Old 08-14-2012, 12:24 AM   #2726
rymaggi
Member#: 253442
1. where the hell is that gonna fit
2. how much freaking whp are u aiming for.
rymaggi is offline   Reply With Quote
Old 08-14-2012, 12:53 AM   #2727
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
That is why I bought it this early, to get a gauge of it's size and start playing with where to mount it. Currently it is between fog light mounting and finding a way to squeeze it in rotated. Fog light seems to be the more likely approach.
I don't really have an exact whp target, but enough to scare some of the serious cars at RSDs. RSDs stands for Real Street Drags, basically street racing, but at a drag strip so none of the legal issues. But you can give spots, go off a light or whatever instead of a tree, betting is encouraged... etc.
RexFTW is offline   Reply With Quote
Old 08-15-2012, 03:22 AM   #2728
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Rex,
Why no anti-surge housing?
Walter
Beetspeed is offline   Reply With Quote
Old 08-15-2012, 11:30 AM   #2729
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Originally Posted by Beetspeed View Post
Rex,
Walter
Hi Walter,
It actually is an anti surge housing. Borg does it a bit differently than other people, this is a quick picture off google to illustrate.
You can see the slot at the top of the compressor blades and a large slot further up the inlet. The surge port is actually set up so when you look straight at the turbo it isn't apparent it has one, but the ports are integrated into the walls of the inlet so it indeed is an anti-surge housing.
Old 08-16-2012, 04:44 AM   #2730
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Very cool, thanks for showing it explicitely!
Old 08-29-2012, 12:09 PM   #2731
monkiboy
Member#: 202958
2008 wrx
from my setup posted above, the impossible to get and rare species EFR 7064 twinscroll turbo is for sale on ebay and here.
http://www.ebay.com/itm/120976806737?item=120976806737
monkiboy is online now   Reply With Quote
Old 08-29-2012, 12:53 PM   #2732
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
why not sell it back to fullrace? isn't there a ****ing 10 years back order?
Bariga is offline   Reply With Quote
Old 01-10-2013, 07:48 PM   #2733
Llyon Gauge
Member#: 173086
2006 WRX TR
Hi guys, my name's Manny and I'm relatively new to Borg Warners.
I was looking at the S256 I believe, but currently am running a single scroll setup. I hope to go twin scroll some time in the future, but for now, it seems unlikely. Can I run the divided Borg Warner turbo without any damage / only the loss of the benefit of being twin scroll without issue for the moment? My ideal turbo would be a Air Werks line that is T4 single scroll, with a 3in Vband down pipe making about 500whp.
http://www.agpturbo.com/borg-warner-...-580-hp-turbo/
This is the turbo I was looking into. To give you an idea of the setup I am currently running:
I ended up getting this turbo for a steal, and was mislead to what it truly was. It is laggy as all hell. Turns out it's an old Precision turbo that was originally for diesel performance. Needless to say that I am unhappy with it. I would also prefer something from the Airwerks line too. If anyone could help lead me in the right direction, it would be greatly appreciated.
Motor specs:
Engine / Drivetrain:
Beatrush Alternator Cover
Beatrush Air / Oil Seperator / Catch Can
Borla Unequal Length Headers
Pfitzner Performance Gearbox (PPG) Helical cut 1-5/R Dogbox (Built by Andrewtech Automotive)
Beatrush Forged Motor Mounts
Beatrush Transmission mount
Beatrush Forged Pitchstop
Deatschwerk Topfeed 850CC Injectors
Cusco Tarmac Center Differential
ARC Radiator Cap
HKS Carbon Ti Catback Exhaust
Precision GT-Q 70 trim T-4 w/ anti-surge housing
Tune by Michael Adkins
HKS Camp-2 (w/ supporting sensors)
Tial 44mm External Wastegate
Aeromotive 300lph fuel pump
TurboXS FMIC
ACT 6 Puck Sprung Clutch
Optima Yellow Top Battery (Relocated to Trunk)
Performance Race Solutions Rotated Mount Turbo kit & FMIC piping
Perrin Top Feed Fuel Rail kit
Cosworth Main Bearings
Cosworth 11mm Headstuds
Cosworth Rod Bearings
Cosworth High Volume Intake Manifold
Cosworth High Volume/High pressure Blueprinted Oil Pump
CP Pistons / Rings 100mm 9:1 Compression
ARP Case Studs
Power Enterprises Timing Belt
Mishimoto Radiator
Mishimoto Radiator Hose kit
Brian Crower Stage 2 - 272 spec Camshafts
Brian Crower Titanium spring / retainer kit
Brian Crower Intake Valves 37mm
Brian Crower Exhaust Valves 33mm
Ported & Polished head
...and if anyone could recommend a non-laggy Airwerks line, that would be amazing.
Thank you guys in advance,
Manny
Llyon Gauge is offline   Reply With Quote
Old 01-10-2013, 08:15 PM   #2734
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
The S200SX turbos are now available with T3 external WG housings - that should work well for you and you could easily swap to the twinscroll housing at a later date when you are ready to change the exhaust manifold and up pipe
Full-Race Geoff is offline   Reply With Quote
Old 01-11-2013, 12:55 AM   #2735
Bbee 4
Member#: 138867
2000 wrx
white
Originally Posted by Homemade WRX View Post
Yes, it'll do it's thing but will continue to pull vacuum and that vacuum will be filled with the path of least resistance.
At least you won't have pressure (much) to keep the oil in the return line.
That would be the real option. If it were me, I'd add three stages and get both heads into that system
How would you go about doing that?
Bbee 4 is offline   Reply With Quote
Old 01-11-2013, 03:22 AM   #2736
Bru1212
Member#: 178770
06 STi
04 FXT
In for overtime reading
Bru1212 is offline   Reply With Quote
Old 01-11-2013, 11:48 AM   #2737
3MI Racing
Member#: 200987
Wow, that must have been a while back. What was the full quote/what were we discussing? Seems like I'm talking about a dry sump and multiple stages being used to scavenge.
3MI Racing is offline   Reply With Quote
Old 01-11-2013, 12:06 PM   #2738
WhatTurboLag?
Member#: 243992
2006 WRX TR
So I'm excited to say I saw the full race kit pricing has come down a LOT. And my dream of getting one is a lot closer. Ordering it ewgless and I'm going to have custom side exit ewg's made.
Anyway
I'm looking at a s200 7670 but in t4 twin scroll, don't need more than 400whp @20psi on pump gas 93 octane. Want good spool and power to redline.
Might get a bullseye batmowheel billet compressor wheel if they make one for the s200 turbos.
I don't get how/why these journal bearing turbos spool so fast compared to a Bb turbo of the same size. How's transient response compared to a bb turbo of the same size?
To say the least I'm going to be excited when it happens.
WhatTurboLag? is offline   Reply With Quote
Old 01-13-2013, 02:17 AM   #2739
Bbee 4
Member#: 138867
2000 wrx
white
From post 2544 on page 102.
It was made by homemade wrx I think
Old 01-14-2013, 10:59 AM   #2740
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
that is an excellent turbo, one of the best values in the industry and with twinscroll configuration it works GREAT and can definitely meet your targets.
It comes down to borg warner's unique turbine wheels, which have excellent turbine efficiency .. everyone seems to get caught up starting at shiny billet compressor wheels, but the turbine wheel and housing is IMHO the most critical and overlooked element in any turbo
i do not recommend that... the testing ive seen indicates the batmowheel is a gimmick that does not perform
Old 01-14-2013, 05:24 PM   #2741
WhatTurboLag?
Member#: 243992
2006 WRX TR
Done, 7670 it is. and ill tell you guys about my side exit idea when I call to order. Hopefully over summer. Basically I want 2 38mm ewg's welded on the manifold or up pipe near the mani to up pipe connection and they will go out the bottom passenger side of the front bumper by the wheel well.
Wat hot side do you recommend? Stock 2.5 block and heads.
Eventually will have a de stroked 2.3 sleeved and bored back to 2.5. But I will probably will have a bigger turbo then anyway.
Old 01-14-2013, 06:58 PM   #2742
chohakai
Member#: 52263
Interesting! Can the S200SX 7670 come with a divided T3 housing (w/ V-band outlet)?
Aslo the S200SX 7670, does it use the same turbine and compressor wheels as the EFR 7670 turbo?
Thanks, Geoff!
chohakai is offline   Reply With Quote
Old 01-14-2013, 07:06 PM   #2743
WhatTurboLag?
Member#: 243992
2006 WRX TR
Nope.
It's not a billet compressor wheel.
Also how durable are they to abuse, high temps and rally style antilag?
Old 01-15-2013, 12:07 AM   #2744
subbi7
Member#: 241967
02 wrx
does anyone use the new 8070?
how does it perform?
subbi7 is offline   Reply With Quote
Old 01-15-2013, 12:58 AM   #2745
poohbear
Member#: 154043
2006 WRX Wagon
I have the s200sx 8070 its a great turbo. On a mustang dyno it made 400 whp @ 20 psi on 92 pump gas. Feels good on the street. Running full-race el headers and downpipe.
poohbear is offline   Reply With Quote
Old 01-15-2013, 03:10 AM   #2746
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
That's pretty sick man ^. Nice
stretchedk7 is offline   Reply With Quote
Old 01-15-2013, 09:25 AM   #2747
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
I switched eventually to that turbo (S200SX 7670) and also had a DOM3 (3076R) before on the exact same engine. My DOM3 had the 8cm² A/R turbine housing. So, same size compressor wheel, only different hot sides.
The 7670 I ordered had a sort of hybrid T3 twin scroll with T4 bolt pattern and flange and ported to fit a T4 tiwn-scroll flange.
The 7670 spooled only 200-300 rpm later BUT made the same torque (and this hp) down low!
Conclusion: the larger, but also better flowing twin-scroll turbine housing caused a better VE of the engine, thus using the available boost better through less back-pressure.
Up top the 7670 made 50 hp more (maybe also because 4" intake BW vs 2,4" intake DOM3)
YMMV
Walter
Old 01-15-2013, 09:34 AM   #2748
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Proud owner of the TS Bw 8374 with internal waste gates. Pics to follow along with build info.....tuning charts dyno sheets etc....
Coop1103 is offline   Reply With Quote
Old 01-15-2013, 09:52 AM   #2749
WhatTurboLag?
Member#: 243992
2006 WRX TR
Thumbs down
YMMV
Walter
How much bigger was the hot side on the 7670?
That's still pretty damn good if u ask me. I will be getting it in ts aswell.
I want the hot side to be big enough to hold power just to redline without falling off, but not be laggy as piss.
Old 01-15-2013, 12:21 PM   #2750
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
the 8070 is another excellent turbo in the lineup, here is a dyno comparison on a stock internal 2.5L STI of the S200SX 80-70 (green) VS the S300sx 8375 (red) with our FR twinscroll kit:
I switched eventually to that turbo (S200SX 7670) and also had a DOM3 (3076R) before on the exact same engine. My DOM3 had the 8cm² A/R turbine housing. So, same size compressor wheel, only different hot sides. The 7670 I ordered had a sort of hybrid T3 twin scroll with T4 bolt pattern and flange and ported to fit a T4 tiwn-scroll flange. The 7670 spooled only 200-300 rpm later BUT made the same torque (and this hp) down low! Conclusion: the larger, but also better flowing twin-scroll turbine housing caused a better VE of the engine, thus using the available boost better through less back-pressure.
that is consistent with what we've seen, thanks for posting. One thing to note is that the 70mm turbine wheel is a *really* good wheel... extremely efficient and i believe is mostly responsible for the gains compared to your old garrett - not just the twinscroll turbine housing
Originally Posted by chohakai View Post
Interesting! Can the S200SX 7670 come with a divided T3 housing (w/ V-band outlet)? Aslo the S200SX 7670, does it use the same turbine and compressor wheels as the EFR 7670 turbo?
-the S200SX 7670 has the same turbine wheel blade shape as the EFR, but it does not share the superback on the turbine wheel nor does it have the same compressor
-S200SX are not available with any sort of T3 housing, T4 only, however there are T3 sized openings on the T4 bolt pattern... so you could definitely make it work with a T3 if you wanted.
would you mind posting your dyno chart? Interested to see if possible
thats the same turbo i run on my daily driver, its an animal...
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
