Old 05-25-2012, 06:09 PM   #2701
LittleBlueGT
Member#: 96204
2013 STI GR
Originally Posted by Nagase View Post
The 6758 has better response than stock, the 7064 has much worse.
Just to clarify:
The SS 7064 has a higher boost threshold then stock. Will it help if it were TS, maybe, not a HUGE difference though.
And boost threshold does not equate to response. It kinda used to when all turbos were constructed the same, but w/ the EFR's lightweight rotating assembly, the SS7064 may in fact be just as responsive as a stock turbo, despite the higher boost threshold.
LittleBlueGT is offline   Reply With Quote
Old 06-04-2012, 02:49 PM   #2702
monkiboy
Member#: 202958
2008 wrx
forgot to post the results of the first dyno session in here:
this is a twin-scroll IWG 7064EFR on an 08 wrx with the full-race kit @ ~17psi peak boost on 93 pump. will be on the dyno again in a couple weeks for a final result @ 26-28psi on 93 pump + meth.
monkiboy is offline   Reply With Quote
Old 07-18-2012, 07:30 PM   #2703
Moore Performance
Member#: 231489
Here's a new Borg-Warner twin scroll setup we've been working on (non-EFR). Straight pump gas, on your typical Mustang heart-breaker dyno:
So far, so good on the s300/s200 hybrid...aka the Cy-Borg™ !!
here's the full writeup:Project 600 WHP: Moore Performance-built twin-scroll 08 STI
Moore Performance is offline   Reply With Quote
Old 07-18-2012, 07:34 PM   #2704
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Updates? Mine put down 365whp @ 25 psi on a 205. Hoping to see better results on a 2.5L....
thefoos is offline   Reply With Quote
Old 07-19-2012, 03:21 AM   #2705
Bilyk WRX
Member#: 89058
2003 WRX 9.33/151mph
EJ257+PT7675 840whp
my new 2012 BW S374 setup with big throttle
Bilyk WRX is offline   Reply With Quote
Old 08-06-2012, 10:17 PM   #2706
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Okay i know this may not be the best place but my friend ended up with a huge borg warner turbo good for like 800whp turbo and the spool is beyond ****ty for what he wants it for. He has a fullrace twin scroll t4 setup basically. he found a older s200 series turbo with an ar1.22 hotside. the actual compressor size is unknown but its from a johndeere diesel setup i assume. anyone on here have an idea what kinda of spool i will have with this setup? If i need to search elsewhere let me know. i have never looked for a turbo bigger than a dom1.5 so this is all out of my league but he wanted me to check with what you huge turbo guys have in mind.
oh yeah and is there a possibility other hotsides will fit on it from an older s200 BW turbo's? its for his build 2.5L so i am assuming spool will only get better than what this beast is putting down now.
WhiteBgeye02 is offline   Reply With Quote
Old 08-07-2012, 11:34 AM   #2707
monkiboy
Member#: 202958
2008 wrx
sorry, never got the thread update. hopefully you've already seen the results in my build thread, though. it makes sense to post the final results here as well:
pump @ 20psi peak.
pump + meth @ 29psi peak.
EFR 70/64 IWG, full-race kit on a 08 wrx.
Old 08-07-2012, 11:47 AM   #2708
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Graph from last tune, full-race EFR 7670 IWG
pump @ 19 psi
pump + meth 23 psi
Bariga is offline   Reply With Quote
Old 08-08-2012, 08:51 AM   #2709
garagedefeat
Member#: 101399
2001 Forester L
^^ looking good! What kind of dyno does Maxwell have? DD?
garagedefeat is offline   Reply With Quote
Old 08-08-2012, 11:43 AM   #2710
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Dynocom
Old 08-08-2012, 08:42 PM   #2711
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
bariga, that chart looks promising would you mind reposting it? Hard to see the torque curve and 3000rpm axis
Full-Race Geoff is offline   Reply With Quote
Old 08-08-2012, 09:03 PM   #2712
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
pump @ 20psi peak.
Sweet. I knew the 7064 had much better in it....
Old 08-08-2012, 09:53 PM   #2713
Phatron
Member#: 36033
CEO PhatBottiTuning
Monki,
How come the meth plot picked up 50tq down low at the beginning of the plot? I'm assuming the meth isnt spraying that early?
Old 08-09-2012, 12:11 AM   #2714
monkiboy
Member#: 202958
2008 wrx
Originally Posted by Phatron View Post
Monki,
i really wish the boost sensor was working on the dyno then i could answer more confidently but meth begins spraying right around 11psi so it's possible with as responsive as this thing has proven.
Old 08-09-2012, 08:25 AM   #2715
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Monki,
What I have seen on my car is that even at low rpm, boost builds to 5-10 psi before the natural "spool" rpm. I bet he is spraying meth before the turbo really gets rolling....
If you are talking about the bump up at ~3900rpm, boost builds fast with these wheels, boost has a tendancy to rise quicker than the system can respond to it. With a PID controller, you are normally going to get an overshoot anyway, but even more so with these wheels. I'm assuming that is what happened on this dyno run.
Old 08-09-2012, 09:55 AM   #2716
garagedefeat
Member#: 101399
2001 Forester L
Dynocom
thanks. Any idea how they read as compared to the de facto Dynojets/Mustangs out there?
Old 08-09-2012, 10:56 AM   #2717
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Equilibrium tuning on their Dynocom dyno:
This is not from a road dyno. It's from our Dynocom chassis dyno running a .85 correction factor to make it read like my old road dyno software.
Thanks
-- Ed
Their road dyno software ends up about 10-15% higher than GST's heartbreaker Mustang Dyno in terms of HP, and very close to a properly setup airboy plot.
That puts Ed's uncorrected Dynocom right in the ballpark of a typical Dynojet. I don't know how similar the dyno at Maxwell Power is to the Dynocom at Equilibrium, but that gives you some idea anyway.
Concillian is offline   Reply With Quote
Old 08-09-2012, 12:03 PM   #2718
Phatron
Member#: 36033
CEO PhatBottiTuning
Just search for threads by mps and u can draw your own conclusions about how it reads. IMO it reads in the Dynojet and dynapack arena.
Ed's reads on the low side.
Old 08-13-2012, 11:23 AM   #2719
monkiboy
Member#: 202958
2008 wrx
ps - i'm selling the EFR t4 twinscroll 7064 (< 800 miles) from the above dyno plot as i'm going to go a bit bigger but staying with an EFR. if interested feel free to PM!
Old 08-13-2012, 07:07 PM   #2720
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Well, I received my new turbo today for my full retard project. Just waiting on my engine to be finished then the real project begins... mounting this insane thing. Edit: picture is next to a td04. I need to find a 30R or 35R to compare it to, pictures do not do it justice.
S400SX 67mm FMW 1.25 AR twinscroll. I will probably end up downsizing the hotside but I wanted to see how bad it would really be first. Still undecided if I am going to run it in actual twinscroll configuration or try out a Sound Performance QSV.
RexFTW is offline   Reply With Quote
Old 08-13-2012, 08:05 PM   #2721
SubieLuvin
Member#: 248202
2013 WRX Sedan
Holy **** balls
SubieLuvin is offline   Reply With Quote
Old 08-13-2012, 08:45 PM   #2722
rymaggi
Member#: 253442
Is this going in a Subaru?
rymaggi is offline   Reply With Quote
Old 08-13-2012, 09:43 PM   #2723
Clark Turner
Member#: 178047
02 WRX STI Spec C
BW turbos have such a big frame size in comparison to compariable garrett products. Thats a bigun there.
Clark Turner is offline   Reply With Quote
Old 08-13-2012, 09:45 PM   #2724
Layvon
Member#: 195711
STi 04/05/06/07
Layvon is online now   Reply With Quote
Old 08-13-2012, 11:55 PM   #2725
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Originally Posted by SubieLuvin View Post
Holy **** balls
Yeaup, it's going on my bugeye.
Yeah, I knew they were big, but holy cow the size on this thing is ludicrous.
This might be the closest thing I have to a good visual representation of it's size.
Same td04.
I may very well end up stepping down to the 1.1 housing, we will see. I am planning on running a lot of boost, I'm not a lag vagina at all, and it is twinscroll so I will just have to wait and see. Swapping hotsides will be the easiest part of this once everything is together.
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
