#1 |
Member#: 15359
I'm a little late to the game this year. I just returned from a seven month deployment (active duty Navy) but have a few things planned for the car.
Before I left on deployment last August Vern and I pulled the motor out the car so he could dissemble it and check it. Everything looked good, so it's going back together with a new set of bearings and rings. For the car, I have a few minor things planned. No pictures yet, but I'll try and get some up this week. - New rear wing from Kognition (72") - Cool Suit (Christmas present from my wife )- Removal of the passenger seat - New front brake setup (details to follow) - Minor changes to the brake ducting and backing plates. - Lexan front windshield (tired of replacing glass every 2 weekends) - Water cooled turbo First project was to do some reconditioning of the trailer. Replaced all 4 leaf springs, equalizers, and shackles. Also replaced both driver side wheel bearings. Big thanks to Vern for the help. I made some progress on the above last weekend. Battery is moved from the trunk to the passenger side floor to allow for the wing support. Seat is out, Cool suit is installed, and the engine bay ready to receive the engine. Also fabricated the new brake backing plates. Upgraded the tow vehicle as well. ![]() -Duncan
#2 |
Member#: 98961
Vehicle:2003 WRX Black |
What was breaking the glass? Debris? Chassis flex?
#3 |
Member#: 15359
Just debris from rocks thrown up by sticky tires.
-Duncan |
#4 |
Member#: 15359
Snapped some pictures of the smaller projects.
Cool suit and battery in their new location. Just need to shorten the positive cable and add a fuse. ![]() Part of the ducting to ensure air gets into the radiator and doesn't flow around. They're aluminum with rubber piping so they don't damage the heat exchangers. ![]() ![]() Brake backing plates. These match up to the quantum and RCE adapters already on the knuckle and ensure that air doesn't simply run out the back of the hat. ![]() Water misting setup in its new location ![]() Re-did the heat protection around the turbo. ![]() -Duncan |
#5 |
Member#: 84181
NESIC
Vehicle:NASA #530 PTC |
I keep reading your updates as Im building my car and I keep wondering what the hell you do for a living to have so much coin
![]() Good job Duncan |
#6 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
#7 |
Member#: 15359
Any recommendations on a good fuse for the battery? I was using a car stereo fuse since I was in a hurry last time but I have a feeling there's something more appropriate.
-Duncan |
#8 |
Member#: 92582
Vehicle:* |
Everywhere I read to use an Audio fuse, something like this holder and the fuse to go with it...http://www.bestbuy.com/site/DB+Link+...=1218010850573
#9 | |
Member#: 84181
NESIC
![]() Anyway - I've always used the audio battery fuses myself as they tend to have a good enclosure to protect it. |
#10 |
Member#: 156702
Vehicle:2004 Impreza WRX Aspen White 52E |
Dunk, Its Natchez. Good to hear your back from Deployment, Hope this summer I get a chance to eyef*ck your car like I always end up doing when its at Kienens.
Good Luck with the Build/Rebuild. |
#11 |
Member#: 102091
Vehicle:1994 1.8l Impreza L Open Class Build w/110hp |
Unless I learn something new, I'm using one of these in my rally car. They come in all different amp ratings.
http://www.defender.com/product.jsp?...25431&id=50780 ![]() |
#12 |
NASIOC Manufacturer
Member#: 95419
E. Canada
We use ETA units at MSI ... as do most motorsport shops I believe.
http://www.e-t-a.com/us_aerospace.html -mark |
#13 |
Member#: 106470
NWIC
Vehicle:2004 STI ICSCC #9 www.ClintonRacing.com |
#14 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
#15 |
Member#: 15359
Thanks for the suggestions. I like the look of that 30amp breaker.
-Duncan |
#16 | |
Member#: 102091
The starter motor is the highest draw. But, I haven't figured out how many amps it actually pulls. MSI, what amp breakers do you use at the battery? |
#17 |
Member#: 191557
TXIC
Vehicle:2004 WRX Wagon WRB not so minty fresh |
I'd use the Circuit Breaker shown above... contact www.darvex.com or look on ebay for "bag-boy" which is the same guy. The guy's name is Trail, he is VERY enthusiast friendly.
Rob edit: http://stores.ebay.com/Bag-Boy-Home-...34Q2ec0Q2em322 |
#18 |
Member#: 101091
NWIC
#19 |
Member#: 122980
South East
#20 |
Member#: 98961
I use an 80 amp on my entire car so, the starter isn't drawing more than 80 amps (or starting is such a short amount of time it's not getting hot). I was surprised I wasn't popping the 80 amper. I was assuming I'd need 100+ amps. If I was buying something specifically for this, I'd probably put a 120 amp or even a 150 amp breaker on it. You're just trying to prevent melting the battery cable not protect the whole system. The rest of the car has it's own fuses.
Are the breakers slow-blow or instant? Slow blow means you can go over the rating for a short time (like cranking) and not blow the fuse. Non-slow blow will pop as soon as you go over the rating. http://www.defender.com/product.jsp?...5431&id=590019 I like this one. |
#21 |
Member#: 15359
Are you using a car audio fuse holder and fuse?
-Duncan |
#22 |
Member#: 98961
Yeah, car audio fuse. I've used several different styles but, the last fuse was one of those transparent inline fuses. When I had the really small battery in the box, I had a larger bolt down fuse holder. It would accept fuses up to 150 amps or so. When I switched to the larger battery, I lost the room and changed to the inline 80.
I kept the fuse in the battery box. You want it as close to the battery as possible. |
#23 | |
Member#: 78952
Vehicle:2005 WRX CGM |
#24 |
Member#: 15359
Motor's going back in the car on Monday. Anybody have a good source for Deka batteries and the required terminal adapters?
thanks, Duncan |
#25 |
Member#: 15359
Got another project knocked out today. I removed the fans late last year as an experiment to see whether it would allow more air through the system. Because I had designed the inlet to work with the fan it didn't quite line up perfectly with the pipe I replaced it with. I corrected that today, but replacing the inlets with new pieces that slot into the duct.
![]() As you can see, the two pieces now fit perfectly together. ![]() I also made these little pieces. They bolt underneath the ABS sensor and make sure all the air from the quantum duct actually makes it into the rotor. With the design as delivered quite a bit of air can escape out the back of the duct. ![]() And this picture is for Clint at TIC ![]() Tomorrow afternoon I'm going to finish up the radiator inlet pieces. I'm running a 1/2 marathon in the morning so wish me luck. -Duncan |
| Thread Tools | |
| Display Modes | |
| The Winter Tire thread- all winter tire questions go here !!! | Luke@tirerack | Tire & Wheel | 3485 | 04-02-2013 07:24 AM |
| Official 2010 MWSOC Shootout Thread - May 15th, 2010 | jennspgt | Mid West Subaru Owners Club Forum -- MWSOC | 335 | 05-17-2010 02:23 AM |
| FR: Accomodations for 2010 Winter Olympics | Doraemon76 | VIC Private Classifieds | 1 | 05-09-2009 05:10 PM |
