Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Flatirons Tuning
Old 03-19-2010, 03:49 PM   #1
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
Rally Stuff NEW! Modena Gear Sets and TS Diff, OEM & JDM Gear Sets, Exedy Clutches+ GroupN Mounts
We stock a wide variety of Drivetrain components, including gear sets, clutches, mounts, and limited slip differential's. Here are a few of the items that we have, and if you don't see what you are looking for, let us know and we'll see what we can track down for you.
Flatirons Tuning is proud to announce that we now have access to Modena Torque Biasing Differentials, and Gear-Sets for the Subaru 5-Speed Transmissions.
Modena is one of Australia's Premier Gear and Differential manufactures and they specialize in making motorsports grade parts. Modena specializes in producing Porsche gears and differentials for club racers, all the way up to endurance race-cars. They have also developed a proprietary sequential transmission for various motorsports applications including the Australian Touring Car Championship.
But quietly in the background, they have been producing Gears and differentials for Subaru's as well. Below is what we have available at present, but there will be more on the way soon. Including a gear-set or two for the STI 6-Speed Transmission.
New! - - - - Modena Torque Biased Front Differential for the WRX
Modena is one of Australia's premier manufacturers of Motorsport Gears and Differentials.
This is Modena's Torsen Style Torque Biasing Front Differential for the 2002 - 2007 WRX. This replaces the factory open differential, and will behave much like the factory LSD that is in the rear differential, or like the front LSD that comes in the STI from the factory.
Modena's Torque Biasing Differential will provide improved traction under acceleration, but will open, or "Unlock" under deceleration as soon as you lift your foot off the accelerator. This is ideal for a car that is driven on the street, or at the track or Auto-X course because it will give you improved traction through the corner, and will help reduce understeer.
The reason that this differential is not called a "Limited Slip Differential" is because it doesn't "lock-up" when the wheels begin to slip, which means that both wheels are receiving the same amount of torque and turning at or near the same speed.
Instead, The Modena Torque Biasing Differential will transfer torque between the left and right wheel in order to make sure that 100% of the torque that is sent to the front axle is distributed between the two wheels. In other words, if one wheel is receiving 60% of the torque, this differential will make sure that the other 40% is sent to the other wheel.
This results in improved traction for a better exit from the corner, without inducing any understeer, which a "Locked" Limited Slip Differential has a tendency to do.
Professional installation is strongly recommended, and this diff. comes with stub-axles all ready installed, for ease of installation.
This Modena Torque Biasing Differential is In Stock and Ready To Ship!
Click Here to order your Modena Front TBD - $1250.00
We also have acess to a limited number of front Torque Biasing front Differentials for the 4-Speed Automatic fond in the WRX.
Click Here to order your Modena front TBD for your Automatic WRX - $1100.00
Modena Hybrid RA Ratio Dog-Box Gear Set for the Subaru 5MT Transmission
This is a Modena Hybrid Ratio Rally Dog Box for the Subaru 5MT transmission. This is a competition Spec. gear-set, and professional installation is very strongly recommended.
You could say that the ratios are a hybrid of v5/v6 STi street ratios and RA ratios. The 1,2 are RA and 3,4,&5 are STi. This makes for a tall first with a great tight stack that will get you to 100mph really quickly. But it will still cruise down the highway without revving too high.
The ratios are as follows:
1st gear 3.00
2nd gear 1.92
3rd gear 1.294
4th gear 1.000
5th gear 0.791
This kit includes all parts necessary for installation including:
- Modena Motorsports Grade 2-Piece Main Shaft
- All 3 Stainless Steel Shift Forks
- All new Stainless Steel Shift Rods
- Some new bearings (seen in picture)
- Modena Shift Interlocker (to prevent selecting 2 gears at the same time)
Please call with any questions before ordering this Modena Gear Set.
MSRP on this Gear Set is $10,000, and the PPG equivalent would be $9,000+. Click here to order this gear set at the special introductory price of $7,500.00
Modena Group-N Ratio Dog-Box Gear Set for the Subaru 5MT Transmission
This is a Modena Group-N Ratio Rally Dog Box for the Subaru 5MT transmission. This is a Competition Spec. gear-set, and professional installation is very strongly recommended.
The Modena Group-N ratios are as follows:
1st gear: 2.917
2nd gear: 2.091
3rd gear: 1.555
4th gear: 1.176
5th gear: 0.900
The Modena Group-N Gear Box is taller down low and shorter up top than the Modena Hybrid Gear Box. They are super tight and super aggressive with the bare minimum of rpm drops between gears to always be in the sweet spot of the engine. This is ideal for a Rally Car that is using a restrictor that dramatically narrows your torque curve.
We do stock JDM Gear Sets, and though we do try to keep them in stock, but feel free to call to check availability before ordering.
STI Group-N Engine & Transmission Mounts
These Engine and Transmission mounts are made by Subaru Technica International to replace the stock parts.They are made using stiffer rubber and plastic to reduce movement of the engine and transmission under hard acceleration and braking.These are strongly recommended for highly modified engines.
Each part is available separately, or you can save with our Group-N Engine Mount Kit which includes all three Engine Mounts, or our Complete Group-N Kit which includes the Transmission Mount as well.
Transmission Mounts are now available for both the 5 Speed and 6 Speed Transmissions!
Professional installation is strongly recommended.
Click Here to order the complete kit - $234.99
2005 - 2008 OEM Legacy GT 5-Speed Gear Set
This is the OEM Main Shaft, and 1st through 4th gear that came in the 5-Speed manual transmission in the 2005 – 2008 Legacy GT.
The Gear ratio’s of this transmission are:
1st: 3.166
2nd: 1.882
3rd: 1.296
4th: 0.972
5th: 0.738
This set is available with either the Main Shaft and 1st and 2nd gear, or the Main Shaft and 1st through 4th gear. This gear set can be retrofitted into most Subaru 5-speed gear sets, but depending on the year of your transmission, you would need additional parts.
We now offer the 1-4 gear set with installation kits for the 2002 - 2007 WRX. Each kit is slightly different, but they all include all the parts that are required for installation. There may be other parts that need to be replaced due to wear, shuch as bearings and synchros. If you need any other parts, let us know.
All of the install kits to include a new speedo-gear, but WRX's with a 3.7 final drive will have a slight speedometer discrepency.
Professional installation is very strongly recommended, and if this gear set goes into any car other than it was designed for, there is no warranty expressed or implied.
Also, because of the number of issues that can arise due to improper installation, if we do not install this gear set for you, we do not offer any warranty on the parts.
Click Here to order. Main 1-2 Kit - $454.62 Main 1-2-3-4 Kit - $692.82
Click Here to order the Legacy GT Gear Set with the 02 WRX Install kit for $1039.00
Click Here to order the Legacy GT Gear Set with the 03 WRX Install kit for $1000.00
Click Here to order the Legacy GT Gear Set with the 04 WRX Install kit for $784.00
Click Here to order the Legacy GT Gear Set with the 05 - 07 WRX Install kit for $664.00
JDM STI Version 6 Standard Ratio Kit - In Stock
Assembled by Rallispec, the STi standard ratio gears feature a 5th gear that is identical to the stock WRX for those wishing to maintain the same highway performance. However, these gears provide a close ration 1-2-3, and improved reliability of the 5MT through similar hardening and strengthening features as found on the STi RA ratio gear set.
Now R.E.M. treated for increased strength.
This Kit Includes:
- Main Shaft
- 1st Gear Driven
- 2nd Gear Driven
- 3rd/4th Gear Set
- 5th Gear Set
- Main Shaft Lock Nut
- Output Shaft Lock Nut
- Pinion Shaft Lock Nut
- Transfer Case Gasket
- Front Main Shaft Oil Seal
- Custom Steel 3.9 Speedometer Gear
- Installation Kit for Correct year Car
Professional installation is strongly recommended, and you MUST order the correct installation kit for your car. If you are not sure what year transmission you have, you need to order the 02 Installation kit.
JDM STI V.6 Ratios
1st-3.166
2nd-1.882
3rd-1.296
4th-0.972
5th-0.738
Click here to order your kit starting at $1258.71
JDM STI V.6 RA Ratio Gear Set - We have 4 RA sets in stock and READY to SHIP!
Assembled by RalliSpec, the close ratio gears from the STi RA feature strengthened and hardened components for improved reliability of the 5MT in modified Imprezas. The gearsest have REM-treated 1st-4th gears for even further improvements in reliability at high power levels. Each gearset includes all necessary gears for installation including a custom speedometer gear (3.9 final drive ratio only).
Now REM Treated for increased strength.
Professional installation is very strongly recommended.
JDM STI-RA
1st - 3.083
2nd - 2.062
3rd - 1.545
4th - 1.151
5th - 0.825
This kit contains the following:
STI RA Main Shaft
STI RA 1st Driven Gear
STI RA 2nd Driven Gear
STI RA 3rd Drive Gear
STI RA 4th Drive Gear
STI RA 3rd/4th Driven Gear Cluster
STI RA 5th Drive Gear
STI RA 5th Driven Gear
1st Gear Synchro (baulk ring)
Lock Nut, Main Shaft
Lock Nut, Pinion Shaft
Lock Nut, Driven Shaft
Oil Seal, Main Shaft
Custom Steel Speedometer Gear
(Calibrated for 3.9 Final Drive)
Case Gasket
Click here to order your gear set starting at $1449.99
This is a brand new 6-Speed Transmission that came in the 2007 STI. Perfect to swap into your WRX!
Gear Ratios:
1st - 3.636
2nd - 2.235
3rd - 1.521
4th - 1.137
5th - 0.971
6th - 0.756
Reverse - 3.545
Front reduction gear - 3.900
Transfer reduction - 1.1
Rear reduction gear - 3.545
Transmission gear oil - GL-5 4.3 US quarts
This transmission has a 1.1:1 transfer reduction, which is the same as most of the previous WRX models, making this transmission easier than most others to retro-fit into a WRX. You will need other parts to get this swap to work, but this year of transmission is without a doubt the easiest because it requires changing out the minimum # of parts to get it to work correctly.
This is for the transmission only, and does not include shift-linkage, axles, propeller-shaft, etc.
Because of the size and weight of this part, it must be shipped as freight.
Click Here to order your brand new 2007 STI 6-speed transmission - $4200
__________________
303.402.5142
Contact us at:
FlatironsTuning.com is offline   Reply With Quote
Old 03-19-2010, 03:51 PM   #2
FlatironsTuning.com
Member#: 171650
Hey guys, we are pleased to announce that Flatirons Tuning now carries KARTBOY!!
We just got our first shipment in. We are able to order anything from Kartboy, and have lots of items in stock and ready to ship!
We now have Kartboy shifter bushings in stock!!
We now have Kartboy Shifter bushings for both the 5 and 6 speed transmissions, as well as the Kartboy rear shifter bushing. These Polyurethane bushings are a great upgrade over the OEM rubber bushings.
Rear Shifter Bushing: $35
STi Shifter Bushings: $32
WRX Shifter Bushing: $30
We also now have Kartboy short shifters for the WRX, Legacy GT, and STi!
These short shifters are non-adjustable, mechanically shortening the shift throw length. These work great in combination with a corresponding set of Kartboy shifter bushings and a Kartboy rear shifter bushing.
Note that the STi shifter is compatible with 04-09 STi's; the shifter includes two spacers which are either used or discarded depending on the width of your shift linkages.
Kartboy STi Short Shifter 04-09': $150
Kartboy WRX 5-speed Short Shifter: $100
Kartboy Legacy GT and 08+ WRX Short Shifter: $110
We also have Kartboy's Polyurethane Transmission Crossmember and rear differential bushings!
Kartboy Transmission Crossmember Bushings: $30
Kartboy Rear Differential Bushings (softer version): $32
Old 03-19-2010, 03:51 PM   #3
FlatironsTuning.com
Member#: 171650
This Just In!
Modena looked at the options for differentials available for the Subaru STI 6-Speed transmission, and saw that there was not much in the way of a true motorsports differential. For this reason, Modena has released a set of differentials for the Subaru 6-Speed STI Transmission for motorsport applications that are second to none in terms of performance and adjustability.
The exact same locking mechanism used in these Subaru differentials are being used all over the world in cars that compete in Rally Racing, as well as sprint racing and endurance racing.
All 3 of these Modena differentials use the same Modena Limited Slip assembly with Modena Clutch plates, making all 3 equally adjustable and rebuildable. The special Modena clutch plates provide so much lock-up that these differentials are only designed to work with R Compound Race tires, as street tires will most likely not provide enough traction to get the clutch plates to slip.
The front differential comes in what would be considered a 1.5 way configuration. The two options are 90% Lock under acceleration and 40% lock under deceleration, or 85% Lock under Acceleration, and 35% under deceleration. (90/40 or 85/35)
The Rear and Center differential are using the same 2 way configuration. The two options for the center and rear differentials are 80% lock under both acceleration and deceleration, or 90% lock under both acceleration and deceleration. (80/80 or 90/90)
Other locking profiles are available, so if you do not see what you are looking for, let us know and we’ll see what we can do.
The other thing to note is that service for these differentials is now available here in the US with a quick turnaround. It will usually only take between 24 and 48 hours to rebuild, or reconfigure your differential.
Since these differentials are designed for motorsports application, it is recommend that you have them re-built every 80 – 100 hours of use.
The R180 Rear differential can be used by itself with the OEM Subaru center and front differential for some applications. The Front differential can also be used with the OEM Subaru DCCD, but it is not recommended. If you are going to use the Modena Center Differential, you would need to use the Modena front and Rear differentials as well.
We do encourage you to ask any questions before you order these differentials to make sure that you are getting the correct set-up for your driving application.
Click Here for Pricing and to order your Modena Motorsports Differentials
Please feel free to PM us with any questions!
We also have Exedy clutches for your application in stock! We can also order any Exedy product you might need.
Exedy Stage 1 Organic Clutch ---
Exedy's entry level performance clutch.
In Stock:
Click Here for the 04-09 STi - $534.99
Click Here for the 02-05 WRX (2.0L) - $529.99
Click Here for the 06-07 WRX and 05-09 Legacy GT - $534.99
Exedy Stage 1 Heavy Duty Organic Clutch
These use an upgraded pressure plate, increasing the torque capacity of the clutch. For example, on the STi, the torque capacity is increased to 402 over the standard Stage 1's 321.
In Stock:
Click Here for the 04-09 STi - $574.99
Click Here for the 02-05 WRX - $563.99
We also have Exedy lightweight flywheels to go along with your clutch upgrade in stock and ready to ship!
In stock:
Click Here for the 04-09 STi - $372.99
Click Here for the 02-05 WRX - $328.53
Click Here for the 06-07 WRX - $317.20
If you are doing a clutch and flywheel installation, we recommend re-sealing the back side of the motor while you have access. If you are a low mileage car this may not be necessary, but for most applications, it is good peace of mind.
This kit includes everything you need to reseal the whole back side of the motor, which you have access to during that installation. The parts are also available individually below the kit.
The kit includes:
-- 806786040 - Rear Main Seal
-- 11831AA210 - Rear Access Panel
-- 800406140 (x5) - Access Panel Screws
-- 800406150 - Access Panel Locking Screw
-- 806931070 - Driver's Side O-Ring
This kit is applicable to most turbo Subaru's. If you are unsure if this kit includes the parts you need, simply give us a call at 800-830-6675 with the last 8 digits of your VIN number. We can then check Subaru's system to make sure you are getting the right parts!
Click Here to order your Rear Engine Re-Seal Kit - $39.71
Old 03-19-2010, 03:51 PM   #4
FlatironsTuning.com
Member#: 171650
On a budget? We have Exedy OEM-replacement clutch kits and Subaru OEM flywheels!
These Exedy kits are essentially the exact same clutch that is in the stock WRX. The stock clutch is manufactured by Exedy, so cut out the middle man (Subaru) and get this for almost half the cost of the OEM one!
On sale on our website for $172.55!
Also, we have OEM Subaru Flywheels for all years of the WRX and STi, as well as the flywheel needed to run an aftermarket clutch in the Legacy GT.
The 02-05 WRX Flywheel is on sale for $195.05!
Old 03-19-2010, 03:52 PM   #5
FlatironsTuning.com
Member#: 171650
Last one I promise.
Old 03-22-2010, 10:47 AM   #6
FlatironsTuning.com
Member#: 171650
TGIM bump.
Old 03-23-2010, 11:56 AM   #7
FlatironsTuning.com
Member#: 171650
Tuesday bump.
Old 03-24-2010, 12:01 PM   #8
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 03-25-2010, 11:52 AM   #9
FlatironsTuning.com
Member#: 171650
Thursday bump.
Old 03-25-2010, 10:18 PM   #10
GochYou
Member#: 169479
2002 Hybrid WRX
Pro-Tune SpeedIndustry
sent you a pm.
GochYou is offline   Reply With Quote
Old 03-25-2010, 10:19 PM   #11
prometheum
Member#: 92003
04 bicycle!
how do they charge so much for the gearset yet so little for the lsd?
prometheum is offline   Reply With Quote
Old 03-26-2010, 10:37 AM   #12
FlatironsTuning.com
Member#: 171650
TGIF bump.
Old 03-26-2010, 10:40 AM   #13
FlatironsTuning.com
Member#: 171650
The price for the Front Diff is actually right in line with other comparable diff's out on the market.
As for the gear set, this is a top of the line motorsport gear set, that is actually a very good value compared to an equivalent PPG set for instance.
Feel free to PM me with any other questions you might have.
__________________
303.402.5142
Contact us at:
Old 03-29-2010, 03:37 PM   #14
FlatironsTuning.com
Member#: 171650
TGIM bump.
Old 03-31-2010, 11:19 AM   #15
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 04-01-2010, 01:43 PM   #16
FlatironsTuning.com
Member#: 171650
Thursday bump.
Old 04-02-2010, 10:55 AM   #17
FlatironsTuning.com
Member#: 171650
TGIF bump.
Old 04-05-2010, 10:39 AM   #18
FlatironsTuning.com
Member#: 171650
TGIM bump.
Old 04-07-2010, 10:18 AM   #19
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 04-07-2010, 05:01 PM   #20
terror7
Member#: 80482
2004 PSM WRX -- RIP
2006 Aspen white WRX
Placed an order yesterday. The price for Group-N mounts are very good.
I am looking forward them to come.
terror7 is online now   Reply With Quote
Old 04-08-2010, 11:57 AM   #21
FlatironsTuning.com
Member#: 171650
Thank you for your business!
__________________
303.402.5142
Contact us at:
Old 04-09-2010, 10:49 AM   #22
FlatironsTuning.com
Member#: 171650
TGIF Bump.
Old 04-13-2010, 11:29 AM   #23
FlatironsTuning.com
Member#: 171650
Tuesday bump.
Old 04-14-2010, 10:35 AM   #24
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 04-16-2010, 10:48 AM   #25
FlatironsTuning.com
Member#: 171650
TGIF bump.
Difference between Oem Exedy clutch and Exedy Stg 1 Serkan Transmission (AT/MT) & Driveline 7 11-11-2011 03:27 PM
JDM & OEM Gear Sets, ACT& Exedy Clutches, Engine Mounts, & LSD's FlatironsTuning.com Drivetrain 244 03-17-2010 10:52 AM
Perrin NEW R160 High Capacity and Cooling Diff Cover - $210 Shipped CO WRX Drivetrain 15 08-21-2008 02:32 PM
Cusco mounts, Stock FW, Exedy clutch, exedy LW FW, forester tranny, diff, axles, hubs big67 Drivetrain 8 01-09-2008 12:18 AM
STi V6 RA Gearsets, Cusco Motor Mounts, ACT and Exedy Clutches and Flywheels Z1 Performance Drivetrain 13 10-10-2005 06:15 PM
