 390 SAE corrected
Peak Torque at RPM: 365 @4800 Standard Correction, 362 SAE corrected
Baseline hp/tq for a stock on same dyno: 230? Never worked on this particular one before
Target Boost: 22
Target AFR: 10.8-11.1
Fuel: 93 octane unleaded
-Bone stock 170,000 engine
-S256 Borg Warner turbo kit
-OEM Subaru wrx tgv's (flap removed) and fuel rails
-Injector dynamics 1000cc injectors
-SSAC Front mount intercooler-
-Hallman pro boost controller
-Walbro 255 fuel pump
-Catback exhaust
Driveline Modifications:
-Exedy HD organic clutch
Suspension Modifications: Unknown
Other Modifications: Wheels...I do not recall the brand
3rd gear pull.
crashtke is offline   Reply With Quote
Old 03-16-2010, 10:35 PM   #5
Demon2003
Member#: 129983
2007 STI
No S3XX's? Im thinking about one for my new setup is sargent on nasioc?
Demon2003 is offline   Reply With Quote
Old 03-16-2010, 10:54 PM   #6
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Sargent is the guy above u
Old 03-17-2010, 12:34 AM   #7
Demon2003
Member#: 129983
2007 STI
Good to know
Old 03-17-2010, 05:15 AM   #8
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
BW S300SX 83-75 .91AR
Event: Dyno Tune
Ambient Temp: 51F 68% Humidity
Elevation: 200ft
Weather: Seattle Weather
Car: 2007 STi
Tuner: Dominic Acia of Maxwell Power Services (DomTune)
Dyno Info: DynoCom
Peak HP at RPM: 574 WHP @ 6300 RPM SAE Corrected / 596 WHP Uncorrected
Peak Torque at RPM: 502 WTQ @ 5750 RPM SAE Corrected / 522 WTQ Uncorrected
Baseline hp/tq for a stock on same dyno: 245 WHP
Target Boost: 29psi
Target AFR: 11
Fuel: 94 octane + 70/30 meth
Method: Vi-Pec V88
EJ257
CP Pistons 99.75mm w/ Ceramic Crown and Molybdenum Disulfide Skirt Coating
Carrillo Forged H-Beam Rods
Calico Coated ACL Race Bearings
OEM Head Gaskets
ARP Head studs
11mm Oil Pump w/2 shims
B25 Heads
Kelford 276/272 AVCS Cams
5-Angle Intake Valve Job
3-Angle & Radiused Exhaust Valve Job
Supertech +1mm IN/EX Valves
Valves Lapped
Supertech Dual Valve Springs
Titanium Retainers
BW S300sx 83-75 0.91AR
Custom TS-T4 header/up-pipe
Dual Tial 38mm MV-S WGs
APS DR725 FMIC with Custom Upper Pipes
Injector Dynamics Bosch 1000cc Injectors
Aquamist HFS-5 Meth Injection System 2x 1.0mm nozzles
alcoolaid is offline   Reply With Quote
Old 03-17-2010, 11:18 AM   #9
UpSideDownDesi
Member#: 148372
02 WRX,FD,S2K,M5
^^BEAST
Sargent has a s300 series build under contruction also.
Old 03-17-2010, 01:22 PM   #10
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Really interested in seeing a S300SX 91-79 setup. Anyone???
Md05STI is offline   Reply With Quote
Old 03-17-2010, 01:46 PM   #11
juanmedina
Member#: 133146
there will be one up and running soon
Old 03-17-2010, 01:49 PM   #12
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Awesome! Trying to decide between the 91-79 and a pte6765 for my next setup.
Old 03-17-2010, 03:05 PM   #13
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
TDagen is offline   Reply With Quote
Old 03-17-2010, 03:11 PM   #14
mystilexzero
Member#: 154674
2007 wrx
ugm
i also have a bw 91/79 still finishing my block though
mystilexzero is offline   Reply With Quote
Old 03-17-2010, 03:36 PM   #15
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
They had one. I think they have the motor torn down for headwork, cams and a refresh. If you look at the threads crashtke has posted in, you will see it I am sure. Think Mike has a couple more coming soon.
ZenMotors is offline   Reply With Quote
Old 03-17-2010, 03:44 PM   #16
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Yeah I have the 91-79 1.00 ar twinscroll with 3.5 " downpipe .... It will be tuned with speed density powered by E85 very soon ... I'll post it up for sure... Just waiting for Garrett cored intercooler and some Bosch id 2200cc injectors...
Old 03-17-2010, 07:58 PM   #17
crashtke
Member#: 120912
This is Gost's car. It has one of our S362 kits on it. Think the engine was on its way out at the time of this graph as it had horrible blowby from the start. That and we later learned that one of the injector connectors was loose on the cylinder that went out. After inspecting the piston, it looked like it had been slowly beating itself in the cylinder also due to some BIG clearances.
We now have the motor down for a refresh and higher compression custom pistons, cams, port and polish, along with some bigger valves, new injectors. But thought I would post up the original tune as something to compare to later. This is the last time I tuned it before we decided to tear it down to see what was going on with the motor.
Sorry, I know the scan is not the best.
Event: dyno pull
Ambient Temp: 65 degrees +-
Weather: mostly cloudy
Car: 2004 STI
Tuner: Mike Sargent
Dyno Info: Dynojet
Peak HP at RPM: [email protected] Std correction
Peak Torque at RPM: 406@~5100
Target Boost: 25
Target AFR: 11.2
Fuel: 93 octane with 50/50 meth
-Forged pistons
-S362 Borg Warner turbo kit
-Modded Sti sidefeeds
-SSAC Front mount intercooler-Modified piping
-Catback exhaust
-Exedy 3 puck clutch
Third gear pull:
Old 03-17-2010, 08:27 PM   #18
cubuff
Member#: 38345
2004 WRB WRX
I have a 91-79 with a 1.00 a/r on my ej207. I have only tuned up to 28psi and my plans are to take it to around 38-40. On 28psi it made 527 on a dyno dynamics. Up here at a mile above sea level 520+ on this dyno runs 10's. On 40psi im pretty sure it will make over 600 on this dyno. I will have a full tune here within the next couple of months.
A graph is in my thread. It can be found at the bottom of page 6.
http://forums.nasioc.com/forums/show...1811795&page=6
Its laggy but it goes to 9000rpm.
cubuff is offline   Reply With Quote
Old 03-17-2010, 09:26 PM   #19
Gost
Member#: 148686
2004 WRX STI
Woot! loving this thread! Cant wait to get my car up and running again and post up some #'s
Gost is offline   Reply With Quote
Old 03-18-2010, 10:10 PM   #20
MRX WRX
Member#: 114566
2005 STI
aspen white
mine is a s300sx3!
Old 03-18-2010, 11:14 PM   #21
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Here is a picture of the 91-79 1.00-hotside mounted on my Chimera performance Twin Scroll setup ....Once I get everything installed and tuned I will post up the numbers/graph...
Turbo is fairly large...
Old 03-18-2010, 11:32 PM   #22
Nuke209
Member#: 108089
2003 WRX
NF Performance
Have fun Travis
Nuke209 is offline   Reply With Quote
Old 03-18-2010, 11:35 PM   #23
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Originally Posted by Nuke209 View Post
Have fun Travis
No fun to be had until we run into you guys ! We have been just waiting to get the car out again its been a long winter.....
Old 03-18-2010, 11:53 PM   #24
Nuke209
Member#: 108089
2003 WRX
NF Performance
Not gonna be fun at all now
That's just bullying us.
But...that may just have to change, eh?
Old 03-18-2010, 11:59 PM   #25
Rick Hunter
Member#: 825
2002 wrx
Great results and great thread gents!
Give me 2-3 months and I'll have some BW s258 0.70 AR results on a 3MI 2.34L LR & jdm v8 heads... can't wait
Rick Hunter is offline   Reply With Quote
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
