Old 03-19-2010, 11:52 AM   #1
Darkmatter1986
Member#: 233518
2009 WRX CSK Tuned
..RIP... 2013 WRX...
Default 6 speed swap into 09 WRX
So I did a search and this topic has been beaten to death for older models, but I have not seen anything related to an 09 WRX....I saw one post about a guy trying to put an 05 sti trans into an 08 but Im looking at doing a straight 08+ to 08+ swap and just wanted to see if anyone has any experience with this particular swap, and what you found was needed to make it work. Appreciate the specific info guys.
Darkmatter1986 is offline   Reply With Quote
Old 03-19-2010, 01:29 PM   #2
WRrexu
Member#: 217061
2009 Wrx
i think efi logics did it to an 08 wrx. i asked as did many others as to what problems they ran into and other info but no response was ever given...
WRrexu is offline   Reply With Quote
Old 12-11-2011, 02:00 PM   #3
yeahdatwrx
Member#: 284265
Did you ever get any info on this....I'm looking to do 6mt swap for my 2010 WRX.
yeahdatwrx is offline   Reply With Quote
Old 12-13-2011, 08:13 PM   #4
danbolsom
Member#: 256898
2011 WRX Limited 6MT
World Rally Blue
I am looking into doing an sti swap to my 2011 wrx
danbolsom is offline   Reply With Quote
Old 01-09-2013, 01:37 PM   #5
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
I will be doing one shortly on an 2011 WRX I will put together a write-up.
mxturboracer86 is offline   Reply With Quote
Old 01-09-2013, 02:01 PM   #6
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
very cool. how soon are you doing this? I'll be sure to watch for the thread!
SenorDucK is offline   Reply With Quote
Old 01-09-2013, 06:10 PM   #7
mikereiser
Member#: 291941
2010 Wrx sedan
Im planning on doing the same on my 2010 wrx, just did a new 5spd not to long ago so we will see how long it lasts. I researched this awihle ago and i couldn't seem to find much on 08+ either.
mikereiser is offline   Reply With Quote
Old 01-09-2013, 08:37 PM   #8
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Also interested
ryblair is offline   Reply With Quote
Old 01-10-2013, 08:43 AM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's mostly the same as the other years. Things to keep in mind about the newer models:
Push vs. Pull type clutch (replace clutch slave, clutch, flywheel, etc)
3.9 FD rear diff (new rear diff or 6MT with 1:1 center ratio)
Clutch Linkage (08+ required due to length)
xluben is offline   Reply With Quote
Old 01-10-2013, 09:37 AM   #10
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Doing the swap in February on my 2008 wrx after holding off for a year.
I will be swapping to 5x114.3 hubs and all, since I got a full 2010 driveline cheap enough.
2008+ sti are direct fittment minus the axels which need cv conversion or hub swap .
I am using 2010 sti setup
All parts are 08+ sti unless stated
6spd
Driveshaft - I am using a pst cf
Rear diff
6spd Transmission mount
R180 Rear diff mount
6sp shifter and linkage
Starter
Clutch fork
A new aftermarket clutch and flywheel or stock sti 04+
Dccd pro controller
You have two choices for rear axel setups you can keep 5x100 or switch to 5x114.3 .
Now the rear ether needs a set of custom axels the ways I have heard about are
Wrx axels with switched inner spec be cv to the diff side
Or
Monkiboy has a company making a set not made yet of conversion axels to keep 5x100
Or
switch to 5x114.3 hubs and axels
On the front the stock axels can be used .
Or
Swap to 5x114.3 to use the thicker sti axels
I will update any findings I have and a 100% list after the swap
wrb08wrxsedan is offline   Reply With Quote
Old 01-17-2013, 08:11 AM   #11
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Should be starting it around mid February, going to be keeping r160 and all the stock hubs
Old 01-17-2013, 08:46 AM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
With a 1:1 viscous center diff or a 3.54 r160?
Old 01-17-2013, 06:10 PM   #13
meffie
Member#: 113021
06 STi
I've been pondering this for my 12. Interested to hear how it turns out.
meffie is offline   Reply With Quote
Old 01-18-2013, 05:45 PM   #14
spx19811
Member#: 218998
2009 wrx hatch
blue
just blew mine on my 09 looking to do the same and am subscribing
spx19811 is offline   Reply With Quote
Old 01-27-2013, 05:34 PM   #15
LASOOBIE
Member#: 314389
2009 WRX Sedan
I just bought an 06 STI tranny, axles, diff and driveshaft for my 09 wrx. Trying to figure out what we are doing with hubs and rear axles. Should be getting into it more this week. Will keep posted.
LASOOBIE is offline   Reply With Quote
Old 01-27-2013, 06:47 PM   #16
25rsti
Member#: 166324
I have 08 STi hubs, knuckles, rotors, rear diff brace, driveshaft and more if anyone is interested.
Old 01-29-2013, 11:26 PM   #17
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Just finished a swap into a 2011 wrx
All you need is:
-2007 or newer STi trans (we used 2010 sti trans that came with shifter and drive shaft)
-08 or newer sti drive shaft
-02 thru 05 wrx r160 (if you don't want to go crazy and buy new wheels)
-r180 flange to attach sti drive shaft to r160
-STI slave cylinder
-STI clutch and flywhweel
Front axles can be reused, no need to swap (same as older swaps I've done)
If you use auto lgt drive shaft you don't have to swap flanges on the r160
Old 01-29-2013, 11:29 PM   #18
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Drive shaft on 07 and older sti is shorter than newer wrx and sti, Linkage is as well
Old 01-30-2013, 12:28 AM   #19
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
All you need is:
-STI slave cylinder
A couple clarifications:
  • 06 STI tranny will also work, but it will have shorter gears
  • You need the 08+ shift linkages, the older ones are too short
  • The 08+ Impreza AT driveshafts also work with the 6MT and r160
And there are also many other ways to do it (ie. 04-05 tranny and keep the stock rear diff, etc.). The way you did it is nearly the same as how I did mine except I used the Impreza AT driveshaft and unmodified r160. I also put in the Spec B long gears.
Old 02-06-2013, 12:54 PM   #20
LASOOBIE
Member#: 314389
2009 WRX Sedan
Please delete this post
Old 02-06-2013, 03:51 PM   #21
BlackHole
Member#: 85525
05 LGT Wagon 5MT
ABP
For rear axles, can the Legacy Spec B axles be used to mate the R180 diff to the stock hubs (this is what the LGT folks do)? The 08+ WRX platform is similar to the 02-09 Legacy, but I don't know if the axle lengths and outer hubs are the same.
BlackHole is offline   Reply With Quote
6 speed swap into 08 WRX help. aboogabooga Transmission (AT/MT) & Driveline 21 02-15-2013 08:17 AM
little trouble with 6 speed swap into 04 wrx tylerrusso Transmission (AT/MT) & Driveline 7 06-05-2009 08:18 PM
6 Speed swap Into Wrx ....Axle SWAP? the real suby dude Transmission (AT/MT) & Driveline 1 05-06-2009 03:43 PM
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 09:22 PM
I'm doing a 6 speed swap into my wrx and I need some advice! snowcrzy Transmission (AT/MT) & Driveline 1 10-16-2006 01:54 PM
