Old 05-30-2002, 10:37 PM   #1
Jiz311
Member#: 19351
1993 Impreza WRX
Unhappy Leaking fluids...
I have just purchased my '93 and this is the first time I have worked on this type of engine. I have put on minor mods and street race a lot. However, when I do run after run, eventually I begin to leak what I think is power steering fluid. It leaks onto the pipning beneath it and smokes until it is all burned off. Any ideas on what this may be?
Jiz311 is offline   Reply With Quote
Old 05-30-2002, 11:30 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If it is indeed power steering fluid, it couldn't hurt to power flush and replace the fluid with fresh automatic transmission fluid (*NOT* power steering fluid... Subaru is odd like that). Hopefully, a flush/fill has been done in the past, but hey, you never know ). Also, check the banjo bolt at the bottom of the pump and the compression nuts on the power steering rack itself (it is located inside of the engine crossmember right between the front wheels). There should be four of them all told IIRC. Make sure they are tight and/or not leaking. I had a problem with air getting into my power steering system due to those compression nuts being loose, and it caused a boil-over of my fluid (air expands ALOT more than than PS fluid and that stuff gets HOT).
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.subaruwrxparts.com
Old 05-31-2002, 12:20 AM   #3
Jiz311
Member#: 19351
1993 Impreza WRX
Thank yuou very much for your help. I'll check it out tonight
Old 05-31-2002, 09:36 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
definately..! check the fittings....
they are known to come loose at times..
i have had many, many ps issues w/my rally car...
(95 L....)
and now i'm running Redline ATF
http://www.redlineoil.com
and the air foaming/boiling over issues seem to have been resolved...
good luck to you!
cheers!
Jamie
www.subiegalracing.com
www.subiegal.com
2008 STI AC pulley, smoking and leaking fluid. Alfaneggio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-06-2009 07:26 PM
installed springs, now the car is leaking fluid DanmanWRX Brakes, Steering & Suspension 3 10-29-2006 11:44 PM
wastgate leaking fluid? raglan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-03-2005 02:44 AM
car leaking fluid? awdaddict172 Newbies & FAQs 3 07-25-2004 03:42 PM
Leaking Fluid? worried. 2.5RSMatt Normally Aspirated Powertrain 8 04-17-2004 08:13 AM
