Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-19-2010, 03:00 AM   #1
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
Default Clutch Work in Austin
Anywhere other than Subaru that anyone would recommend for new clutch install ?
Thinking about doing it myself. It just went out of warranty (36000+miles).
It has been slipping some since 19,000 miles and was a 1,600 mile demo when I got it, but subaru said it was fine when I brought it in slipping. I should have pushed it then to have it replaced.
I started autocrossing it a little bit after that, and have maybe 6 races on it, and would slip a little every race, but is slipping pretty badly daily driving now after the last race, so I'm not going to blame Subaru at this point(much), but don't want to throw them any business. Due to the issues with this car overall, this will definitely be my last Subaru. (That and the whole 08' to 09' fiasco)
MurphysLaww is offline   Reply With Quote
Old 03-19-2010, 03:55 AM   #2
fatcircles
Member#: 142310
pm meld
fatcircles is offline   Reply With Quote
Old 03-19-2010, 09:10 AM   #3
zimmermamc
Member#: 63542
05 STI Aspen White
98 2.5RS Arcadia Green
Not me.
zimmermamc is offline   Reply With Quote
Old 03-19-2010, 09:13 AM   #4
wrx_02
Member#: 188471
If you want to try and attempt it yourself:
http://www.cobbforums.com/forums/sho...Clutch-install
It was not that hard if you have a good general knowledge of cars.
wrx_02 is offline   Reply With Quote
Old 03-19-2010, 09:46 AM   #5
HiI'mDustin
Member#: 214172
08 Evo X
+1 for meld
he gives good prices and has done dozens of clutches
HiI'mDustin is offline   Reply With Quote
Old 03-19-2010, 11:51 AM   #6
LaptopBrent
Member#: 112731
2006 WRX
Hit up Meld for sure!
LaptopBrent is offline   Reply With Quote
Old 03-20-2010, 02:13 AM   #7
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
I just finished the Diff on the BMW, and so am likely overly confident, because, well, it's just a diff.
I did buy a Tranny adapter for my jack to help with the diff, so I have that.
I think I am going to do it myself, so thanks for the DIY post. I need to re-install my Perrin FARB, and get a short shift kit anyway, so I can get a bunch of stuff done at once.
I'll make one for the 08' as I go and post it here.
Old 03-20-2010, 11:45 AM   #8
wrx_02
Member#: 188471
Good luck! PM with question if you can't get them from the DIY or the forum.
There were 2 hiccups I had with mine. The pins in the front axles only come out one way so if you are having a hard time spin them and hammer it from the other side. Also I had a hard time getting one of the bolts out of the shifter linkage. I noted this in the thread.
I have had 2 ppl in my area contact me about it and did it them selves with not issues. Should take you anywhere from 6 to 12 hours depending your skill level.
Just don't forget the Fork Release Pin you have to pull it!!!!!!!!11 The trans will not come out at all unless you pull that pin!
Old 03-21-2010, 02:21 AM   #9
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Crystal Grey Mettalic
I'll help for a few greenbacks... I've changed my clutch twice in the middle of the third time right now, just waiting on clutch masters to get my parts back to me... But let me know if u want help I can have your clutch out in about 3 hours
Daniel's05WRX is offline   Reply With Quote
Old 03-22-2010, 01:25 PM   #10
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
Thanks man, I very well may have to ask for help.
Old 03-22-2010, 05:21 PM   #11
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Is 08 push or pull?
If push, ignore the pin comment.
We had mine out in 3 hours, but had a nice electric impact
Good luck
And word of advise, If yours went out that fast, make sure the pedal and slave have full travel. Could be a sign of one not fully releasing <shrug>
scoobdude is offline   Reply With Quote
Old 06-16-2010, 06:48 AM   #12
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
haven't had the time to do it, the Rex has been in the garage for a month or two now.
found the Excedy OEM on Amazon for $260.00 Can't beat that.
Did the Diff, and suspension in the BMW. The entire cooling system in the Wife's POS Impala, and now this.
This is all working up to an s50 or LSx swap into the M3/25is next year. If I get all that done, I'm applying for my shadetree designation.
Telecom work in Austin??? chudlo Texas Impreza Club Forum -- TXIC 4 12-16-2005 11:06 PM
good body work in austin Devilprobably Texas Impreza Club Forum -- TXIC 0 05-26-2004 06:26 PM
WRX Clutch work in a GC8 Impreza? BrysImpreza Transmission (AT/MT) & Driveline 2 11-21-2002 01:45 PM
Who does good work in Austin? nsnguyen Texas Impreza Club Forum -- TXIC 2 03-22-2001 10:26 AM
