Old 12-15-2010, 07:27 AM   #1251
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
When will the 8374's be available for sale
alcoolaid is offline   Reply With Quote
Old 12-15-2010, 07:52 AM   #1252
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
They have been fs.
methaddict is offline   Reply With Quote
Old 12-15-2010, 08:05 AM   #1253
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by [email protected] View Post
I'm about 99% sure it's the 7670. It fits with room to spare and the 8374 fits with room to spare as well... Just a little less room.. Haha. The pics kinda give you a visual on size of the turbo since several members were concerned about actual size. It's not gigantic as some would think.. Pics don't do it justice.. They have to be the sexiest turbos hands down.
Raffi, Looks like plenty of room diameter wise but they are a bit longer on the hot side with the IWG and a tad longer on the cold side as well because of the BPV. Is the up pipe your 2-1 UP? Seems like it could be positioned slightly more forward in position. Agreed they are sexy! I think the 7670 is in my FSTI's future with my new motor build next spring. How will the availability be come March? Will I need to reserve some thing soon? Do you want to PM me to discuss?
Thanks
Allan
Old 12-15-2010, 09:15 AM   #1254
n2oiroc
Member#: 141952
15 legacy 16 wrx
If you want one anytime soon i would recommend calling and putting money down. I believe im #1 in line for the 8374 with a mid jan ship date. I heard they are nearly sold out and who knows when they will show up after the first batch.
n2oiroc is offline   Reply With Quote
Old 12-15-2010, 01:13 PM   #1255
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
THANK YOU to everyone who stopped by the BW booth at PRI. it was great to meet you guys and show you the EFR technology in person
Originally Posted by Homemade WRX View Post
I do wonder how the brittle titanium-aluminide turbine wheels will handle the percussion and shock waves from antilag and two steps...I really don't want to have to squeeze a bottle to launch on a big turbo.
this turbine wheel material gains strength and ductility as it heats up... it literally gets stronger with hot exhaust gas. As an experiment in the lab, the BW engineers simulated a metal piece shooting through the turbine wheel (similar to a broken piston or a broken valve exiting the engine) and it obviously damaged a blade on the turbine wheel. Then they tested the damaged turbine wheel turbo to see what the loss of efficiency was... amazingly the performance was almost identical to the undamaged turbo. <i do not recommend doing this!!!>
Originally Posted by n2oiroc View Post
i wonder how long it will take before someone starts making a nice billet one to sell like that. i'd probably buy one.
Full-Race has a very innovative billet aluminum CRV cover coming soon
Originally Posted by crashtke View Post
methaddict, what are those bearings comparing? The new ones vs some other turbo or something?
its an EFR bearing vs GT bearing. the internals really tell the story.
GT: plastic bearing cage, stainless balls, metal bearing race
EFR: metal bearing cage plated with silver to prevent galling, ceramic balls, M50 bearing race
im guessing the bearing cartridge on the 8374/9180 vs. a gt35r.
correct. fyi- the gt35R bearing cartridge is also the same as gt30, gt28 and gt25
Originally Posted by methaddict View Post
Regarding specifically with the EFR 8374.. I'm curious to what the differences in power/torque will be throughout the power band, better low to mid end without loosing to much up top? How much more response and spool would there be, minimal or considerably more? You've always stated that in a twin scroll configuration, it likes a larger a/r turbine housing. How would it behave on let's say my motor: 2.5 lit forged sti block 8:5.1, light porting on valve seats, 272 BC cams (not true 272's, maybe more like 260ish duration) which is ok so I don't shift to the right so much.
this is a great question. You are correct that I traditionally like large-sized A/R turbine housings for twinscroll setups, However I learned a lot working with the BW team and turbine efficiency tends to go down slightly with too large A/R becuase you are asking the wheel to flow more than its "sweet spot". As a result the .92 a/r is actually damn near the sweet spot for the mid-highish flow levels, and the 1.05 is the way to max out the turbo for the high flow and high boost setups. For twinscroll setups on a performance application - above 1.05 is too big, and below .92 is too small.
This was really driven home to me when testing a bw prototype turbo last year on my R14 during the modified magazine shootout AND the previous year with yimisport's 08 STI. I did not take their advice to use the .91 and instead I ran the 1.10 a/r based off my initial instincts and experience with the s300sx line mostly on evos and hondas. I was thinking it would be a bit easier on the motor (we had a stock bottom end in the car) however now that ive gone thru data and logs and dynocharts - the .91 a/r was ultimately a much better powerband but because i was rushing to get ready for the race I did not test it until after. we're always learning. the cars would have definitely gone faster had we run the smaller a/r hot side. for this reason i am running an EFR 8374 with .92 a/r on my RB26 next year... and ill lose the complexity, weight and hassle of the external gates
Ultimately the behavior of this turbo on an engine like you highlighted - 2.5L with mild headwork and 264-272 cams (kelfords are my preference) i would lean towards the .92 a/r with internal gates. the subaru VE is not ultra high, and unless its a race car which will live at high boost and high rpm, im going to want the quicker response.
Originally Posted by Dutch Devotion View Post
The EFR76 is most likely the lucky turbo to be mounted on my EZ30R next summer :-) Will have a relaxed life pumping around 750Nm and 500 horses; however, the top spool caracteristics is what attracks me most. And the internal gate, while 'll have to fabricate all parts myself, this just saves a lot of time and cursing
that would be a fantastic setup, incredible powerband with massive torque and spoolup would be a rush. Sorry we do not have plans to mfg a manifold for the ez30 at this time
I'd like to see the engine dyno graph for the Cosworth testing with the 8374. I'll have to give them a call then next week.
that is not the 8374 from what i can see - looks like an efr 6258 or 6758 .64 a/r
Originally Posted by manitou View Post
Raffi,
Is that the 7670 or the 8374 in the engine bay?
Thanks
7670
7670. the 8374 has a bigger compressor cover.
correct
this is our singlescroll T3 up pipe, which bolts to a 2bolt stock header or any of the aftermarket headers (not counting full-race or any 3 bolt lower manifolds). can not position the turbo more forward - the intake manifold is there. btw i see your screen name do you ride mt. bikes?
the first shipment of singlescroll T3 EFR turbos heads to Full-Race friday Dec 17th. The twinscroll EFR turbos will ship to Full-Race the last day in January
Full-Race Geoff is offline   Reply With Quote
Old 12-15-2010, 01:55 PM   #1256
manitou
Member#: 193757
2006 XTI Limited
I do realize that there will be an intake manifold there but I was wondering about the position of this turbo because they are longer front to back it looks like they could rotate counter clockwise and move forward and not interfere with the intake. Why yes I do mtn. bike as much as I can. From MTBR.com? You ride as well? It's ski time now and I've got some big new Wagner's to ride!!
Old 12-15-2010, 01:58 PM   #1257
manitou
Member#: 193757
2006 XTI Limited
I want the 7670 T4 .92 AR TS. Will these be on the late January shipment? What do you guys need to reserve? You can PM me.
Thanks
Old 12-15-2010, 02:02 PM   #1258
manitou
Member#: 193757
2006 XTI Limited
That's probably the 7670 which uses the medium sized type "B" compressor cover with a 3.5" inlet and 2" outlet. The 8374 uses the larger type "C" which has a different style ported shroud with a 4" inlet and 2.5" outlet w/ integrated Vband option, bottom one in the MotoIQ pics.
Thanks MA! I figured as much but wanted to be sure what I was looking at. The 7670 T4 .92AR TS should not be any bigger overall maybe a bit taller top to bottom. Would you not concur?
Old 12-15-2010, 02:19 PM   #1259
sburck
Member#: 191491
2011 Forester
Any idea when you will have complete turbo kits with the efr's and ts up pipes without wastgates or flanges?
sburck is offline   Reply With Quote
Old 12-15-2010, 02:32 PM   #1260
Member#: 264595
raffi@full-race is offline   Reply With Quote
Old 12-15-2010, 02:33 PM   #1261
Member#: 264595
Old 12-15-2010, 02:37 PM   #1262
Member#: 264595
N2oiroc, if we were having serial numbers on them, yours would be #0001..haha.. You were the very first in line. Nasioc is gonna have to make a EFR forum pretty soon for the suby's with transplants..
Old 12-15-2010, 02:42 PM   #1263
Member#: 264595
Once again Mr. Full-race himself helps me address all questions for the nasioc'ians? Haha.
Thanks bossman, I've got a "worlds best boss" coffee mug under the tree for you..
Old 12-15-2010, 03:17 PM   #1264
sburck
Member#: 191491
2011 Forester
emailed you
Old 12-15-2010, 04:10 PM   #1265
n2oiroc
Member#: 141952
15 legacy 16 wrx
So my 8374 with the 1.05 t/s housing is late jan? I have to wait until feb to spin the wheels and make vroom vroom noises?
Old 12-15-2010, 07:55 PM   #1266
Member#: 264595
Well, at this point, be lucky you have one reserved!! Haha.
Old 12-15-2010, 08:11 PM   #1267
Adrenalin Rush
Member#: 76729
2004 WRB WRX 2.7L
S400SX3, PPG, AEM, 701whp
Time to clear up some rumors, I have been receiving inquires about these from customers that are being told that all of the EFR units are spoken for, the EFR turbos are not sold out!!! Please remember that just because one vendor has presold all of their units, this does not mean they are all gone!
These units are set to arrive this week and are currently available:
179150, EFR6258, .64 A/R T2 W/G
179388, EFR6758, .64 A/R T2 W/G
179351, EFR7670, .83 A/R T3 W/G
179258, EFR8374, .83 A/R T3 W/G
The twin scroll units will be arriving late January but I would order sooner than later. They are selling fast as well. Please do not think that they are all gone!!!
Those interested can find more information, including pricing here
Adrenalin Rush is offline   Reply With Quote
Old 12-15-2010, 08:29 PM   #1268
Member#: 264595
Originally Posted by sburck
emailed you
Thanks for the email. Keep my contact Info and feel free to call or email me with any questions, comments or concerns.
We've still got availability of every model EFR, T25, T3, and T4, just shoot me an email for specifics.
Old 12-15-2010, 08:57 PM   #1269
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
good choice - the 7670 .92 a/r IMHO is the optimal match on a street EJ25. The twinscroll EFRs will arrive early february, it is not possible to get one earlier
The EFR turbokits are in production right now. ordering the manifold with no wastegate ports/flanges will save $
twinscroll turbos are tentatively scheduled to leave BW the last day in january, arriving at Full-Race early february.
Old 12-15-2010, 09:10 PM   #1270
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Hey Geoff, I'm curious what kind of "location" the 7670 TS with your exhaust manifold will be? Raffi was telling me the EFRs won't fit your old TS manifold so I'm assuming it's not the same as a rotated kit? Would you happen to have any pictures of a 7670 TS in a subaru?
EtoS is offline   Reply With Quote
Old 12-15-2010, 09:32 PM   #1271
Member#: 264595
Emmanuel, it's not that the EFR won't fit the manifold, it's that the internally gated model require a specific downpipe. They fit the manifold just fine, but since the EFR that you are getting is internal wastegate, the turbine housing is elongated which means we had to fabricate a new version for it.
Old 12-15-2010, 09:33 PM   #1272
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
The external wastegate EFR turbos WILL fit our gen2 twinscroll kits - in fact the EFR turbine housing fitments were developed around these twinscroll turbo kits (many many hours spent on that!!). The main difference is that the EFR kit can be ordered with or without wastegate ports - and that requires a different downpipe to accomodate the high flow IWG
The EFR turbos will NOT fit our old gen1 twinscroll kits.
i do have photos of all the twinscroll EFRs in a subaru, id be happy to post them up tomorrow morning for you
edit: i just checked, we've got pics of the 7670, 8374 IWG, 8374 EWG and 9180 EWG all in twinscroll and singlescroll
Old 12-15-2010, 10:19 PM   #1273
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
So piping for the intake should be no different then a non EFR turbo right? I'm in the process of trying to figure out the intake side of my build now. I want a reverse intake that will keep AC, PS and ALT. I'm trying to figure out if I should have the piping like how Yimi did it for their 08 or have the piping go straight through the top rear of the engine to the drivers side front and come out the pass side front. Any opinions on this?
Old 12-15-2010, 11:23 PM   #1274
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
correct. flipping the intake manifold to acheive the shortest possible charge piping route is smart, and our Full-Race charge piping is by far the easiest way to do this - particularly on the cold side.
its pretty easy to route the piping under the intake manifold OR how yimi did on their S300SX (soon to be EFR), both routings are fine:
Old 12-15-2010, 11:34 PM   #1275
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
How involved will Yimis setup be? Do you offer that? Another option I have requires unwrapping the engine harness and some other things. Will I have to do that as well?
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
