Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 06-01-2002, 10:49 AM   #1
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Default 2.5 oil pressure locations
Other than the spot under the alternator, are there any other places to get oil pressure from? Someone in the thread about the sender install noted that there was a much easier way to do it, but he never posted the pics.
Charlie
wcbjr is offline   Reply With Quote
Old 06-01-2002, 11:14 AM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
There was someone (can't remember the name right now) that was using a sandwich adapter for an oil cooler, but instead of hooking up an oil cooler, he put oil temp and pressure in the openings.
Impreza Rider is offline   Reply With Quote
Old 06-01-2002, 01:43 PM   #3
Avenger
Member#: 1234
This question have been asked many time, I'm sure you'll find many other locations. But since I got nothing better to do, I did a search for the oil filter sandwich for you.
There is a plug you can take off on the passenger side of the engine towards the rear that is also an oil line that you can thread an adapter onto. And the other way was through an oil filter sandwich.
http://www.i-club.com/forums/showthr...t=oil+pressure
Avenger is offline   Reply With Quote
Old 06-01-2002, 03:42 PM   #4
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Notice the Blue and Red fitting in the following oversized picture, that's my oil feed line...
subachad is offline   Reply With Quote
Old 06-01-2002, 03:53 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Yeah, it's amazing what searching can do.
I found the secondary oil gallery plug under the throttle body and intake, which is 1/8 BSPT. I have an Autometer sending unit which is 1/8 NPT. So, I ordered a 1/8 BSP male -> 1/8 NPT male adapter, along with a 1/8 NPT female pipe coupler from Pegasus Racing for $10. The part numbers are 3230-2-2NPT and 3280-02, respectively. I hope the BSP/BSPT conversion will work out...
So, I hope to unplug the plug in the oil gallery(w/ allen wrench), then screw in the male->male adapter. Then screw on the female pipe coupler with the Autometer sending unit on top that. I think there is enough clearance, and this way there are no lines to run except the sending wire to the gauge.
It will be a week or so until I get the parts, so I will post pictures when everything gets done. That is, if it all fits correctly.
Now to find a place to weld on my EGT bung...
Charlie
Old 06-01-2002, 08:11 PM   #6
zaidallas
Member#: 4106
If you go to cobb you'll see the greddy oil filter adapter thingy sitting on the shelf , it has openings that I think you can use for the sender unit.
zaidoun
zaidallas is offline   Reply With Quote
Old 06-04-2002, 03:15 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I believe the Greddy is BSPT, and I am trying to avoid using the sandwich adapter because I don't want to damage anything during repeated oil changes.
2 liter oil pressure? fizzak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-06-2007 07:28 PM
FS: 2001 2.5 RS coupe located in bay area typens83 Private Vehicle 'For Sale' Classifieds 7 04-20-2006 02:01 PM
2.5 New Shoot locations, which one do you like? 6 Pics Yodaman Member's Car Gallery 12 06-06-2005 08:28 AM
2000 2.5 oil pressure larsch13 Normally Aspirated Powertrain 7 08-07-2003 09:33 PM
Defi Adapter or T the OEM Oil Pressure Location Neil Wallerstein Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-29-2001 05:23 PM
