Old 03-13-2010, 11:02 AM   #1
olivertwisto
Member#: 224318
1998 WRX
snow white
Default Getting rid of the Purge Control Solenoid
I busted the purge control solenoid on my scoob a while back, and have been getting an associated CEL ever since. The obvious answer is to just replace is, but $100 for something that doesn't make the car go faster, stop better or corner more impressively seems like a waste of my tuning dollars. Does anyone have an idea on how to delete the thing while keeping the evaporative emissions system CEL from reappearing, short of deleting the code?
Thanks in advance!
olivertwisto is offline   Reply With Quote
Old 03-13-2010, 03:11 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
remove and delete.. simple and easy
sidewayz is offline   Reply With Quote
Old 03-13-2010, 06:10 PM   #3
WeldingHank
Member#: 98645
2002 WRX Wagon
+1 remove valve and delete associated codes.
WeldingHank is offline   Reply With Quote
Old 03-13-2010, 08:06 PM   #4
robo1040
Member#: 231114
2011 WRX sedan
remove and delete, then watch the code come back. if you remove the purge valve, they light will come right back on once the evap system runs any kind of test and/or trys to purge the system. the only way to bypass it may be for a tuner to do so.
i bought my purge valve used from a member on here, 20 bucks.
robo1040 is offline   Reply With Quote
Old 03-13-2010, 10:58 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Delete the code in the ecu, byway of opensource or whatever.
scby rex is offline   Reply With Quote
Old 03-14-2010, 03:03 AM   #6
arghx7
Member#: 232940
Evap systems are VERY complicated and the OEM engineers build in multiple self-diagnostic tests to verify that the system is working. This is because a large portion of HC emissions are produced by gasoline vapors. It is one of the main reasons why returnless fuel systems exist, and why fuel pumps are duty controlled.
Eliminate the code with a reflash. You can't just pull it out on an OBD II car.
arghx7 is offline   Reply With Quote
Old 07-15-2010, 03:29 PM   #7
Bizko1288
Member#: 151260
2011 BMW 135i
__________
So who has done this with success?
Bizko1288 is offline   Reply With Quote
Old 07-15-2010, 06:09 PM   #8
sidewayz
Member#: 5810
2001 S366 2.5RS
I've done it about 2 dozen times and havent had isues
Old 07-17-2010, 12:24 AM   #9
Bizko1288
Member#: 151260
2011 BMW 135i
__________
2 dozen times? I am assuming you do it temporarily and then hook it all back up.
But, maybe not. So I am going to try this tomorrow... except permanently. This system is definitely the source of my vacuum leak and I don't have the money/motivation to fix it. I hate all the vacuum lines clogging up my engine bay anyways.
I'll update this thread with my results over time.
Old 07-19-2010, 05:20 PM   #10
wickedblk02
Member#: 237875
2002 impreza
crazy blackw/blue init
Is the p.c.s that cluster underneath the front of the intake mani.I was checkin my car over the other day and the damn things not even conected well the vac lines any way
wickedblk02 is offline   Reply With Quote
Old 07-19-2010, 05:45 PM   #11
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Yea that's the one. Has a little plastic "F" that lines hook up to. The ECU won't throw codes at you if the valve is plugged into the harness and the lines capped off.
Psychoreo is offline   Reply With Quote
Old 07-23-2010, 01:20 AM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
Yes 2 dozen. I own a shop and do engine builds all day long (can't say shop name for fear of Nazi mods)
Remove the UFO and purge solenoid garbage and just delete the code. No one will ever know :P
Old 06-17-2011, 08:42 PM   #13
alpinestarz067
Member#: 253415
04 WRX Wagon
blue
what do you do with the vaccum lines? cap them off?
alpinestarz067 is offline   Reply With Quote
Old 06-17-2011, 08:43 PM   #14
alpinestarz067
Member#: 253415
04 WRX Wagon
blue
I have the jdm spec c so I only have one vaccum nipple. or do I just connect a vac line from the t.i.p to the intake mani?
what car to get if u had to get rid of the sti? SilverCWestWRX General Community 53 01-13-2005 01:04 PM
Why are alot of people getting rid of the Eibach ProKit?? The_Triton General Community 3 10-16-2003 02:20 AM
Anybody want to get rid of their stock boost solenoid? sherifx Mid West Subaru Owners Club Forum -- MWSOC 3 10-24-2002 09:19 PM
What does the purge control solenoid do? MadMax Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-27-2001 09:26 PM
