Old 03-17-2010, 11:25 AM   #1
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Default Can I slap a new ACT disc in my ACT press. plate?
Right now I have a perfectly functioning (~40k miles) ACT HDSS clutch. My car will (hopefully) be making more power soon. Can I go ahead and pick up a new release bearing, pilot bearing and a different ACT disc and use my same pressure plate? Judging by the ACT site, it seems as if that will work fine. I just wanted to ask before I ordered something.
Also, the price difference is massive. $800 vs. $200 for the "rebuild."
CKxx is offline   Reply With Quote
Old 03-17-2010, 11:44 AM   #2
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
depends on the condition of the pressure plate but if it's good then that would be fine. i recently took one off my car and it had heat spots everywhere and cracks. =(
ownnij is offline   Reply With Quote
Old 03-17-2010, 11:45 AM   #3
blacktrail
Member#: 154841
2002 white
johnny tran
I'd ask a reputable dealer of ACT. The new disc may be advertised to hold more power than your current one but remember that the pressure plate is what applies the clamping force so you may not get the desired clamping force if your new disc is suggested with the use of a different pressure plate.
blacktrail is offline   Reply With Quote
Old 03-17-2010, 11:48 AM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Old 03-17-2010, 12:07 PM   #5
CKxx
Member#: 33458
93 RX7+09 Forester
Thanks guys. I gave ACT a call and they said that what I proposed is a perfectly acceptable upgrade. All their discs are the same dimensions, so you can pretty much pick a pressure plate and pick a disc and go to town. Apparently the 6pk will have a shorter life, but grabs harder. I don't mind the shorter life if I can get away with $140 disc from time to time.
If i put a new hard drive in my Dell laptop, can i still use my dell version of XP? kbcr3 Off-Topic 4 03-20-2007 03:34 PM
Need a new clutch, interested in an ACT... DannyGT Tri-State Area Forum 21 01-31-2003 02:15 PM
VIDEO of my new race motor in my r/c scooby ^jynx^ New England Impreza Club Forum -- NESIC 11 01-14-2002 10:38 PM
where can i get gold bulbs to put in my fogs... shukes24 Interior & Exterior Modification 7 11-09-2000 12:40 AM
Can I use synthetic oil while breaking in my engine? Tim K. Technical Forum Archive 11 05-26-2000 11:31 AM
