Old 03-15-2010, 02:48 PM   #1
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Default Question on Air Bag Light with After market seats
Im installing a set of seats this weekend.
I'm giving my stock seats to a friend, he will not be installing them in a suby so he has no need for the air bag harness. I was just wondering if it would keep the light off if I cut the wiring on the seat leaving the clip installed on the airbag sensor.
Cards2323 is offline   Reply With Quote
Old 03-15-2010, 04:11 PM   #2
Wannascooby
Member#: 112992
2006 WRX TR
Crystal Gray
That's a good question, but I don't think so. If I can remember correctly try a 10ohm resistor and plug it into the holes. That will keep the light off!
Wannascooby is offline   Reply With Quote
Old 03-15-2010, 04:12 PM   #3
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Just wire in a resistor. A search will reveal the proper size. Couple cents at RS.
trex616 is offline   Reply With Quote
Old 03-15-2010, 04:16 PM   #4
PSM_02_WRX
Member#: 197108
2003 Ford Mustang GT
Yes, its a 3.3 Resistor.
PSM_02_WRX is offline   Reply With Quote
Old 03-15-2010, 04:16 PM   #5
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Well I've seen anywhere from 2.0 to 3.3, I have enough 10 ohm resistors(5 on each side) to run par to make 2.0 ohm by 1/4 watt.
I was just wondering if leaving the clip in would work also....
Old 03-15-2010, 04:19 PM   #6
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
I would doubt it, its just a continuation of the same wires with the same missing signal.
Old 03-15-2010, 04:19 PM   #7
TRooper
Member#: 62422
2006 Lotus Elise-
1.8L of Fury!!
I believe it is 3.3Ω, but a 3Ω resistor will also work. Install like this and secure with electrical tape.
TRooper is offline   Reply With Quote
Old 03-15-2010, 07:13 PM   #8
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Ever hear of search?
Anyways, your question has already been anwered, 3.3ohm resistor, but anything from 3-4 technically works...even combining a 1.5 and a 2ohm to make it work.
snowflowmfg is offline   Reply With Quote
Old 03-15-2010, 08:11 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
The reason this would not work is that the 2 ohms the airbag control module must see is not really dependent on the harness; it is dependent on the airbag inflator.
The inflator has either one or two (depending on type) igniters. These igniters work similar to a fuse. They have a filament that is very thin and give a specific resistance when a certain predetermined current is passed thru it. If enough current is passed through it, it will burn out and ignite propellant in the process. After that it will show infinite resistance because the filament is broken and the circuit is open. The airbag control module then knows that the bag has been deployed (or removed or otherwise not operational) and it will trigger a light.
Old 03-15-2010, 08:12 PM   #10
kpluiten
Member#: 120273
06 WRBWRXWGN
3.3 may work, but the industry standard (what the airbag control module is programmed to look for is 2.0 0.2 ohms.
Old 03-15-2010, 08:30 PM   #11
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Did you ever learn how to read???
Where in my question did I ask what resistor to use. I know its been said a million times which is why I didnt ask. What I DID ASK was if i could just cut the harness and use that....
Old 03-15-2010, 09:09 PM   #12
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Ooops, That's true. Maybe I should take more English courses.
I'm just so used to seeing a ton of threads regarding what resistor to use.
Old 03-15-2010, 09:33 PM   #13
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
^^All good haha...I just took that personally since I def. search before posting questions that have been covered.
I retract my "learn how to read" question
Old 03-20-2010, 07:12 PM   #14
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Well I just put my seats in. I used 4 10 ohm by 1/4 ressistors parralell. It comes out to a 2.5...
Worked like a charm
Question : Air Bag Light Fix? xwtfbrendan Interior & Exterior Modification 6 09-23-2008 07:07 PM
Question on air bag light resistor fix brandonl Interior & Exterior Modification 1 06-24-2008 07:29 PM
After market seat install air bag warning light Kastley85891 Electrical & Lighting 1 12-24-2007 12:26 AM
Air bag light come on after i disconnected it from the clock pod hornyturbo Electrical & Lighting 2 10-23-2006 08:46 PM
Help! Deleted Seat Air Bags & used 3.3 Ohm Resistors & getting Air Bag Light 2.2gotboost Electrical & Lighting 3 02-19-2004 10:36 AM
