Old 03-17-2010, 09:41 AM   #1
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Default OT handy wood folks or creative furniture idea folks or anyone else not busy
Scenario:
I need to raise up my PS3 and cable box off the floor. There isn't really enough space for a a/v rack beside the TV in the alcove. There's only about 2 feet of space max between the TV and the wall.
I was thinking of maybe putting in a shelf on the wall but will it hold? Or maybe a shelf with some of those hanging braces above or beneath?
HLEPE!
-=C=- is offline   Reply With Quote
Old 03-17-2010, 09:45 AM   #2
Kaiser
Woodpecker
Member#: 7170
Aut Kaiser,
aut nullus.
Originally Posted by -=C=- View Post
Scenario:
I think it's very brave of you to attempt this...what with the stroke you've obviously suffered recently.
Kaiser is offline   Reply With Quote
Old 03-17-2010, 09:48 AM   #3
-=C=-
Member#: 7719
99 F-150 crew cab
I have to keep it somewhat entertaining for OT...the attention span is measured in...oh look a bunny!
Old 03-17-2010, 09:48 AM   #4
.WRXXX.
Member#: 183695
.WRXXX. is offline   Reply With Quote
Old 03-17-2010, 09:52 AM   #5
Strider
Tasteful Mod
Member#: 2197
an inconvenience,
properly considered.
Strider is offline   Reply With Quote
Old 03-17-2010, 09:57 AM   #6
-=C=-
Member#: 7719
99 F-150 crew cab
ooohh...Strider...I like that...only real issue there is that the shelf would have to come out far enough so that you can reach the PS3 for loading. But I likey...now to find someone that can do it well enough to make it look nice.
What about load? Should I put braces beneath or those fancy cable braces above?
Old 03-17-2010, 10:56 AM   #7
madcatz
Member#: 187530
Fuk UrSelf
Height of archway, depth your working with. TV dimensions. Any other AV equipment?
Do you want the TV on top or on the floor, or both off the floor
madcatz is offline   Reply With Quote
Old 03-17-2010, 11:00 AM   #8
-=C=-
Member#: 7719
99 F-150 crew cab
TV has to stay on floor. It's a 51" Hitachi HDTV rear projection.
Height of archway is 8ft.
Depth of archway is 3ft.
Width of archway is around 6ft.
TV takes up around 4 feet wide and all the depth.
No other A/V equipment in this room yet, but at the most we would only add a sound bar.
Old 03-17-2010, 11:02 AM   #9
justincredible
Member#: 83633
2012 bright green
box
Milk crate.
justincredible is offline   Reply With Quote
Old 03-17-2010, 11:15 AM   #10
moshter11
Member#: 110190
u should set up the shelf (height between the shelf and the tv) so that u can hang a soundbar underneath the shelf and have the cablebox and tv on top of it.
moshter11 is offline   Reply With Quote
Old 03-17-2010, 11:20 AM   #11
-=C=-
Member#: 7719
99 F-150 crew cab
You don't read...here's my TV:
Hitachi 51F59 51-Inch Digital Projection HDTV
Old 03-17-2010, 11:38 AM   #12
madcatz
Member#: 187530
Fuk UrSelf
ill try to craft something up tonight.
but I think Strider has it nailed.
as for "supports" I would look into framing the wall with 2x4 then using 1/2" MDF as your support board to hold everything. you can use fancy wood to make the show side (what your lookin at) like a mahogany or Walnut to hide the MDF and framework above the TV. The 2x4 should be fine to support just about anything you put on there, then the MDF can be used as the top and you can even put some fancy **** back behind it all to make it all tie together
Old 03-17-2010, 11:42 AM   #13
-=C=-
Member#: 7719
99 F-150 crew cab
OK, don't go to any real trouble for this...I'm only looking for a cheapo solution. I'm going to go to Lowe's tonight to see if any of their ready to go shelves look decent enough.
Old 03-17-2010, 11:48 AM   #14
madcatz
Member#: 187530
Fuk UrSelf
or if you want on the cheap cheap......2x4's
1 8" on each wall, then use 2x4 to span to each support board put into the wall.
4 2x4 at 8' each to span the cove
and screws....of you can do toggle bolts in the drywall to anchor the supports. Or just screw into a stud on one of the 8" strips and it should be enough to hold the PS3 and cable box
Old 03-17-2010, 12:10 PM   #15
moshter11
Member#: 110190
oops i meant ps3 instead of tv.
of course not the tv on a shelf. sorry for confusion
Old 03-17-2010, 12:17 PM   #16
constantinus
Member#: 153174
just get something like this and put it next to the TV....without the baskets of course. i'm sure you can find some type of bookshelf under 2' wide that would fit between the TV and wall...
Dimensions: 31.5Hx11.75Wx10.75D"
http://www.target.com/Espresso-Narro...eywords=shelfs
who the hell hangs a heavy bag with toggle bolts?!
constantinus is offline   Reply With Quote
Old 03-17-2010, 12:21 PM   #17
-=C=-
Member#: 7719
99 F-150 crew cab
Originally Posted by constantinus View Post
toddler can pull that over...sorry for not telling that in the OP.
Old 03-17-2010, 12:32 PM   #18
moshter11
Member#: 110190
i have a crazy idea...
2 floor lamps like these
and place a thing of wood on top of these two lamps
like this
would make a pretty cool lighting effect also
with 2 feet behind the tv, i think this is doable. plus u dont have to drill holes on the wall.
Old 03-17-2010, 12:39 PM   #19
-=C=-
Member#: 7719
99 F-150 crew cab
LOL, my wife wouldn't be able to reach the PS3 to put a DVD in.
Old 03-17-2010, 12:43 PM   #20
lbone420
Member#: 6898
2001 Impreza 2.5 RS
Go to Ikea and purchase this.
http://www.ikea.com/us/en/catalog/products/70103622
It is very clean as it looks like it is floating since the supports are inside of the shelf and not above or below. It can hold up to 7lbs. I have one in my bedroom holding my DirecTV Box, DVD player and a lamp.
lbone420 is offline   Reply With Quote
Old 03-17-2010, 01:38 PM   #21
pattylicous
Member#: 117487
Combine these two ideas. It would be easy to make it stable and look nice.
This is a shot of a drawing cabinet at work to demonstrate what madcatz is talking about. Then you could put a 2" strip of fancy looking wood on the front to make it look nice (as already stated).
pattylicous is offline   Reply With Quote
Old 03-17-2010, 01:50 PM   #22
Ap1S2k
Member#: 100270
Since you have a projection tv, why not just put the ps3 and cable box on top of your tv?
Ap1S2k is offline   Reply With Quote
Old 03-17-2010, 01:55 PM   #23
Grap
Dicky Nipperist
Member#: 6590
so brave...
Grap is offline   Reply With Quote
Old 03-17-2010, 02:43 PM   #24
wrigh003
Member#: 13997
Personally, I'd put a cleat on either side of the arched opening (just a piece of 1x2 screwed flat to the wall into whatever studs are available)- there should be at least 3 studs there. Cut down a piece of 3/4" plywood to fit the length/depth (wall to wall) of what you want the shelf to be. Then cut a piece of 1x3 to use as facing for support (so the shelf doesn't bow) as well as so you can paint it to match your trim in the room, or the paint in the alcove, whatever. 1x3 will hide the 1x2 used as a cleat on the ends, too, so you wind up with what looks like a big 2.75" thick shelf. Put the front edge of the shelf even or just back from the front of the opening, but leave it a couple inches shy of the back so you can run your cords down. If you care A LOT about not seeing cords, you could make a false back for the alcove, etc.
wrigh003 is offline   Reply With Quote
Anyone else not getting email notifications from NASIOC anymore? garface General Community 7 12-23-2003 08:08 PM
Anyone else not gotten their Guiness towell? Thunder Lungs Off-Topic 3 12-20-2003 08:43 AM
Anyone else not have a birth certificate? kevinsUBARU Off-Topic 15 07-23-2003 01:51 AM
Anyone else NOT watch the Oscars, and not care? -=C=- Off-Topic 26 03-24-2003 02:08 PM
