Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-03-2011, 07:23 PM   #2551
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
double post
seanathanq83 is offline   Reply With Quote
Old 10-04-2011, 03:31 AM   #2552
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Originally Posted by Bbee 4 View Post
My set up made by jzk25
EFR 8374
Not on the motor yet.
Updates when ready.
nice setup, wow that thing is big!
i still like iwg design that efr offers
not digging your 2 90 degree bends for the waste gas to exit,
Bariga is offline   Reply With Quote
Old 10-04-2011, 07:18 AM   #2553
crashtke
Member#: 120912
Mild steel I guess.
crashtke is offline   Reply With Quote
Old 10-04-2011, 07:39 AM   #2554
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Paul your new setup looks amazing! Icantvwait to see what it does, and how the Cosworth drysump works out. Being eyeing that unit for a while now...
GL mate
waynoSTI is offline   Reply With Quote
Old 10-04-2011, 11:59 PM   #2555
Bbee 4
Member#: 138867
2000 wrx
white
Thanks Wayno.
Micah I will rely on the cosworth pump to do its thing.
Bbee 4 is offline   Reply With Quote
Old 10-05-2011, 03:38 AM   #2556
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Thanks Wayno.
Excellent set-up with super short header lenght!
I second Micah's concern though that dry-sump "vacuum" won't suck the aerated oil 'up the hill' or will you run a second stage on the DS pump especially for the oil return?
Beetspeed is offline   Reply With Quote
Old 10-05-2011, 04:06 AM   #2557
Bbee 4
Member#: 138867
2000 wrx
white
I'll suss it when I put the new engine and other stuff in. Thanks for your concern too.
Old 10-05-2011, 09:30 AM   #2558
seanathanq83
Member#: 173241
i think it you rotate the center housing backwards that it will make it easier to pull the oil back from the turbo, but not to much or it might cause pooling inside the CHRA
Old 10-05-2011, 11:46 AM   #2559
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Thanks Wayno.
Yes, it'll do it's thing but will continue to pull vacuum and that vacuum will be filled with the path of least resistance.
At least you won't have pressure (much) to keep the oil in the return line.
That would be the real option. If it were me, I'd add three stages and get both heads into that system
Old 10-06-2011, 12:09 AM   #2560
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
little teaser for now, car should be up next week with any luck.
Dipp is offline   Reply With Quote
Old 10-06-2011, 12:20 AM   #2561
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
that thing looks massive
Old 10-06-2011, 12:41 AM   #2562
Dipp
Member#: 127907
99RS 9.54 @ 146
It is, had to do some creative cutting of the frame to make it fit.
Old 10-06-2011, 04:55 AM   #2563
02RexWI
Member#: 165141
What kind of oil return pump are you running?
02RexWI is offline   Reply With Quote
Old 10-06-2011, 09:40 AM   #2564
Dipp
Member#: 127907
99RS 9.54 @ 146
http://www.turbowerx.com/Scavenge_Pu.../Exa-Pump.html
Old 10-06-2011, 11:13 AM   #2565
02RexWI
Member#: 165141
^I'll keep that in mind if/when my manifold cracks.
Old 10-06-2011, 11:14 AM   #2566
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Dipp,
That thing is awesome looking!! What trans/EMS is going in that?
Junior2JZ is offline   Reply With Quote
Old 10-06-2011, 03:07 PM   #2567
Dipp
Member#: 127907
99RS 9.54 @ 146
Originally Posted by Junior2JZ View Post
Dipp,
Built 4EAT just like St. luticas it has a transbrake with full manual valve body. Im running a Hydra but I need the new software, its currently the 2.17 version
Old 10-24-2011, 01:07 AM   #2568
seanathanq83
Member#: 173241
so i got all my electrical sorted out and have started tuning, im thinking my fuel pumps going, i have 800cc injectors and im showing 93% but according to my logs im only making 350, and 270 with VD, i have actually did a few pulls so i am not 100% sure if that was the right gear, i had some saying 450, which would be more right with the fueling i will try to get some dynos up tomorrow, but car runs insanely good at 23.5psi
Old 10-26-2011, 12:53 AM   #2569
seanathanq83
Member#: 173241
So does anyone else have an s200sx-56 on a 2.0??? All I have to say is I love this Turbo with the .83 exhaust side im making 24psi at 4300-4700 in 4th gear depending how hot the turbine is I assume, gotta love spool like a Vf Turbo and 100whp+ more
Old 10-26-2011, 03:00 AM   #2570
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 10-26-2011, 07:43 AM   #2571
sumfoo1
Member#: 82146
2005 Legacy GT
now that's efr and it's so pretty my junk just jumped.
sumfoo1 is offline   Reply With Quote
Old 10-26-2011, 08:15 PM   #2572
Member#: 264595
Now you know why Anton has called in to work sick this whole week! He had the motor back in within 15 minutes of taking the turbo out of the packaging. Haha.
raffi@full-race is offline   Reply With Quote
Old 10-26-2011, 09:34 PM   #2573
seanathanq83
Member#: 173241
Hey Raffi what are the dimensions of the 8374 compared to my s200sx-56 (7670)?? Im hitting 24 psi by 4300-4700, just feeling a little lacking in the power, only making ~400 on VD (dynojet setting, granted im running out of fuel so maybe 430-440) but I can't see this having much slower spool, And I just dont see the EFR7670 making much more power. So deft concidering going to the 8375 or efr8374
Old 10-26-2011, 09:58 PM   #2574
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Any updates brotha? I wanna see this beast bust some serious times out, it's gonna be scary fast
TDagen is offline   Reply With Quote
Old 10-26-2011, 10:18 PM   #2575
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
I guess if you save up 9 months of sick days he's taking next week off too for the tune
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
