Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 04-19-2010, 04:30 PM   #101
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Crashtke what do you think this turbo should spool at even with the 272 Kelford cams, Joe at goodspeed thinks the large Diameter runners on the AMR header is hurting the spool up on the turbo and Clark thinks the .70 is just too big.
ASU is offline   Reply With Quote
Old 04-19-2010, 04:34 PM   #102
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
.70 on a twinscroll is pretty small really.
06rexwagon is offline   Reply With Quote
Old 04-19-2010, 04:36 PM   #103
ASU
Member#: 164551
2006 Brotastic STi
Im not running a twinscroll its a singlescroll
Old 04-19-2010, 04:36 PM   #104
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
This is the .70 open, not the divided. What gear was the 4700 in?
ZenMotors is offline   Reply With Quote
Old 04-19-2010, 04:37 PM   #105
crashtke
Member#: 120912
Also curious to know what gear that is in. In 2nd gear that would be pretty good 5th, that would suck, lol.
crashtke is offline   Reply With Quote
Old 04-19-2010, 04:37 PM   #106
ASU
Member#: 164551
2006 Brotastic STi
That was in third gear, he said it should spool a little faster in 4th due to the increased load. Can the headers really move my full boost by 700 rpms I know it had 2inch runners but 700.
Old 04-19-2010, 04:41 PM   #107
06rexwagon
Member#: 114730
9.8@150
Oh, didn't know.
Old 04-19-2010, 04:44 PM   #108
crashtke
Member#: 120912
Depends on a lot of factors. Those headers are more suited to a S364, S366 or something along those lines. Also, depending on the wall thickness you could be losing some heat too. That will effect spool time as well. The S362 I posted had the headers and the up pipe wraped in thermal heat wrap with 2 1/4 inch collector on the header going to a 2.25" up pipe.
Personally I would not want to go any smaller on the turbine side as I would be afraid it would choke off top end. It would be a waste to have cams, intake and heads that promote better top end flow only to choke it off with too small of a turbine housing.
Edit: looked back and it was 2.25" up as well.
Old 04-19-2010, 04:46 PM   #109
ASU
Member#: 164551
2006 Brotastic STi
I agree on that about the cams etc etc. Im thinking the Header is the culprit at this point as well. Ill have a complete dyno sheet hopefully in 10 days for you all
Old 04-19-2010, 04:52 PM   #110
crashtke
Member#: 120912
Trust Clark. He knows his stuff
Old 04-20-2010, 06:22 PM   #111
joebud
Member#: 55089
Just an update, I switched the AMR header with a Perrin. The gate is opening at 4100 rpm in 3rd gear. That is 6-700 rpm sooner with the smaller diameter Perrin header.
Joe
joebud is offline   Reply With Quote
Old 04-20-2010, 06:53 PM   #112
crashtke
Member#: 120912
Nice.
Old 04-21-2010, 12:52 AM   #113
Clark Turner
Member#: 178047
02 WRX STI Spec C
I knew it was the header. Plus. This motor needs to break in. Its got 20 miles on it
C
Clark Turner is online now   Reply With Quote
Old 04-21-2010, 04:32 PM   #114
CatfaceType-R
Member#: 81102
^^nice call, didn't think 700rpm was possible; amazing...was the top end effected?
CatfaceType-R is offline   Reply With Quote
Old 04-21-2010, 04:38 PM   #115
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Probably not by much if any with that sized turbo.
Old 04-21-2010, 05:21 PM   #116
Clark Turner
Member#: 178047
02 WRX STI Spec C
I have a larger turbo then this car. I have had 5 different types of headers on the car. The only ones that will outspool stock manifolds are the Small perrins or the Synic equal. From small to large headers I see no more then 10 to 15 hp lost at redline. Thats a fine trade off for 700 to 800 rpm extra power band. This car did not lose any power. Remember that most of these cars have a 44mm gate blowing to the ground. Once that opens. The headers just dont make a huge difference.
C
Old 04-21-2010, 06:03 PM   #117
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
Had the exact same problem with my car the first time around the weld cracked right down the middle at the collector.
Dipp is offline   Reply With Quote
Old 04-22-2010, 02:41 PM   #118
crashtke
Member#: 120912
What psi was it hitting at 4100 Clark?
Old 04-22-2010, 03:49 PM   #119
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
off topic, What is the size of diameter of the Full-Race headers compared to Perrin and AMR?
juanmedina is online now   Reply With Quote
Old 04-23-2010, 05:04 AM   #120
ASU
Member#: 164551
2006 Brotastic STi
Ill trade 15 to 20 Whp for a wider and more usable power band. Goodjob by goodspeed and clark to get this problem solved I would of never thought it to be the header. Oh well a 1500 dollar mistake on my part.
Old 04-23-2010, 06:13 AM   #121
groff
Member#: 110073
2006 STI swapped WRX
BW S366
Event: Dyno pull
Ambient Temp: 85
Elevation: About 100?
Weather: Humid
Wheels/Tires: 225/45/17
Car: 2005 LGT
Mileage: 1200 on engine
Tuner: Jr
Dyno Info: Dyno Dynamics
Peak HP at RPM: 550whp corrected
Peak Torque at RPM: 475
Baseline hp/tq for a stock on same dyno: unk
Target Boost: 27psi
Target AFR: 12
Fuel: 93
Tranny: 04 STI 6spd
Engine/Power Modifications: 2.5L EJ257 with ACL bearings, stock crank, pauter rods, wiseco 100mms, ported heads, BC valves, springs retainers, BC 272 cams (poopy), dual walbro pumper, DW1100s, custom built 3" FMIC and dp w/ Ecutout, aquamist hfs5 w/ dual pumps and dual 1mm nozzle set up, etc
Software: UTEC
btw, all for sale here
also the motor is for sale here built up with sleeves and better cams
groff is offline   Reply With Quote
Old 04-23-2010, 03:15 PM   #122
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Gear the pull was done in? And turbine wheel diameter and turbine AR?
Old 04-23-2010, 04:10 PM   #123
groff
Member#: 110073
4th gear
Old 04-26-2010, 11:09 AM   #124
ASU
Member#: 164551
2006 Brotastic STi
Im very excited about more and more people running BW setups and the BW hybrids out there. Just proving that you dont have to have BB to get fast spool and awesome power numbers and the best part of it all it the price is 300 to 400 dollars cheaper than there Garret brothern.
Old 04-26-2010, 11:31 AM   #125
Clark Turner
Member#: 178047
02 WRX STI Spec C
Glad you are happy.. Now Put some miles on her and get it broken in. Then we can turn it up.
C
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
