Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 05-31-2002, 08:51 AM   #1
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Default Is stock WRX fuel pump good upgrade for RS?
I'm finally upgrading the fuel pump in the wrx with a nice walbro unit...
Can I put the oem wrx pump in the RS?
FWIW, the RS is tec2'd, and will be turboed when shiv finally send me the kit... shoulda mailed yesterday
Austin is offline   Reply With Quote
Old 05-31-2002, 10:12 AM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I would recommend against trying it... Just spend the $100 on getting the Walbro for the RS.
kastle is offline   Reply With Quote
Old 05-31-2002, 01:08 PM   #3
8Complex
Member#: 922
04 FXT
Red
Hmmm... actually, I don't see a reason why it shouldn't be done. It's already a turbo pump, so it'll be capable of higher pressures, though I question the flow as it's 2.0 versus a 2.5.
It'll certainly be quieter then the Walbro pump, that is for sure.
Old 05-31-2002, 04:38 PM   #4
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
kastle - Why are you saying don't even try to put it in?
Old 05-31-2002, 05:43 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I figured that the WRX guys are all replacing it as well, so I was guessing it wasn't as strong as one would need....
Just my .02
Old 05-31-2002, 07:33 PM   #6
christoph1371
Member#: 1090
After being schooled in fluid dynamics by the local 'kooter' the stock wrx pump is fine. In some applications,it is actually better than the walboro.
It really depends on what injectors you are/plan on running. Which ones are you planning?
christoph1371 is offline   Reply With Quote
Old 05-31-2002, 08:51 PM   #7
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Both the wrx and the rs have 550cc low imp squirters. I'll probably end up putting the wrx pump in there and using it for at least a while. If I run out of fuel in the RS, then I'll buy a bigger Walbro.
Old 06-01-2002, 01:49 AM   #8
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
Hmm, wonder if my 1.8 could use it to any effect...
Old 06-01-2002, 03:44 PM   #9
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Sure Kosta, why not. I have an Rx7 TT fuel pump in mine and it helped quite a bit.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 06-02-2002, 02:09 AM   #10
DoinkMobb
Member#: 3787
2008 Dandyboy-mobile
Now w/ more rainbows!
But then again subachad, you're turbo'd and Kosta isn't. What would a better fuel pump do for a stock 1.8L engine anyway?
DoinkMobb is offline   Reply With Quote
Old 06-02-2002, 03:51 AM   #11
subachad
Member#: 8488
Teal
Well, unless it's a heavily modified 1.8... waste fuel, pollute the air more, foul plugs...
FS!!! Stock 05 WRX Fuel Pump, good condition necratis Engine/Power/Exhaust 0 09-18-2009 05:37 PM
FS: Stock WRX top feeds, Stock WRX fuel pump Subaru Tripple 5 Engine/Power/Exhaust 8 09-16-2009 10:08 PM
Fuel pump/injector upgrades for my impreza "L-T" farrell Normally Aspirated with bolt-on Forced Induction Powertrain 11 01-09-2005 04:09 PM
TRADE: stock WRX fuel pump for 2.5RS fuel pump. Riverside CA RyansJDMgc8 Private 'For Sale' Classifieds 0 07-05-2004 06:47 PM
The stock wrx fuel pump is a 190 lph yes? Blue02WRX Factory 2.0L Turbo Powertrain 2 10-28-2002 09:48 AM
Message Board Statistics All times are GMT -4. The time now is 01:19 AM.
