Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 03-22-2010, 07:19 PM   #1
speedymaker
Member#: 162070
2005 VF48 wrx wagon
Default Fuel pump continously priming on swap
So I swapped a 2005 wrx engine into my 05 rs....car runs fine, even just upgraded to a bigger turbo, only one problem
The fuel pump always primes, it should prime for a few seconds then shut off, so something is wrong. I put in a wahlbro 255 pump so I know its strong enough to get fuel pressure. Is this a big deal, because Im sure is shortening the life of the pump. I wired in the fuel pump controller following the FSM so it should be correct. Not throwing any codes whatsoever, so who can help?
speedymaker is offline   Reply With Quote
Old 03-22-2010, 08:20 PM   #2
davis10
Member#: 70011
You should double check the wiring to the fuel pump controller.
davis10 is offline   Reply With Quote
Car Wont Start... Fuel Pump Not Priming... Any Ideas? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-09-2011 03:35 PM
Fuel Pump not coming on... SikSilvrSuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-17-2010 06:27 PM
Fuel Pump wont prime!! 02ej257 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2006 03:45 PM
Fuel Pump not priming ** prodriveuk Newbies & FAQs 3 04-15-2006 01:13 PM
fuel pump not priming/ecu not on? attitude Engine Management & Tuning 16 06-24-2005 12:16 PM
