Old 03-19-2010, 09:10 PM   #1
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Default Want to do trailing arms, hub bushings, and lateral links but, NVH???
Do you happen to know how much if any NVH I might experience if I swapped my stock trailing arms (with megan trailing arms), hub bushings (with SuperPro urethane replacements), and did a set of aftermarket adjustable lateral links...
I'm sure many have done this, how much NVH??? anything? The arms have pillowballs in them for reference.
djerickd is offline   Reply With Quote
Old 03-19-2010, 09:35 PM   #2
teiva-boy
Member#: 22825
I have in the rear...
Group-n front trailing bushings
prothane rear trailing arm bushing (in the hub to be exact)
whiteline lateral link bushings
kartboy botox bolts
I have no noticeable NVH that I can detect over my already non-OEM muffler.
That said, I really dont think you'll get that much more, but if you put things in the driveline you will. At least that has been my experience.
teiva-boy is offline   Reply With Quote
Old 03-19-2010, 09:52 PM   #3
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
thanks for your input!
Old 03-19-2010, 10:09 PM   #4
fastwrx25
Member#: 126441
03 bugeye
In the rear I got superpro bushings in the lateral links, rear trailing arm bushing(hub), and obx trailing arms, whiteline rear subframe locking bolts, and superpro rear diff mount bushings.
no additional nvh. Only thing I noticed nvh wise after install was that going over rough roads or cobblestone streets the rear is louder and much firmer. But that is the only downside....improvement in handling and control in the rear is substantially better.
if you haven't gotten fender / cowl braces get some. tighter front handling and less banging when going over rr tracks or bad roads.
fastwrx25 is offline   Reply With Quote
Old 03-19-2010, 11:13 PM   #5
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
Pull the trigger.
I've got Whiteline adjustable lateral links, subframe lock bolts, urethane diff bushings, urethane trailing arm bushing (F&R).
gagliano is offline   Reply With Quote
Old 03-28-2010, 01:14 AM   #6
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Ok I am getting a clunk in both Megan trailing arms... Anyone else ever have this issue?
Old 03-28-2010, 02:28 AM   #7
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Did you buy spherical links, or rubber/urethane bushings? You might not have installed something right
happs subi is offline   Reply With Quote
Old 03-28-2010, 09:18 AM   #8
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
the Megan trailing arms have pillowballs
Old 03-28-2010, 09:26 AM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
There you go.
if you stick with something like group n it'll still be better than stock, and not too bad on noise.
Old 03-28-2010, 11:26 AM   #10
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
WTB Trailing Arm and Lateral Links/Rear tracking arms. Passengers Rear Right Side 02WRX1989 Private 'Wanted' Classifieds 7 03-05-2009 11:21 PM
STI WRX PINK trailing arms and lateral links 2004-2007 Subaru SPT lateral link kccobra Suspension/Brakes/Handling 5 03-12-2008 07:33 PM
New and Improved End Links, Bushings, and Lateral Links PolTec Inc Suspension/Brakes/Handling 67 05-25-2006 08:15 PM
Lateral Links and Trailing Arms Package Deals, New End Links PolTec Inc Suspension/Brakes/Handling 30 05-02-2005 06:48 PM
Any new thoughts on your STi trailing arms and lateral links? thebusiness999 Brakes, Steering & Suspension 27 04-25-2003 12:10 PM
