Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 03-25-2010, 04:33 PM   #26
eg33GC
Member#: 206851
56 Belair
Pro Street
Originally Posted by PrecisionCustom View Post
LOL. Do u know what HF is. lol, I like how u say it has nothing...NOTHING to do with steel welding then say but the start. High freq is F-en huge when it comes to steel welding period. The amount of HF controls how wide or small your arc is. It also controls the arcs start-ability. And your pointless MIG welding talk is kinda lame. On your own level i guess. I bet Kenny is getting a little laugh on this. He actually knows what he is saying. Well im not trying to have a big dick contest here but I posted some work. The comment on the color of a weld is also incorrect. Stainless can tell you allot from its color. Lots of blue and purple is cold and most likely did not penetrate correctly. Ideal color for stainless (Pretty much any series) is gold or siliver. Gray or discolored completely is very bad. Porosity is present and the piece has become work hardened. Making it brittle and likely to crack. Pulse has nothing to do with puddle control or stability period. It controls the amount of amperage across the signal at any given rate. Stability is controlled through connections to the work piece, amount of space from work piece, environment your in, and a whole lot more variables but pulse.
I recommend asking for a refund to the backwater 2 year tech you went to ( if at all)
HF only applies for Al, where the A/C needs it for stability. You must be mixing HF with arc force/pinch/?
Bead profile is 90% heat, 10% arc force setting/"pinch" setting ( or whatever your manufacturer calls it)
As far as backpurging goes, use it only for critical welds where you want maximum nominal flow. IE DIY headers won't really benefit unless youhave massive over penetration.
eg33GC is offline   Reply With Quote
Old 03-25-2010, 08:55 PM   #27
PrecisionCustom
Member#: 207830
2002 Precision Built
^ $hitz weak!!!!!
PrecisionCustom is offline   Reply With Quote
Old 03-25-2010, 11:17 PM   #28
eg33GC
Member#: 206851
56 Belair
Pro Street
^ $hitz weak!!!!!
nasioc already has too much misinformation, leave yours out.
I always laugh when i read "pulse has nothing to do with puddle control".
pulse= changing peak heat to lower heat set by the user, and adjusting how long peak is on. So current has nothing to do with puddle control?!
Old 03-26-2010, 07:44 AM   #29
PrecisionCustom
Member#: 207830
Dude shut your misinformed mouth now. I work as a Tech for Lincoln Electric. If you would like a welding lesson please feel free to sign up. I am teaching a motor sports welding class coming up soon.
http://www.lincolnelectric.com/focus...ool/school.asp
Old 03-26-2010, 03:03 PM   #30
25rsti
Member#: 166324
MAN!@ i would LOVE to sign up but im in MA ;-(
Old 03-26-2010, 03:55 PM   #31
PrecisionCustom
Member#: 207830
I can send u some really good information through the mail, Pm me if interested.
Old 03-27-2010, 03:20 AM   #32
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
here is mine, not quite finished yet. should be done by the end of next week i hope. i know its not as nice as some of the setups above.. but i'm proud to say that i have done it all myself
olsen726 is offline   Reply With Quote
Old 03-27-2010, 10:40 AM   #33
240sxguy
Member#: 229791
2002 WRX wagon
^ Nice work man, you should be proud.
240sxguy is offline   Reply With Quote
Old 03-27-2010, 12:58 PM   #34
Fas_ti
Member#: 236712
local performance performance shop by the name of AGP Turbos just started making these kits for our STI's and I was there tester they normally make kits for srt-4
Fas_ti is offline   Reply With Quote
Old 03-27-2010, 01:00 PM   #35
PrecisionCustom
Member#: 207830
Sick project olsen726. What you got going on with that beast. MOD LIST PLEASE
Old 03-27-2010, 05:12 PM   #36
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
here is a link to the build thread.
http://forums.nasioc.com/forums/show....php?t=1753564
basically what i am doing is boosting my n/a block at 7 pounds.
then after i get that all figured out i want to do a brake upgrade.
in the mean time i will be building a spare block i have, and swapping that in when its finished, so i can turn the boost up.
i just need to fab my up-pipe, and i can hook everything up and bring it in for a tune
Old 03-29-2010, 02:41 PM   #37
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
.one lane is offline   Reply With Quote
Old 03-29-2010, 04:07 PM   #38
PrecisionCustom
Member#: 207830
^ nice.. Any pointers in laying out that piping. I am headed the same direction as you
Old 03-29-2010, 05:40 PM   #39
25rsti
Member#: 166324
did you have to lengthen the wires for the maf on that side? if not what did you do?
Old 03-29-2010, 05:56 PM   #40
Built Industries
Member#: 33839
that looks very similar to the Turbo XS Rotated Kit.
Built Industries is offline   Reply With Quote
Old 03-29-2010, 10:47 PM   #41
mr.green
Member#: 235902
thats a pretty beefy turbo my friend had it on his srt4
mr.green is offline   Reply With Quote
Old 04-01-2010, 06:21 AM   #42
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
Yeah, I had to extend the MAF, and the TPS wires. Careful with the MAF since the maf signal requires shielding.
As for pointers, measure a sh%t load and cut once, and having a general idea where you want the pipes also helps.
Old 04-02-2010, 02:47 PM   #43
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
is there any certain wire that needs to be used to extend the maf?
Old 04-03-2010, 04:40 AM   #44
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
http://forums.nasioc.com/forums/show....php?t=1884052
This should answer your questions about extending your MAF cables.
Old 04-03-2010, 06:10 AM   #45
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
thank you sir
Old 04-03-2010, 08:21 AM   #46
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
Here is some of my work. Did it all Solo
teach/help me do rotated set up on my rsti
slava from goshen is offline   Reply With Quote
Old 04-03-2010, 08:32 AM   #47
slava from goshen
Member#: 152176
BRP/SRP
instead of just pics can people post up specs as well. like:
what type of material used (size, lengths, bends, thinkness, etc), where purchased and pics of actual pieces maybe some dimensions.
Old 04-03-2010, 10:47 AM   #48
PrecisionCustom
Member#: 207830
Dude I would so like to help you.... YOu have PM
Old 04-04-2010, 09:04 AM   #49
NitroPlasma
Member#: 203001
2005 Impreza WRX STI
WOW I really like that intake manifold! i wanna make one! Percision really really really nice welds. I am a custom fab. as well just havnt touched my sti just yet ALOT more knowledge based when it comes to building parts like the intake manifold . And rem everyone cup size,tungstin,hf s,pulse, gas all of it contributes to the way a weld looks! And the strength of the weld. I personally love using the miller dynasty 300 i think it's the best for the buck and for the size the dynasty 200 are nice but if i rem correctly they are big,(not 100% sure) dynasty 300 is nice and compact. Any of you guys ever weld anodized alum? Very fun! And hey if any of you guys want some steps on polishing let me know, when i find my pictures of my down pipe i put togeather i will post them!
NitroPlasma is offline   Reply With Quote
Old 04-04-2010, 09:25 AM   #50
PrecisionCustom
Member#: 207830
Dynasty 300 FTW. I had to learn the hard way about anodization. Be careful when u weld aluminum and have to get things anodized. I forget which one it is but between 5356 and 4043 one of them will make your welds look black after being anodized. Get at me if you need and tips on the manifold Nitro. I would love to help ya out. PS Thank you
Piece of Perrin rotated kit 06rexwagon Private 'Wanted' Classifieds 12 06-24-2010 11:06 AM
Pictures of custom installs/boxes? Gman094 Car Audio, Video & Security 42 04-17-2004 12:43 AM
Post picture of custom grilles!!! WRXVII Member's Car Gallery 0 08-23-2002 12:20 AM
Can someone post a picture of custom designed front grille? WRXVII Member's Car Gallery 0 08-19-2002 01:34 PM
