Old 03-16-2010, 07:00 PM   #1
riderome
Member#: 210603
2005 STI
Default realtime economy map
So I flashed an economy map into realtime over my stage 2 tune to see a difference in gas mileage. I don't really notice a difference and am driving at full force grandma style. Is this due to the fact that the economy map is not the main map/?
riderome is offline   Reply With Quote
Old 03-16-2010, 07:55 PM   #2
subarulz!
Member#: 99061
16 WRX
CWP
Have you done a full tank or two to get the actual calculations? It's only going to be a few MPG difference if that and that's too small a difference to tell by looking at the mileage and the gauge. I didn't notice much on my 02 either but the slight difference is there. I just gave up on it because it wasn't worth driving like that all the time.
subarulz! is offline   Reply With Quote
Old 03-16-2010, 08:07 PM   #3
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
in economy mode at stage 2 in my bugeye wagon, I was only seeing 1mpg better than if i just drove as if i was in economy mode on the regular stage 2 map (shift at lowest rpm possible, accelerate painfully slow, etc.). To me, it just wasn't worth the hassle of switching back and forth. I just stopped switching and started driving nicer when needed. Like i said, i got like 20-30 less miles per tank. Now, if i were to go cross country, i would probably switch maps, as this 20-30 miles would start to add up to some decent dollars. On a side note, I think that a protuned economy map will show better results...just my opinion though.
amalgrover is offline   Reply With Quote
Old 03-16-2010, 10:28 PM   #4
van_dutch
Member#: 198633
2004 WRX
Economy map limits your boost. Off boost performance is unchanged. If you stay out of boost all the time, it will not make a measurable difference.
van_dutch is offline   Reply With Quote
Old 03-17-2010, 01:17 AM   #5
riderome
Member#: 210603
2005 STI
Yea I couldnt drive like that as well and just reset the ecu to wipe out the economy map. The difference I saw was tiny about a few mpgs, definately not worth it. Those times when the **** box civics piss you off....you need that boost.
Old 03-17-2010, 02:32 AM   #6
projectpat817
Member#: 50752
2006 STi
Default Re: realtime economy map
I've been running the economy map for the past month and I've gotten, at best 270 miles per tank. This is while driving and not boosting at all, and mostly highway.
Before I was driving mostly city and a little highway and I would get about 230 per tank.
I'm currently running the 91 oct map so I'm logging to see what the difference is, still trying not to boost. Right now I'm at about half a tank at 147 miles.
Next fill I plan to run the same 91 oct map while boosting and driving normally. I'll let you know it goes!
Anyone else see improved gas mileage?
projectpat817 is offline   Reply With Quote
Old 03-17-2010, 08:45 AM   #7
amalgrover
Member#: 183480
2009 Forester XT
like i said, i only saw about a 1mpg increase in my city and a 2mpg increase in my highway mpg. I was getting like 23 city at stage 2 driving VERY easily, and with economy map i would get like 24mpg city. Highway i was getting 28mpg in stage 2 with cruise control set at a constant 60mph, and in economy i was getting like 30mpg with cruise control set at 60mph. The difference is minimal, but it IS there. Like i said before though, I think that if a tuner made a specific economy map for your vehicle you may see better results than if using the cookie cutter map from cobb.
Old 03-17-2010, 12:10 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
A MONTH? WOW!!! I could barely make it a week... I did get better MPG but it sure wasn't worth it. ALL the fun was taken out of driving the car, may as well have been driving my wife's ECHO...
wrxdrvr is offline   Reply With Quote
Old 03-18-2010, 01:33 PM   #9
riderome
Member#: 210603
2005 STI
AWD...fail....
Old 03-18-2010, 03:25 PM   #10
projectpat817
Member#: 50752
2006 STi
Maybe longer than a month, and you're right it's not really fun getting onto the on ramp of a highway not boosting, cars don't like that, especially in Chicago lol
I'm filling up tonight, I'm a little past the 3/4 mark with 238 miles on the 91 oct map.
So tmrw I'll start driving "normal," boosting and not boosting, I'll see how that affects my mpg. But of course this depends on the driver
Old 03-19-2010, 12:25 AM   #11
my02turboWRX
Member#: 68448
2008 WRX STi
Cobb tunned by Surgeline
Its all in the closed loop, open loop fueling.
Go into Econ and stay out of boost. There is your MPG gain.
But heck where is the fun in that??
my02turboWRX is offline   Reply With Quote
Old 03-20-2010, 09:43 AM   #12
arghx7
Member#: 232940
Adjust the closed loop fueling targets.
arghx7 is offline   Reply With Quote
Old 03-21-2010, 10:18 PM   #13
GroceryGetter06
Member#: 200092
2006 Stg.2 WRX Wagon
I fill my tank twice a week running stage two and I consistently hit 270 before I need to refuel. I have even hit 280.
GroceryGetter06 is offline   Reply With Quote
Old 03-21-2010, 10:50 PM   #14
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
You have a different motor than OP, therefore your numbers are irrelevant. Also, tanks is not a unit of measure
ProdriveDreams is offline   Reply With Quote
Old 03-22-2010, 08:38 PM   #15
WRBryce
Member#: 223862
2003 vf34'd WRX S/W
hahahah been there stg 2 map stays now... haha
WRBryce is offline   Reply With Quote
Old 03-26-2010, 09:06 AM   #16
gathermewool
Member#: 143624
14 FXT Touring
VRP
+1 miles/tank is useless.
gathermewool is offline   Reply With Quote
Old 05-26-2010, 05:09 PM   #17
WorldRallyRedneck
Member#: 6506
2005 WRX Wagon
I just switched to the economy mode to see what kind of difference it made in gas mileage. I loaded it in realtime mode, and my stage 2 map is still in reflash, how do i go back to the stage 2 map. Do i just click on show map, re flash and when the stage 2 info comes up click OK. Just want to make sure that i am back in stage 2, I don't want to open it up in economy mode.
WorldRallyRedneck is offline   Reply With Quote
Cobb AP - economy map txl146 Engine Management & Tuning 12 04-20-2005 10:26 AM
Anyone have a good fuel economy map? cartervt2k Engine Management & Tuning 6 03-30-2005 06:15 PM
Cobb Accessport Economy Map...Anyone? Oldalfaguy Engine Management & Tuning 9 03-04-2005 10:59 AM
Cobbs economy map boost? engr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-08-2004 11:55 AM
Cobb economy map grozgon Engine Management & Tuning 2 06-21-2004 10:54 PM
