Old 03-25-2010, 12:31 AM   #26
frnciscob
Member#: 225634
05 wrx
black
No I'm using the grimmspeed 3 port boost controller solenoid. I actually have all the supporting mod for the 16g.
frnciscob is offline   Reply With Quote
Old 03-25-2010, 10:16 AM   #27
burtonrider3889
Member#: 163519
2006 Cayman S
Is your boost solenoid hooked up correctly? When I went in for my tune I had one of my ports wrong and overboosted. But he fixed it after one dyno run. If it's hooked up wrong it could be causing you to overboost.
burtonrider3889 is offline   Reply With Quote
Old 03-25-2010, 05:03 PM   #28
frnciscob
Member#: 225634
05 wrx
black
Ill check it just to make sure. But it should be right I used the diagram that came with the boost controller
Old 03-25-2010, 06:44 PM   #29
burtonrider3889
Member#: 163519
2006 Cayman S
Well my problem was that there were two diagrams. One with the restrictor pill and one without. Depending on if you used the pill or not depended on which port your supposed to use. Port 2 or 3. Using the wrong port results in overboost. If that were the case though I'd think you'd be over boosting by a lot though. What's the worse you've overboosted over?
Old 03-25-2010, 07:27 PM   #30
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
you can run a MBC in line with the ebcs to eliminate that
todeswalzer is offline   Reply With Quote
Old 03-25-2010, 09:19 PM   #31
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by burtonrider3889 View Post
And numbers are all relative anyways. I could go back on a cooler day and it could be way higher, or vise versa on a scorching day. I'm gonna try and hit the track to see what I trap to really get an idea.
you r right with numbers being relative....but with yours being corrected they should be about the same no matter what the temp is
Old 03-25-2010, 11:03 PM   #32
frnciscob
Member#: 225634
05 wrx
black
Talking
I have overboosted by 2 psi. Which rounds up to 20 its not much but idont like the feeling of being cut in the middle of scaring the girls
Old 03-25-2010, 11:16 PM   #33
burtonrider3889
Member#: 163519
2006 Cayman S
And your 100% positive your fuel cutting from this?
Old 03-26-2010, 12:00 AM   #34
todeswalzer
Member#: 191495
'05 WRB GTX3071R
read this, i dont know if you have an EWG or not but it might help
http://forums.nasioc.com/forums/show...ight=tial+44mm
Dyno Tune: 2.5L + Blouch EvoIII 16G makes 354whp jonpark Proven Power Bragging 8 05-31-2010 10:02 PM
Dyno Tune: 2.0L + VF43 makes 285 whp dsolis Proven Power Bragging 54 04-05-2010 06:34 AM
Dyno Tune: 2.0L + TD04 makes 242whp 263WTQ (Epic Motorsports) fl4tsc Proven Power Bragging 17 02-05-2010 03:31 AM
Precision Tuning Dyno Tune: 2000 Swapped GC8 Evo 3 16g 315whp corzy666 Proven Power Bragging 9 01-04-2010 02:32 PM
Dyno Tune: 2.3L + Blouch GT30 XT-R on E85 makes 587bhp JAKbauer24 Proven Power Bragging 28 11-16-2009 01:49 AM
