Old 03-19-2010, 03:30 AM   #1
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Default 2.6l Track Motor build 2008 STi Maxwell Power Services
As the title says I'll be building a 2.6l track motor with Maxwell Power Services.
First a BIG thanks to all those involved:
Dominic Acia and Craig of Maxwell Power Services for the engine build
Geoff of Full Race for alot of technical feed back and turbo/exhaust
Geoff of Cygnus Performance for supplying most of the parts short of the longblock for this build
Short Block:
Maxwell Power Services Power Factor Track Edition 2.6l:
EJ257 Block
99.5mm JE custom pistons
Maxwell Power Services 83mm Billet Crankshaft
4340 I-Beam Standard length rods
ACL Race Bearings
Metal Jacket Harmonic Crank Pulley
Full Blueprint and Balance
Heads:
Maxwell Power Services Signature Series Heads:
CNC Ported Heads (30% exhaust flow gain/22% intake)
+1mm Ferrea Stainless Intake Valves
+1mm Ferrea Super Alloy Exhaust Valves
Ferrea Valve Springs with Ti Retainers
Kelford 220-c 272 Cams
Tuning
Element Tuning Hydra 2.6 EMS with Wideband 02
Turbo:
EFR 7670 .92 AR Twinscroll Turbo with Ceramic Coated Hotside and Blanket
Grimmspeed Boost Control Solenoid
Intake:
Fast Motorsports FMIC with DIY custom Reverse Intake Manifold
Grimmspeed Phenolic Spacer
GrimmspeedTGV Deletes
Exhaust:
Full Race TwinScroll Exhaust Manifold and Up-Pipe(Coated and Wrapped)
Full Race Downpipe
Magnaflow CBE
Oiling:
Maxwell Power Services 11mm oil Pump
Killer Bee oil pickup and sump
Accusump
YimiSports TMOC Kit
Cooling:
Koyo Radiator
Slim Radiator Fans
Grimmspeed Thermostat
Samco Hoses
Fueling:
Injector Dynamics 2200cc on 93 pump and e85
Element Tuning Hydramist
Pump 93, E85 and E98
Ignition:
NGK Spark Plugs
Optima Red Top
Clutch:
Carbonectics 3 Plate Carbon Clutch
SS clutch line
There are a few things still undecided. If anyone can give some suggestions on those I'd be more then willing to hear them out.
I'll update this as I decide on more things to put on or remember to put whatever I forgot on the list.
EtoS is offline   Reply With Quote
Old 03-19-2010, 10:53 AM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
what fuel do you plan on running?
Nuke209 is offline   Reply With Quote
Old 03-19-2010, 11:18 AM   #3
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Pump 93 and E85.
Old 03-19-2010, 04:00 PM   #4
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
sounds like a great build!!
GT3076R won't keep you entertained for long...
I just dumped mine and picked up a precision 6262SP....Great turbo! You should look into that as an option.
mtcs is offline   Reply With Quote
Old 03-19-2010, 04:51 PM   #5
acssa
Member#: 184023
who is cnc porting the heads?
acssa is offline   Reply With Quote
Old 03-19-2010, 06:20 PM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
Originally Posted by EtoS View Post
Pump 93 and E85.
I ran out of fuel on the ID1000cc, so we had to tap the FPR to raise up the fuel pressure.
ID2200cc with dual walboro should be fine.
Old 03-19-2010, 07:09 PM   #7
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Old 03-19-2010, 07:11 PM   #8
25rsti
Member#: 166324
seems like an exciting build, good luck with everything
Old 03-21-2010, 04:00 PM   #9
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
nice build, where are you from? Your location says Trenton, which is the town next to where I live. haha
D Money is offline   Reply With Quote
Old 03-21-2010, 04:09 PM   #10
hoagie rolls
Member#: 203463
2002 WRX 2.5L
WRB 350HP 370TQ
Why are you sticking with a top mount? All that power and then your not effectivly cooling down the intercooler...Front mount will show more gains.
hoagie rolls is offline   Reply With Quote
Old 03-21-2010, 04:33 PM   #11
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I would have used his 2.35 motor and had a huge powerband.
scby rex is offline   Reply With Quote
Old 03-21-2010, 07:09 PM   #12
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Top mount for less lag. It's not like I'll be using the stock top mount. You'd be surprised how well a good top mount can handle power and alot less lag then FMIC. Also makes more sense to use a TMIC for stock location turbo. I also will go FMIC when I go to phase 2 with a rotated turbo and twinscroll.
Old 03-21-2010, 07:13 PM   #13
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
It's definitely a nice setup but not the one I want. Maybe with another subaru if I make a flat out race car. Definitely going to be checking that car out when I go to build the engine
Old 03-21-2010, 07:21 PM   #14
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I don't get it... you're buying a FR 1.5 scroll header then down the road you're going to swap out the 1.5 scroll up pipe for the twin scroll up-pipe? With a build costing this much I don't see why you couldn't just go TS from the start.
And you mention about wanting less lag by using a TMIC yet you say this is a track build but have GT40's and GT42's listed as turbo options?
alcoolaid is offline   Reply With Quote
Old 03-21-2010, 07:37 PM   #15
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Yes cause the header is the same with a different up pipe from 1.5 to twinscroll. I could go twinscroll from the start but I don't want that much power from the get go. I'd rather move my way up in steps then go flat out. This engine is going to see alot of track time over the years hence why the big build. I don't see the problem with trying out different setups. And in this case whatever I lose from going to FMIC I could hand down to my fiances 05 STi.
And yes the gt40 and gt42 are options. Untill I see what the motor is really capable of that will be reserved for later judgement. So few have done a build like this so it's not like I can just do a search and find a whole page of what people encountered.
Old 03-30-2010, 05:09 PM   #16
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Updated information and new layout.
Old 05-19-2010, 02:40 PM   #17
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Updated.
So May 11th I flew from NJ to Seattle WA and took a shuttle to Arlington where Maxwell Power Services was located to do the engine build under the Build Your Own program they have. There I met the crew of 3- Dominic Acia, Craig and Wes. Dominic does the tunes/engineering/design, Craig does the engine builds among other things and Wes does the installs. I was there to learn how they put a 2.6 stroker together and take pics of the engine. Overall what a great bunch of guys and amazing facility they have there. I'll post up pictures of what they have to offer there.
Old 05-19-2010, 03:10 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
You're in good hands with them. Looking good!
Old 05-19-2010, 03:43 PM   #19
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
for the oil cooler, where are you going to mount it? and which kit did you get?
Thran is offline   Reply With Quote
Old 05-19-2010, 04:03 PM   #20
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
I'd just skip the whole stock location turbo process if your planning on goin rotated. Also I had major issues with the kelfod 272/268 dual acvs cams and the ATP stock location 35r. But I was also running the stock ecu/cobb ap. My engine builder told me the cams were too big for the atp 35r.
Danomite is offline   Reply With Quote
Old 05-19-2010, 05:40 PM   #21
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
just get twinscroll kit with 35R or 40R and tell dom to make you a 18 psi map, and when you feel like you tired of it go for 30psi map
+ that fullrace uppipe you wont sell it its waist of money to go that way
Bariga is offline   Reply With Quote
Old 05-19-2010, 08:59 PM   #22
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
The way things are looking I may skip the 1.5 scroll and go twinscroll so I'd do a top mount oil cooler setup.
It's looking to go that route. I may go with a BW 35r comparable turbo. FMIC vs TMIC has different response which was what I wanted out of a 1.5 scroll TMIC setup. O well I guess the safer more powerful route is better to take
Old 05-19-2010, 09:17 PM   #23
Danomite
Member#: 190449
If I were to do my turbo setup again i would have went rotated from the getgo and saved myself some hassle.
Old 05-19-2010, 10:39 PM   #24
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
Which one are you thinking about? i have been tossing the idea of going with a tmoc but i always heard about oil pressure isnt great traveling against gravity, wanted to read some more about it
Old 05-20-2010, 12:31 AM   #25
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Cool... I look forward to seeing your build come together.
I really like the way Maxwell can do the build, install, and tuning all under one roof. Having seen so much finger-pointing when things go wrong and each step was done by a completely different company, there's no way I'd ever go that route. One stop shopping FTW.
Maxwell Power Services erikos Vendor Reviews 17 03-27-2013 09:51 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 04:54 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 11:28 AM
99RS 2.5L stock motor build up questions. chrismindless Normally Aspirated Powertrain 3 04-21-2005 04:27 PM
