Old 03-21-2010, 07:09 PM   #1
'07-wrx
Member#: 140799
2007 WRX
Satin White Pearl
Default Rear swaybar question
Hey guys so im just starting to get into autoxing and im debating on whether or not to add a rear sway bar to my set up. My main concern is how to keep the car from three wheeling around the track, my current set up is as followed.
2007 wrx
vf-39
sti topmount
cobb catted dp, greddy tic catback
zeal function xs coilovers 8k front 6k rear
cobb front swaybar with whiteline endlinks
whiteline steering rack bushing
stock rims with 225/45r17 direzza star specs.
I dont have my exact alignment with me but its something like 1.5 camber in the front and .58 camber in the rear with zero toe all around.
Right now ive been running novice class street mod and the car still pushes. Im in the process of looking for different rims i think im gonna end up running 245's or 255's most likely stick with street tires for now. Any input would be helpfull
'07-wrx is offline   Reply With Quote
Old 03-21-2010, 08:49 PM   #2
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
IMO, you already have too much tension in the suspension w/ those spring rates, a stiff(er) rear anti sway bar will add more. But to each his own...
REDrum is offline   Reply With Quote
Old 03-21-2010, 09:03 PM   #3
steveRS
Member#: 180430
2008 335i
Coilovers are the key. You need more droop travel to keep all 4 wheels down.
Also why are you so concerned with lifting the inside rear. It's not as critical with the wrx compared to the STI because of the viscous lsd.
steveRS is offline   Reply With Quote
Old 03-21-2010, 11:08 PM   #4
jamal
Member#: 71875
98 2.5GT
my wheels fit
different spring rates will help. for the cheapest fix switch them front - rear, although less of a differential and softer springs would be preferential, especially for street tires. Somewhere in the range of 400f, 450r would be best. And yes, get a rear swaybar.
wait, are they 600lb/800lb, or 6k/8k?
jamal is offline   Reply With Quote
Old 03-22-2010, 03:50 AM   #5
'07-wrx
Member#: 140799
2007 WRX
Satin White Pearl
oh sorry i meant to say 8k/6k
Old 03-22-2010, 07:03 AM   #6
GT11
Member#: 128002
0000 four door sedan
Poop color
If you just add a rear sway bar, the car will feel unstable at high speeds. Your rear end will come out when you least expect it. Get both front and rear sway bars to be on the safe side.
GT11 is online now   Reply With Quote
Old 03-23-2010, 07:05 PM   #7
leecea
Member#: 37359
2003 WRX
Can you have a local expert autoxer give the car a drive? Sometimes driving adjustments are the answer if the car appears to be pushing a lot.
Also, if your struts are adjustable, have you tried stiffening up the rears and/or adjusting tire pressures. That way you can get the back looser and adjust it back for daily driving.
leecea is offline   Reply With Quote
Old 03-23-2010, 07:40 PM   #8
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Stiffer front springs and more camber.
alcoolaid is offline   Reply With Quote
Old 03-23-2010, 11:57 PM   #9
'07-wrx
Member#: 140799
2007 WRX
Satin White Pearl
I have been getting advice from a co-worker and autoxer Scott Fraser, who has driven my car and is helping me set up my car and we have been arguing about me getting a rear sway bar or messing with springs. So for this weekends autox im going to try more camber and see how it goes. We have adjusted the shocks which have helped but its still not right.
Rear swaybar question minx1225 Factory 2.0L Turbo Powertrain 6 08-29-2005 06:06 PM
STi stock rear swaybar question Kaze Brakes, Steering & Suspension 10 06-27-2005 11:59 AM
Front & rear swaybar questions QAScooter Forester Forum 9 08-12-2002 11:06 AM
Cusco Front & Rear Swaybars Question natasha talarico Brakes, Steering & Suspension 14 05-10-2002 09:40 AM
front and rear swaybar question psaeko Brakes, Steering & Suspension 7 02-14-2002 03:11 AM
Message Board Statistics All times are GMT -4. The time now is 12:16 AM.
