Old 03-13-2010, 09:58 AM   #1
AVANTI R5
Member#: 73805
Default Nissan’s Driveshaft Campaign Raises Questions
A common safety problem among three automakers sees three different solutions. No wonder consumers are confused
Nissan is conducting what it calls a “Voluntary Service Campaign” on a 9,000 four-wheel-drive Armada, Frontier, Pathfinder, Titans, Xterra and Infiniti QX56 2010 models to inspect the front driveshaft.
This is not a safety recall but a service action of the kind that has been criticized by safety advocates. (Click Here.)
Some of these front driveshafts made by Dana have a yoke manufactured out of specification, which may cause cracks in the critical connection between the yoke, which holds a universal joint, and the tubular shaft.
Nissan maintains that the vehicles are “safe to drive.”
“Even in the event the front propeller shaft was to fail, the vehicle would continue to operate in the normal two-wheel-drive mode. A loud noise would be heard but control of the vehicle would not be affected,” Nissan said in a statement, after we requested comment.
That assertion may or may not be accurate, as a front driveshaft failure could lead to a pole-vaulting effect if it fails, where the leading edge of the now detached shaft digs into the road as the vehicle moves forward.
Nissan is notifying owners of all potentially affected vehicles. They will be told to bring their vehicles to an authorized Nissan dealer. The dealer will inspect the front driveshaft, and replace it - if cracks are found where the yoke for the universal joint is connected to the shaft
This differs from the Toyota approach to the same problem. Toyota immediately instituted a safety recall on 2010 model Tacoma trucks that use similar Dana driveshafts after being informed in February by the component supplier of the cracking defect, which resulted from a faulty manufacturing process.
Ford Motor Company, which also uses the same potentially defective Dana driveshafts on Escape, Mercury Mariner and Mazda Tribute SUVs, has concluded that no action is needed on its vehicles.
So three automakers using the same parts have taken three different approaches to a potential safety defect. Small wonder then that consumers are confused about safety regulations and their effectiveness.
This was one of the core issues that emerged during Congressional hearings about the Toyota pedal entrapment and unintended acceleration recalls and the National Highway Traffic Safety Administration’s relationship with automakers, which allows for negotiation about how many vehicles will be recalled or whether a service action will do, or if anything is done at all.
NHTSA is under attack by consumer organizations and safety advocates for its inaction and closing of multiple Toyota investigations without recalls, which, as we now know, ultimately, resulted in serious injuries and deaths on Toyota vehicles.
Recalls were finally ordered after adverse publicity about more than 60, alleged, deaths occurred because of safety related defects. Moreover, it took a visit to Japan by the former acting administrator of NHTSA to force a Toyota recall, since Toyota’s American executives had no power to do so.
No surprise then that NHTSA has been called a “lapdog” for the auto industry by critics. In the 38 years since NHTSA has had recall authority, not once has the agency ordered a recall from an automaker.
NHTSA says its negotiated voluntary approach with automakers saves time and legal fees, assertions that were met with considerable skepticism yesterday at a Congressional oversight hearing on its effectiveness as a safety watchdog. (Click Here.)
http://www.thedetroitbureau.com/2010...k-driveshafts/
Old 03-13-2010, 10:24 PM   #2
JuggernautTCW
Member#: 169223
more than 60 deaths??!?!?!?!?
JuggernautTCW is offline   Reply With Quote
Old 03-15-2010, 09:24 AM   #3
registering
Member#: 89332
2007 Miata
They're "alleged" deaths -- they might not be dead yet, they're still investigating, looking for them...
registering is offline   Reply With Quote
Old 03-15-2010, 10:24 AM   #4
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
Mythbusters proved this doesn't actually happen.
Wonky understanding of physics is wonky.
WhiteKnightSTi is offline   Reply With Quote
Old 03-15-2010, 01:54 PM   #5
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
So 3 different parts made by the same supplier for 3 different manufacturers of which probably have multiple versions of the shafts are all the same now?
Only in Japan: Nissan Note Ad Campaign AVANTI R5 Non-Subaru News & Rumors 1 02-14-2008 02:59 PM
Scions Ad Campaign in Questionable Taste? Chuck Jones Non-Subaru News & Rumors 0 07-19-2007 10:25 PM
Army Recruitment of Autistic Teen Raises Questions Janq Off-Topic 33 05-12-2006 01:29 PM
Dyno Results raise questions toke513 Factory 2.0L Turbo Powertrain 5 10-29-2005 09:04 PM
campaign finance question.... bunot Political Playground 7 02-23-2004 02:17 AM
Message Board Statistics All times are GMT -4. The time now is 07:23 PM.
