Old 06-01-2010, 03:02 PM   #76
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Hard to tell just from pictures, but the pictures look good at least. Looks like the -10AN fittings could use some Dowty seals where they screw into the sandwich plate. And although I like the fact they included gauge sender ports, if you've got gauges with BSPT/BSP senders (like basically every gauge not made in the US) then they're not the right thread.
Old 06-01-2010, 03:26 PM   #77
eg33GC
Member#: 206851
56 Belair
Pro Street
I'll be using their most expensive gauges(hopefully most quality), so I bet it will fit.
I'm feeling some teflon tape at the fittings?
eg33GC is offline   Reply With Quote
Old 10-24-2010, 02:26 PM   #78
Red_Wrx
Member#: 158658
I got a custom made bracket I had made, this bracket holds your oil cooler inside on the bottom passenger fog cover. Let me know if u want it.
Red_Wrx is offline   Reply With Quote
Old 10-27-2010, 01:13 PM   #79
drag_star
Member#: 230997
Hi fellow Nasioc,
Does anyone know what the best way to relocate the power steering cooler line and how (e.g cut it and weld it back to below of the oil cooler)? I find its blocking space for my mocal 19 row .Any ideas guys , much appreciate it . Here the pic :
drag_star is offline   Reply With Quote
Old 11-01-2010, 09:52 PM   #80
prometheum
Member#: 92003
04 bicycle!
uuuh oil barely trickles through the turbo
prometheum is offline   Reply With Quote
Old 11-01-2010, 10:01 PM   #81
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Thats what I was thinking.
OP,
If you want to avoid a sandwich adapter then hook up two -8 lines to the oil pan and use some kind of electric pump to cycle the oil through an oil cooler or something. You could even make the pump thermostat activated.
OR You could just do it the tried and true method that works well and use the sandwich adapter with -10 lines to a high efficiency core such as a Mocal or Setrab.
dexterous is online now   Reply With Quote
Oil Cooler Location and Need for Oil Cooled Only Turbos dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-19-2004 06:51 PM
oil cooler location, too high? vile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-09-2003 10:27 PM
Oil cooler/remote filter mounting locations? kidatari Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-29-2003 03:36 AM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 09:40 AM
oil cooler mounting location newbie sewbie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-09-2002 09:43 PM
