Old 05-31-2002, 05:07 PM   #1
WRXIN
Member#: 15405
2004 STI
Silver/Gold - Team Blew
Default So, why bother increasing boost?
Ok, I'll admit it, I'm confused. I'm ready to start the mods. I have all my gauges so I can see what heck I'm doing. I've read a lot about mbcs and abcs and the boost monkey, etc. On the one hand, increasing boost seems like a no-brainer easy way of increasing performance. Then I read that the ECU will pull timing anyway, so there is no point in increasing boost.
What's the deal? Will a uni-chip fix this problem? Is there a problem with increasing boost? Considering all the manufacturers out there making boost controllers, they must have some positive effect.
Please, no search comments. I have spend hours reading threads on this. I am looking for a definitive answer so I can figure out what my next purchase is going to be. Will increasing boost with an otherwise stock WRX help, or will the ECU screw everything up?
Thanks everyone.
-Mark
WRXIN is offline   Reply With Quote
Old 05-31-2002, 05:14 PM   #2
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
Default Yahh! What he said.
I just did the restrictor mod and am wondering the same thing.
chudlo
chudlo is offline   Reply With Quote
Old 05-31-2002, 05:17 PM   #3
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
The ECU will only be able to pull so much timing back. It can't match the HP increase value with timing retard to the "tee". One way to look at the situation you describe is, "Two steps forward, one step back". While increasing the boost you gain X additional power, but the ECU may pull back some timing for knock and thus give you X-y power with y being the amount of hp loss resulting from the timing retard. Its not a total "lose-lose" situation.
PS. This post is just so chock full of cliche's, its not even funny!
Cosworth is offline   Reply With Quote
Old 05-31-2002, 05:20 PM   #4
WRXIN
Member#: 15405
2004 STI
Thanks Cosworth, that makes sense. Anyone else?
I've read of people who are returning their high boost levels to stock levels to get better performance. That makes no sense to me.
Help out a fellow WRXer!?
Old 05-31-2002, 05:25 PM   #5
TurboRex
Member#: 8635
04 STI, 07 FXT
For the best performance set boost at about 16-16.5psi in 4th. Some cars are getting the best at 15-15.5. I think the difference is mainly accuracy of gauges. If you have a scanner, you can check the accuracy of your gauge. Increasing boost is the cheapest most effective mod you can make.
Greg
TurboRex is offline   Reply With Quote
Old 05-31-2002, 05:39 PM   #6
Diranged
Member#: 18722
2002 WRX Sedan
World Rally Blue Pearl
It seems to me that if you have a daily street driven vehicle, the easiest and safest thing to do is get the boost monkey and pull the restricter. That way your not always running full boost (ie, unless your going WOT), and you have a box that is making sure that you dont run lean and overheat anything. I keep seeing people put MBC's on their cars and I dont get it because it seems like the stock turbo is setup to run at its maximum efficient point of boost anyways... Someone please tell me if im wrong though!
--Matt
Diranged is offline   Reply With Quote
Old 05-31-2002, 05:39 PM   #7
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
Just go with a staged kit and stay under 17psi. I think some are causing the trouble by making mods after they get their kits and not having their cars re-tuned. If you don't live near a tuner don't try anything too wild.
-Jonathan
mynew02 is offline   Reply With Quote
Old 05-31-2002, 06:02 PM   #8
KJR
Member#: 16879
first don't bother with the restrictor mod if you are running the stock ECU. i have yielded best overall results around 15psi. the computer will sustain timing at this level. anything over this without an ECU upgrade and timing will be pulled during long revs. i don't want to void my warranty so i have installed only parts that can easily be un-installed, hence, no stage packages. i had an EBC and it was totally erratic and i was getting full boost at 3000rpm, hello high EGT's. now, the Monkey and i like it much better. 16-17 psi for short "spurts" of boost and 14-15.5 for sustained pulls. of course, higher boost means higher EGT's but this is working for me. trying to hold high boost for long periods seems to be a problem for my car, but i am pretty mellow for the most part and don't run the car real hard for long periods. just my $.02 good luck
KJR is offline   Reply With Quote
Old 05-31-2002, 06:06 PM   #9
WRXIN
Member#: 15405
2004 STI
KJR, so it looks like you like your boost monkey. Are you running with a uni-chip or anything else, or just the boost monkey?
Thanks,
Mark
Old 05-31-2002, 06:07 PM   #10
Diranged
Member#: 18722
2002 WRX Sedan
I wish the BOostMonkey would come with a little sticker for the car... Maybe like an "Intel Inside" symbol except "Monkey Inside"
--Matt
Old 05-31-2002, 06:14 PM   #11
KJR
Member#: 16879
wrxin, just the monkey. a uni-chip will do essentially the same thing but a bit more as far as your a/f ratios through the rpm range. i am going to install a a/r calibrator and meter to see how it's running soon. feels good though, much better than the previous EBC and i can set the monkey to bring full boost at 85% throttle or not at all. if someone else is driving i set the t.p.s. so high that the car will onlyrun off the wastegate.
and yeah, we need Kris to do some stickers for us.
Old 06-10-2002, 01:23 PM   #12
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
--Matt
There is a "monkey inside" logo on the website -- http://www.boostmonkey.com -- but I haven't seen any stickers yet!
CirrusWRX is offline   Reply With Quote
Old 06-10-2002, 03:00 PM   #13
AndyHidley
Member#: 1031
You can run as much boost as you want up to the point of detonation. From that point on the ECU will retard timming and it'll run crappy.
Detonation will be caused by injectors maxing out, fuel octane too low, intake charge temp too high, or too much timing.
Dont forget that subaru says in the manual that its "ok" to run regular octane gas in a pinch. But the ECU will pull timming upon seeing higher boost levels.
The unichip sellers assume that you have enough common sense to only run the highest octane that you can find. They programmed the chip around this and thus can stretch the limits of the EJ20 design to near max. (max being injector capacity, timming, rod and head gasket strength, etc)
AndyHidley is offline   Reply With Quote
So why bother to pay insurance? BrysImpreza New England Impreza Club Forum -- NESIC 27 02-24-2004 10:55 PM
Why bother bypassing TB coolant lines? jimb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 07-18-2002 10:44 AM
Why are so many people loosing boost pressure?? keystone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-08-2001 02:35 PM
Why bother with chipping the ECU at all? trhoppe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-01-2001 05:49 PM
