Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 05-31-2002, 06:49 PM   #1
Fatty Jones
Member#: 16610
Lord of tha blings
Default Pulling ABS fuse, dumb question...
OK, I've decided to disable ABS after reading the numerous posts and weighing pros, cons, safety issues, warranty implications, etc.
Newbie Powers Activate:
Do I need to disconnect the negative terminal of the battery when either 1)pulling the 20A dash ABS fuse(not the "hidden" 10A fuse) and/or 2)replacing the fuse again?
don't want to hurt myself or my precious WRX.
thanks all,
fatty
Fatty Jones is offline   Reply With Quote
Old 05-31-2002, 06:53 PM   #2
rally_wannabe
Member#: 15799
'02 WRX/'06 EVO IX
Vshnu-DPS Stg2/CBRD 405HP
It can't hurt.
I zapped the hell out of mine when I forgot to redisconnect after testing one time and just blew the new fuse.
i still had two more so no harm no foul!
BTW, one of them also will disable your SRS!!!
don't do that. take the time to loosen the dash with the three screws and do the 10Amp ITG one.
JMHO.
rally_wannabe is offline   Reply With Quote
Old 05-31-2002, 07:35 PM   #3
romanom
Member#: 16215
2002 WR WRX wagon
At the front, passenger corner just under the air intake is the ABS block. There you will see a large connector to a black box. Pull this out and use a ballon to protect it and something to protect the ECU. This will disconnect the ABS without cutting the power.
You will have an ABS light all the time, but it will remind you that it's not working.
romanom is offline   Reply With Quote
Old 06-02-2002, 02:26 PM   #4
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
See what "search" can yield for you?
ABS On/Off Switch Self-Installation Guide
My weekend project . . .
T-WRX is offline   Reply With Quote
Old 06-02-2002, 10:24 PM   #5
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
To directly answer your question, it doesn't really matter. I've pulled and replaced the ABS/Cruise fuse at events with the car both on and off. If you pulled the ABS/Cruise fuse, putting it back in immediately makes the light go off. If you pulled the other ABS fuse, you need to turn the car off and on again to reset the ABS.
I've since installed a kill switch on the ABS/Cruise fuse using instructions similar to those posted above.
There is no cone | Two right minus into tightens slippy over curb
Trunkmonkey Racing | sean@trunkmonkey.com | What is a Trunkmonkey?
Somebody set up us the WRX. All your rice are belong to us!
Sean is offline   Reply With Quote
Old 06-02-2002, 10:25 PM   #6
Sean
Member#: 518
762 PGT Impreza L,
Which fuse disables the SRS? I want to disable that one while racing. Airbags and helmets don't mix.
Old 06-03-2002, 04:02 PM   #7
rally_wannabe
Member#: 15799
'02 WRX/'06 EVO IX
it says it right on the fuse box.
ABS SRS.
Old 06-03-2002, 04:25 PM   #8
jmott
Member#: 6713
2007 Prius
brown
after you disconnect it, please do some testing in a parking lot somewhere. Practice emergency stops, stops while in the middle of cornering etc.
You can mess yourself up good if you aren't prepared.
jmott is offline   Reply With Quote
Old 06-03-2002, 04:32 PM   #9
jmott
Member#: 6713
2007 Prius
brown
Old 06-03-2002, 09:35 PM   #10
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Ditto what Jack said. Practice driving without the fuse.....but for the love of God.....don't do it on the street.....and don't drive around the streets with the fuse out.....very bad.
Josh
Legacy777 is offline   Reply With Quote
Old 06-03-2002, 10:06 PM   #11
jmott
Member#: 6713
2007 Prius
brown
Josh
josh, tons of cars in the US still come without ABS at all.
and I drive around the streets with the fuse out.
I truly believe Im safer taking my chances with a lockup than I am taking my chances ramming someones rear end at the bumpy stoplight stops around rice university
Old 06-04-2002, 12:00 AM   #12
rally_wannabe
Member#: 15799
'02 WRX/'06 EVO IX
It would be STUPID of you to drive around with faulty ABS.
I know I nearly had two seperate accidents with other cars when the WRX refused to stop once on a PERFECT but bumpy road and once on sandy gravel cutout invervals in asphalt.
then finally dinged a pole in a parking lot before I pulled that damn thing.
now the brakes are perfect. stops so fast it makes you sick.
threshhold braking is FINE.
just practice.
Old 06-04-2002, 07:11 AM   #13
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Learning to drive properly behind another car may have helped you in those situations as well.
Nah, screw that, let's blame our ABS.
Narcisse91 is offline   Reply With Quote
Old 06-04-2002, 09:41 AM   #14
rally_wannabe
Member#: 15799
'02 WRX/'06 EVO IX
we've been over that already 10 times dumass.
read the posts or just fk yrslf.
Old 06-04-2002, 10:11 PM   #15
Legacy777
Member#: 4800
I don't have abs on my legacy, and I'm fine. There are only a certain amount of circumstances I would want ABS. I don't know however if cars that normally have ABS if pulling the ABS act differently then cars that don't have ABS normally.....oh well....
Can I Overcome P0500 (VSS low/malfunction) by pulling ABS fuse? Tony Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-13-2010 11:30 PM
Pulling ABS fuse in 00 RS AT - urgent question Craigs Brakes, Steering & Suspension 6 10-27-2004 04:59 AM
Help with pulling ABS fuse Bean75 Tri-State Area Forum 10 12-11-2003 11:37 AM
Is pulling ABS fuse legal in Solo stock? Ultralight Motorsports 12 01-29-2003 11:41 AM
