Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 03-22-2010, 10:27 AM   #1
MJBrowny21
Member#: 48000
2002 Impreza WRX
Default Reverse lights dont turn on
so I noticed my reverse lights dont turn on when I'm in reverse. By looking at threads I'm assuming this looks like it can be solved by replacing the reverse light switch. Anybody ever done this before themselves? Easy install?
Thanks,
Mike
MJBrowny21 is offline   Reply With Quote
Old 03-22-2010, 11:51 AM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Thanks,
Mike
First think I'd do is get the 2002 WRX wiring manual (service manual) and use it to check the reverse position sensor signal at the connector by the pitch stop mount. If it's faulty, you know it's a defect either on the harness on the trans or with the sensor its self. From there move down and look for any thing obvious (broken wires or disconnected plug). Next, test the signal at the connector between the sensor and the trans harness.
I can't remember if it shows open or closed when the car is in reverse. Eitherway, you should see a change in state when the car is in 1 thru 5 or neutral vs reverse. The service manual tells you what it's supposed to read.
I've had one of these sensors fail. It really is easy to replace on the 5MT (the 6MT is pretty easy too). It is literally as simmple as disconnecting a connector and then using a single wrench to uncrew the sensor from the case. Remove, replace, job done.
Old 03-22-2010, 11:53 AM   #3
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
did you mess with the switches prior to this happening or anything else?
gingertooth is offline   Reply With Quote
Old 03-22-2010, 12:26 PM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
did you check to make sure the bulbs didn't just die??
Before you get more intense do that because it's easy and common
ProdriveDreams is offline   Reply With Quote
Old 03-22-2010, 01:09 PM   #5
MJBrowny21
Member#: 48000
2002 Impreza WRX
Thanks for the input. I have not messed with any wires prior to this. I didnt test the bulbs either thinking what are the chances that both went out.
Old 03-22-2010, 05:14 PM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I had all 4 brake lights go out on an older car. Parking lights still worked though. Do no doubt. And follow the cheapest path first
scoobdude is offline   Reply With Quote
Old 03-22-2010, 05:25 PM   #7
jeksone
Member#: 241915
Thanks,
Mike
I'm sure its been said but, bulbs go out.
also if you put the bulbs in backwards.
An maybe just maybe racer x came by in his evo and stipped a wire just to mess with you.
^_^
jeksone is offline   Reply With Quote
cruise control lights dont turn on. scoobynoobEMT Electrical & Lighting 4 02-04-2010 10:58 AM
Reverse Lights Not Turning On...Fuse is Fine. XanRules Electrical & Lighting 3 05-18-2009 12:24 AM
Reverse light dont work and CEL's Twiztidunreal Electrical & Lighting 1 08-06-2008 12:50 PM
reverse lights won't turn off. asherbo Vancouver Impreza Club Forum -- VIC 8 02-24-2007 02:07 PM
Reverse Lights Dont Turn On - Help michyous Legacy Forum 5 04-16-2005 10:54 PM
