Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-16-2010, 12:11 AM   #1
deepcj7
Member#: 237538
05 WRX
SILVER
Default Connector Help
Does anybody else have a problem with their Accessport v2 plug not being able to stay connected when driving the car due to road bumps and such. Driving down a smooth road is enough to make the Accessport reboot about every minute. The OBD connector doesn't fall out but the connection is not tight. What are you guys doing to make this a tight connection? Thanks
deepcj7 is offline   Reply With Quote
Old 03-16-2010, 07:45 AM   #2
freshsti
Member#: 90099
2005 ewg gt52 sti
cgm
I have a similiar problem..I put the wire on the steering column with a little bit of tension..seems to work
freshsti is offline   Reply With Quote
Old 03-18-2010, 12:52 AM   #3
deepcj7
Member#: 237538
05 WRX
SILVER
thanks
Old 03-18-2010, 02:04 PM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
try bending the metal piece of the dongle slightly see if that helps
ProdriveDreams is offline   Reply With Quote
Old 03-18-2010, 11:37 PM   #5
deepcj7
Member#: 237538
05 WRX
SILVER
dongle is the big connector to obd plug?
Old 03-20-2010, 01:43 AM   #6
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
correct
Old 03-20-2010, 03:11 PM   #7
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
pop the cars obd connector out of the metal bracket that holds it facing downward. lay the cars connector sideways inside that bracket. it kind of locks itself in pretty good. plug the accessport in . it wont come out that way. its hard to explain. take a look to see what i mean. i have mine that way and its out of the way.
424wrx is offline   Reply With Quote
connector help domestic_abuser Built Motor Discussion 24 02-05-2008 10:17 PM
AP V2 OBDII connector help.... 325boi Southern California Impreza Club Forum -- SCIC 7 06-02-2007 05:52 PM
cobb accessport ODB2 connector HELP in NJ burrito007 Engine Management & Tuning 7 12-30-2004 07:07 PM
Factory Connector Help ImpreziveWRX Southern California Impreza Club Forum -- SCIC 0 07-02-2002 12:41 PM
boost gauge T-connector, help! lstepnio South East Region Forum 1 06-06-2002 03:52 PM
