Old 05-26-2010, 05:40 PM   #276
syoung0298
Member#: 84772
2005 GDB STI
Originally Posted by TDagen View Post
Let's see the log for that airboy, logs shows more than that plot... To me it looks like the 91-79 is clearly spooling faster than the 4088 in that set of logs. This is probably an example of a log where the 4088 had a bad log ( pulled timing , weather , really could be anything, like I said my logs on the 30r would change sometimes if I did the log during day vs night ect... I have heard that The Borg Warner comes back into boost between shifts much faster than the Garrett BB, that's what I'm looking for... If I'm racing I know imgoing to be racing and can keep the engine at an rpm that will have the turbo ready to roll, or brake boost so im not worried about the transiet response ( turbo lag) but you cannot control the boost between shifts... Have you noticed this with the bw between shifts at all syoung?
Once either turbo is spooled up.. lag and transient response aren't an issue .. both recover equally well between shifts..
syoung0298 is offline   Reply With Quote
Old 05-26-2010, 05:49 PM   #277
crashtke
Member#: 120912
There was also a housing difference...the bw was a .91 vs the 1.06 of the garret. Peak torque by 5000 rpms vs. 5500 rpms and looks like with the .91 300 torque by 4000 rpms. I'll take it!
crashtke is offline   Reply With Quote
Old 06-01-2010, 09:05 PM   #278
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Here are a couple engine bay pics with my Chimera Performance twinscroll Borg Warner 91-79 installed...Everything is ready to drive all I have left is to install the 2200cc as soon as I get them....
TDagen is offline   Reply With Quote
Old 06-01-2010, 09:30 PM   #279
Clark Turner
Member#: 178047
02 WRX STI Spec C
thats a big boy
C
Clark Turner is offline   Reply With Quote
Old 06-01-2010, 09:36 PM   #280
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
It looks great Travis
Old 06-01-2010, 09:43 PM   #281
MartinSTi05
Member#: 145145
2006 wrx STi
Looks great, but I'd be hesitant to use a bent tube AL fitting that close to the hotside, especially considering the turbo has no blanket.
MartinSTi05 is offline   Reply With Quote
Old 06-01-2010, 09:53 PM   #282
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
hhhmmm maybe I should have went a steel fitting? Never crossed my mind... I am throwing a Garrett turbo blanket on soon...I could wrap that fitting with heat reflective tape for now or something I guess lol...
Old 06-01-2010, 09:56 PM   #283
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Thanks Juan! It's killing me just sitting in the garage , I need to tune and do logs NOW!!
Old 06-02-2010, 02:10 AM   #284
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
You beat me to the install. I picked up my Full Race kit at their shop today. Hauled it 7 hours back home and took it out of the box to admire it. The quality is like nothing I've seen in the Subaru world before. I'll post pics soon. I won't have time to install it for probably 2 weeks though.
06rexwagon is offline   Reply With Quote
Old 06-02-2010, 02:23 AM   #285
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Hell yeah! Get it installed! Which turbo you testing first? Also which a/r hotsides did you choose?
Old 06-02-2010, 05:27 AM   #286
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
How many lbs is the 83-75 and 88-75 again? Choices and some more choices!
ASU is offline   Reply With Quote
Old 06-02-2010, 09:49 AM   #287
06rexwagon
Member#: 114730
[email protected]
I'll start with the 83-75. I got the 83-75 with .91 a/r and the 88-75 with 1.00. I will try the 1.00 on the 83-75 and see how it does. I doubt I'll put the .91 on the 88-75 but it's possible.
From Full Race's page:
"The 83-75 has an ultra-high flow 68 lb/min 7 blade extended-tip compressor wheel and a 10 blade 75mm inconel turbine wheel with 4340 shaft. Recommended for use in quick spooling 500-680+whp applications, this is an excellent turbo for a very fast 4cyl street car."
88-75
"The Compressor is a 7 bladed 63mm inducer, 88mm exducer rated at ~75lb/min. Recommended for use in high flow 450-750whp applications "
Old 06-02-2010, 09:53 AM   #288
06rexwagon
Member#: 114730
[email protected]
Where did you put your upper coolant reservoir?
Old 06-02-2010, 10:02 AM   #289
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
I deleted it and tee'd the lines... Cleans it up a bit. The Borg Warner only needs oil feed so I figured no point
Old 06-02-2010, 03:34 PM   #290
rexblake
Member#: 178426
2010 S4
Gray
I want one. Probably a good thing I left MN, otherwise I'd be getting a hold of Fobia for an upgrade...
rexblake is offline   Reply With Quote
Old 06-02-2010, 03:53 PM   #291
MartinSTi05
Member#: 145145
2006 wrx STi
My .02 Cents, If you care.....LOL
use a steel or AL Forged 90 fitting. and blanket it. Otherwise if you really have your heart set on a bent tube fitting use a steel one, and use teflon lines (much more heat resistant than rubber). Ill post pictures of my setup, as I have a unique one that showcases my thoughts/eccentricities well;-)
Old 06-02-2010, 03:55 PM   #292
MartinSTi05
Member#: 145145
2006 wrx STi
How do you plan on filling the system with no upper coolant resevoir? I made a banjo block and simply capped the turbo coolant lines and retained the upper coolant resvoir.
Old 06-02-2010, 04:18 PM   #293
crashtke
Member#: 120912
We have used the main radiator cap in some of the cars we did. Has not really been an issue. Top off the radiator, then top off the coolant reservoir.
Old 06-02-2010, 05:32 PM   #294
juanmedina
Member#: 133146
+12345 just let the coolant system burp for 15 minutes
Old 06-02-2010, 05:58 PM   #295
06rexwagon
Member#: 114730
[email protected]
I hadn't considered removing the reservoir. It's ok to just cap the coolant line on the head? I was going to create a bypass but if I don't need to I'll just T everything and cap the line on the head.
Old 06-02-2010, 09:26 PM   #296
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
The line going to the head is tee'd into the other ones, it can still flow just no more gravity feeding coolant tank for the turbo...There's four lines on the upper coolant tank one of them is an overflow line , that one gets deleted and the other three get tee'd
Old 06-03-2010, 02:20 AM   #297
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
I am fairly certain the only point of the coolant reservoir is because the turbo is the high point in the system without it right? If his turbo no longer needs coolant there is no more need, should be able to fill it from the radiator cap like a normal person.
Ben
Old 06-03-2010, 10:45 AM   #298
ASU
Member#: 164551
2006 Brotastic STi
Me want the 91-79 but it is to big for me, so I decided to go for the 88-75. Im going to transfer my S259 into my new WRX bugeye project starting soon.
Old 06-03-2010, 12:04 PM   #299
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
LOL, yeah 91-79 is pretty big!! But the 88-75 isn't small either! I think the 88-75 is bigger than a 37r
Old 06-03-2010, 06:59 PM   #300
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
I know a place right by my house that does great ceramic coating, for a decent price you should get your hotside done.
Dipp is offline   Reply With Quote
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 10:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 02:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 04:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 01:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 04:12 PM
