Old 05-06-2001, 08:10 PM   #1
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Post Front end shudders! HELP!
Has anyone had problems with their RS shuddering at low speed turns. Say you are sitting at a red light and decide to switch lanes.... as I turn the wheel and the car just barely starts to move, the whole front end shudders. It is not clutch/tranny... is is DEFINITELY steering related...
Ideas? Anyone?
EDIT: Too mad to spell.
[This message has been edited by Texas25RS (edited May 06, 2001).]
Texas25RS is offline   Reply With Quote
Old 05-06-2001, 08:20 PM   #2
Accurit
Member#: 4636
2001 1st Gen
Post
never had that problem
Accurit is offline   Reply With Quote
Old 05-06-2001, 10:41 PM   #3
Dissenter
Member#: 3777
03 Yellow WRX Wag
I drive the short bus.
Post
Are you SURE it's not your clutch operation? I can't think of anything else that could cause low speed shuddering like that.
Dissenter is offline   Reply With Quote
Old 05-06-2001, 10:55 PM   #4
YahDude
Member#: 5783
2001 2.5RS
Rally Blue Pearl
Post
hmm, experienced that tonight, and once the other night too, but it was very suddle.
YahDude is offline   Reply With Quote
Old 05-06-2001, 11:04 PM   #5
Frey Bone
Member#: 6252
2000 GC8 w/STI
Post
I've also had that. It only happens when I let out my clutch when the enginge is cold or I get sloppy. I'm also thinking you may have a problem with the power steering (if it only happens when you steer) your fluid may be low and the pump is getting messed up cause your fluid level is way low.
If it happens when starting at low speeds when you are going straight, then its the clutch thing, I have the smae thing going on w/mine ...probably really bad and costly, I'm sure its from me driving it into the ground....
Frey Bone is offline   Reply With Quote
Old 05-06-2001, 11:23 PM   #6
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Post
It has absolutely NEVER happened in a straight line. I have tried everything and the only thing that makes the car shudder is the low speed turn.... I can take the car down to almost stall line in a straight line and the car will pull out without even a peep... just when I turn the wheel.
BTW Mine started real gentle, but then it feels like it is shaking like I am going over stutter bumps or something. It is bad now.
02 wrx to 04 STi front end swap, help with headlight wiring Unlikely Hero Electrical & Lighting 12 03-25-2011 01:40 AM
Bugeye(02/03)- Peanut Eye(04/05) Front End Swap HELP 20BlueWRX02 Interior & Exterior Modification 91 12-11-2010 06:43 PM
2003 wrx to 2004 wrx front end swap help nicerb Subaru Conversions 1 08-12-2009 03:19 PM
Front end dev help needed Cartwright Off-Topic 4 09-10-2007 10:59 PM
Front End shudder Impy General Forum Archive 6 07-16-2000 09:37 PM
Message Board Statistics All times are GMT -4. The time now is 03:01 AM.
