Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 03-31-2010, 04:46 AM   #51
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
I am also interested to see pics of this.
It is kind of hard to picture how you are going to drill all those holes. If I understand correctly, the way you are going to make it, it will bypass the filter all together.
Why don't you just buy a piece of aluminum round stock from somewhere for like $15?
What about a thermostat? That is one thing you can't really do yourself. If I was ever going to put an oil cooler on my WRX, I would buy a Mocal filter adapter with a built in thermostat. They are only like $110.
FourOnTheFloor65 is offline   Reply With Quote
Old 03-31-2010, 08:27 AM   #52
relliMmoT
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
Because a sandwich adapter that would be efficient for the whole thing would cost $20 on ebay
Only DIYers doing it for the cause of DIYing it around the Fab forum.
relliMmoT is offline   Reply With Quote
Old 03-31-2010, 09:34 AM   #53
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
You really need a t-stat anyway, and an inline is more expensive than a sandwich adapter with one built in. Not to mention if you make one mistake machining a custom sandwich adapter and create a restriction, you just killed your motor. Just concede, buy a mocal thermostatic sandwich adapter, and have a system that actually works.
boost junkie is offline   Reply With Quote
Old 03-31-2010, 11:10 AM   #54
relliMmoT
Member#: 206931
2004 WRX Wagon
$100 vs $20 vs free for something thats probably not going to fail in his application.
Its like.. I better buy a cryogenic treated shot peened grade 5000 $100 racing lug nut next time because well.. you never know right?
Hes not spending anything on the project. Its all parts from the garage and custom fab parts.
Old 03-31-2010, 12:21 PM   #55
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
You aren't reading what I wrote. He will have to buy a $120 inline thermostat anyway. So it makes more sense to just spend $95 on a sandwich adapter with one built in. Then you have your thermostat AND don't risk grenading your expensive motor with an oil restriction in an improperly designed part. Why is this so hard to understand?
Old 03-31-2010, 01:15 PM   #56
Maverick7531
Member#: 234291
2002 WRX - '04 EJ257
w/ ECU & Fuel -'04 5MT
Originally Posted by Patrick Olsen View Post
Wow. Please post pictures of the finished product when you're done.
Definitely... will do!
Maverick7531 is offline   Reply With Quote
Old 03-31-2010, 01:18 PM   #57
Maverick7531
Member#: 234291
Well its not really a big problem... thats what feeler gauges are for. Since the holes will intersect and be drilled to no less than the specs of the smallest part of the filter, than it wont be restricted.
Plus as a machinist by trade.... its not really going to be a problem.
Old 03-31-2010, 01:23 PM   #58
Maverick7531
Member#: 234291
I'm also not planning to use a thermostat unless I find one that is really cheap.
And if I were using one, A housing for it would not be any harder than making the adapter a two piece design. I would just mesh the 2 halves together threaded just like the filter onto the motor, and seal it with an o-ring. It really wouldnt be hard.... AND STILL, I would have complete control over where I would want to put the holes, and how many.
And as far as "why don't I just go buy a piece of aluminium stock"... well why spend the money when I can just use junk metal laying around, not spend anything, and go out side of the bounds of my project???
Old 03-31-2010, 01:30 PM   #59
Maverick7531
Member#: 234291
The part where you think it seems like I'm bypassing the filter... I think i accidentally explained machining the top side around the bottom where filter mates up. So... it will work. Sorry for the explaination.
It will go in just like entering the filter. Go through the cooler, then back into the adapter and down into the filter. Then it will come back out and into the motor.
It's not a complicated device. It is just a directional piece that has to be created with volumes no less than the area of the smalles piece of the filter.
Old 04-01-2010, 12:25 AM   #60
relliMmoT
Member#: 206931
2004 WRX Wagon
BAM! [/win] OP has a particular plan and hes pretty set on sticking to not buying anything but fabricating everything himself. The thermostat is a good addition however its pretty much just the same insurance of the example I used earlier. Weve already discussed in depth the disadvantages of having oil too cool and the merits of a thermostat but its just not something that will be used.
Old 04-01-2010, 09:23 AM   #61
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
And that's a mistake, especially on a street car that will rarely see high enough oil temps to require an external cooler. Do I care? No, it's not my car. But why start a thread if you aren't going to listen to sound advice that's based on experience NOT theory?
Old 04-01-2010, 11:13 AM   #62
relliMmoT
Member#: 206931
2004 WRX Wagon
I can definitely agree that he should use a thermostat if hes going with that setup; living in PA there is going to be some super chill oil temps at times if his oil cooling system works out well.
Old 04-01-2010, 10:09 PM   #63
Maverick7531
Member#: 234291
Just because you don't believe I am listening to advice doesn't mean I'm not. Yes, I have a street car... but It does see high temps often... it is driven hard. At oil changes in the winter I will remove the adapter and plug the cooler... and i am planning on making a bypass tube to re-route everything at the turn of a knob. So, if I know I am just going on a long highway drive I can turn it off. However, a lot of the time I am aggressively driving and usually run higher temps than most DD's can fathom.
And a bypass would be as easy as running a "T" right after the cooler's "in" line, before the checkvalve. Right after the "T" I will have a valve that I can open or close(big enough of course to not restrict anything-and with a locking mechanism to ensure accurate volume.) The 3rd end of the "T" will run to a short hose that connects to a similar "T" in the "out(or back to filter adapter" line. Since the flow will be blocked when the valve is closed the oil will travel out of the adapter, through the 90degree "T" across the short tube and through the other "T" and into the adapter on the other side. Of course the short tube between the 2 "Ts" will have the same on/off valve as in the "in" line... as to ensure flow through the cooler on command.
As you can see the flow will not be hindered at all, and the bypass will allow me to control the cooling based on temp/pressure readings.
YES... I know it is manual and will require me to get in and out of the car, and I would be doing the same job as the thermostat... but if I decide to get a t-stat in the future, then I can just replace the "in" "T" with a custom housing for the T-stat that will divert the oil from the cooler directly to the "out" line. Remember, with the check valve in the "in" line after the "T"/t-stat housing, the pressure lock created in the remainder of the "in" line and cooler, all the way until the "T" in the "out" line will keep the cooler full, and not hinder the flow of the diverted oil.
Old 04-01-2010, 10:17 PM   #64
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Either you drive like an absolute ass-clown on the road, in ways that are well beyond what any responsible auto enthusiast would ever do, or you just don't understand what sort of driving it takes to get oil up to really elevated temperatures.
Like what sort of temperatures? I'm too lazy to go back through the thread, but I don't remember you mentioning anything about having an oil temp gauge or any temperature data.
Old 04-01-2010, 10:24 PM   #65
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
Damn, you stole my thunder.....
I was going to ask the same question. I didn't notice anywhere the OP mentioning an oil temp gauge. Could this be one of the parameters from his butt dyno?
gagliano is offline   Reply With Quote
Old 04-02-2010, 09:22 AM   #66
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
So you're going to add a bunch of potential failure points and create the need to manually control flow to the cooler? What are you using to measure oil temps, and at what temp will you decide to divert flow through the cooler?
Old 04-02-2010, 10:15 AM   #67
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yeah, but he's going to make all of these valves with melted down intercooler bits, so it won't cost him anything!!! This is going to be sooooo much easier than just buying a sandwich adapter with a thermostat in it.
Old 04-03-2010, 02:51 AM   #68
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
I am all for experimenting, but you are taking this to far.
Just buy a Mocal one, and be done with it.
Ok, the item will be free, but the time you are using for this project could make it more expensive in the end.
Dutch Scooby lover is offline   Reply With Quote
Old 04-12-2010, 02:48 AM   #69
fallehero_08
Member#: 214110
i am honestly tempted to start threads like this, just to see how many people i can piss off as my posts get more and more insane... this guy is the king of it.
either he is, A, flat broke and too lazy to get a job, so hes going to tinker around in his garage all day. or... B, serious about all this, doesn't learn from his own pile for scrap parts, and is interested in seeing how fast he can destroy his new engine. (which he could afford... but cant afford to buy a few simple project bits.
so, to add to this cluster****, if your interested in cooling the oil without cooling it too much, why not tap into the existing oil filter coolant lines, add a small pump and a small reservoir, make it all pressurized, and run a separate cooling system for the oil alone with a cooler in the line that you previously thought was an oil line. let me know if that tickles your neurons... if not i have plenty of other suggestions.
fallehero_08 is offline   Reply With Quote
Old 04-13-2010, 11:30 PM   #70
Maverick7531
Member#: 234291
Yes... I do have an oil temp gauge, connected to a sending unit running off an existing greddy sandwich filter(just not a one way that is capable of running an oil cooler)
I reach high 250's often... sometimes higher. (Of course I don't know what I will hit once I get the new motor running with all my mods and then tuned.)
Those numbers were on an '02 EJ205:
-TBE-Catless(ported[DP/turbine housing mating area])
-Up-pipe(ported)
-Ported stock exhaust manifolds/head exits
-Ported turbo(turbine entrance and wastgate)
-Ported crossover pipe
----all previously listed were ported to match and gasket matched----
-Custom intake(K&N filter)
-Custom boost controller
-HKS SSQV BOV(Atmospheric)
-CX Aluminium Racing Radiator
-NGK Platinums
-I May have a FMIC set-up by the time I get it running, and who knows what kind of Engine management I'll go with.
Gauges: Autometer Cobalt (Boost, Oil Pressure/temp, A/F Ratio, Volts, EGT)
Old 04-13-2010, 11:36 PM   #71
Maverick7531
Member#: 234291
So I like to fabricate stuff... its not hard for someone with metal working/ engineering skills. I'm almost done with my Strut tower brace... but I got the wire harnesses so I stopped and stripped my car... I have a lot of work to do right now so I'm not so concerned with playing around with things until my car is running again.
THEN, I will decide if I'm gonna make a small sandwich adapter to go under the greddy one, or if I can drill a hole in the side of the greddy one, and insert a tube that will make it a one way unit so I can hook up my cooler. Then finish my STB.
Old 04-13-2010, 11:40 PM   #72
Maverick7531
Member#: 234291
All for the suggestions... thats what this post is for... NOT the negativity
It's not a "waste of time" if its fun! I like making stuff, and I'm good at it... Why do all you people have a problem with that... RELLIMMOT is the only one that seems to be using this forum the way its supposed to be used!
Old 04-14-2010, 12:02 AM   #73
Maverick7531
Member#: 234291
Through all of your incredibly arrogant and absurdly abusive comments I have still managed to get a lot of information I was looking for.
Its a sad moment that I'm sure many will have when they objectively look at these posts and see what kind of people this community is made up of. It's sickening to think that the world is comprised of people like most of those who posted here.
There is no need for comments like the ones in this post... I really don't understand where you think you get off acting the way you have-thinking you know everything-trying to make people do what you want-getting mad when they listen but question what you said/or your logic-and you are to caught up in yourself to see that they are arguing, not to fight, but to rebuttle to find a better answer. I hadn't made any decisions, or came to any firm conclusions throughout this whole post... I just sought out infromation and questioned convention, illiceted thought, and hoped for thoughtful answers. Some gave me that(which is what this community is for.) but to those that just said "do this," or criticized question... you just don't belong, and the sad part is... you will be the ones to reply with something stupid to this message...and you won't even know that you are more of a hinderance than a help.
To those that were truely a help, and even to those that were horrible, but incidentally offered good information-I really do thank you, and I hope in the future that the info is more pure and good natured than what was displayed here.
I might not be done looking for info... but for now I think I have gotten most of what I need.
Old 05-30-2010, 10:15 PM   #74
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
How's this project coming along? Have you successfully melted the intercoolers and turned them into a free sandwich adapter yet?
Old 05-31-2010, 11:02 PM   #75
eg33GC
Member#: 206851
56 Belair
Pro Street
are the glowshift sandwiches junk?
eg33GC is offline   Reply With Quote
Oil Cooler Location and Need for Oil Cooled Only Turbos dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-19-2004 07:51 PM
oil cooler location, too high? vile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-09-2003 11:27 PM
Oil cooler/remote filter mounting locations? kidatari Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-29-2003 04:36 AM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 10:40 AM
oil cooler mounting location newbie sewbie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-09-2002 10:43 PM
