Alaskan Impreza Club
Old 05-13-2010, 09:30 PM   #226
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Originally Posted by kyletakahero View Post
What is a fast spooling turbo?
Something good for rally/autoX.
I don't need a **** ton of power, just enough to make a difference.
td04 is a pretty fast spooling turbo after that id look at a vf34.
Alaskan EJ20 is offline   Reply With Quote
Old 05-13-2010, 10:23 PM   #227
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Hmm, I have a extra TD04, would it be best to port and polish?
Would that even be that beneficial to spool time?
Plus, would tuning also help when it comes to getting a faster spool?
kyletakahero is offline   Reply With Quote
Old 05-13-2010, 10:33 PM   #228
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
^yes but it will take away from the motor power at that instance, you can make the exhaust denser buy dumping more fuel but if its greater than RBT (rich best torque)the motor will loose some power. im sure seth can add to this.
Old 05-14-2010, 02:44 PM   #229
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
vf-34 or vf-39 cheap and fast spool. Wouldn't bother with port/polish for what you asking for. Keep the pipes short and stick with a TMIC and spool should be fine. Dumping fuel or screwing with timing to help spool times is a round about and not very consistent method, results tend to vary and you pay a price of power loss somewhere along the line.
There is a balance between power and spool. Before you buy or decide on a turbo try riding with or driving cars that will be simular to your future setup. Go with what you like.
P3Auto is offline   Reply With Quote
Old 05-16-2010, 12:55 AM   #230
anthonyss
Member#: 246879
1999 audi
blue
Default black sti at dodge?
does any one know who owned it and what not i need to know the pro's and con's my friend is in the process of buythis thing and she is a girl so any one want to chime in?
anthonyss is offline   Reply With Quote
Old 05-16-2010, 03:18 PM   #231
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
^^ I would post this out as a thread maybe you would get better response. I have no idea what car that is btw.
Old 05-17-2010, 02:30 AM   #232
klanner
Member#: 182154
93 Sentra RS
How much wood could a woodchuck chuck, if a woodchuck could chuck wood.
klanner is offline   Reply With Quote
Old 05-17-2010, 07:13 PM   #233
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
A woodchuck would only chuck as much wood as Chuck Norris would allow it to, because the woodchuck shares Chuck's name. Therefore, Chuck must punish it and make it chuck as much wood as Chuck can. So, a woodchuck would chuck as much wood as Chuck could.
Old 05-25-2010, 01:06 AM   #234
klanner
Member#: 182154
93 Sentra RS
Thanks!
Old 05-25-2010, 03:07 PM   #235
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Texas Ranger Ninjas know all, do stronger wastegate springs mean less duty cycles on wastegate trickers to obtain more boost??
Old 05-25-2010, 03:45 PM   #236
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Yes the closer you are to your target boost the less work the wastegate and solenoid have to do and less wastegate duty cylces in the tune. It also makes things a lot easier to tune and control.
You will also be able to hold more boost towards redline IF your wastegate was pushing open from to much back pressure. << This is not always a good thing to do however since there is a chance you may to over spin a turbo and blow a lot of hot air as well as raise EGTs.
Old 06-15-2010, 12:54 AM   #237
iLuv-Bo0st
Member#: 198200
2006 STI
Hey so i Have around 2000$
I have a stage 2 sti currently that is tuned. I am looking for some more power and want to go with a bigger stock location turbo/infectors/fuel pump and then do intercooler etc.... down the way. Im looking for a pretty fast spooling turbo as this is my daily driver in canda Winter/summer. I do the odd Auto X, stratotech lapping and even the 1/4 mile. Just want something I will notice a difference with and be happy with the power. Should I go with something like a 20g Or stick to 18g/EVO III 16 G? Advice ? Thanks !
iLuv-Bo0st is offline   Reply With Quote
Old 06-15-2010, 01:43 AM   #238
Brando5185
Member#: 189926
2006 GC 5.7L
I was same boat and went with 20G. Glad I went with it now. Spools enough at autoX unless course is really tight. And runs decent in 1/4 as well.
Brando5185 is offline   Reply With Quote
Old 06-15-2010, 04:27 PM   #239
iLuv-Bo0st
Member#: 198200
2006 STI
Okay what about the HTA68 ? should i bother with a 16g or will i not see much improvement?
Old 06-15-2010, 04:41 PM   #240
bradfield
Member#: 117116
05 LGT Wagon
Check out the new Dom 2.5xtr, I've only had it for a few days, but love it.
bradfield is offline   Reply With Quote
Old 06-15-2010, 09:56 PM   #241
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
30r and be done with it.
Old 06-16-2010, 01:30 AM   #242
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
2.5XTR..We installed the one for Bradfield ...It spools faster then my DOM3 and makes the same power as a DOM3. I can also get you one for a killer price or any other turbo.
20G is also a nice choice and the STI's seem to take to them very well.
Keep in mind without an upgrade to the TMIC or going with a FMIC your going to have a major air flow issue until you do.
Old 06-17-2010, 02:37 AM   #243
iLuv-Bo0st
Member#: 198200
2006 STI
I will be upgarding to front mount not to long after. So the 20g vs the 2.5 xtr. Would I also need a new downpipe sonde mine is his and it isn't bellmouth? What kind of numbers would I be looking at with Turbo injectors fuel pump?
Old 06-17-2010, 01:45 PM   #244
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
If you do the FMIC, turbo, injectors, etc, we know you can do low 12's. Octane (fuel quality) will be your road block after that. You will need water injection or a race gas tune to get into the 11's. You will also be pushing your motor to its internal limits.
Old 06-17-2010, 03:31 PM   #245
iLuv-Bo0st
Member#: 198200
2006 STI
Ya After the front mount I will most likely get the motor built but that will come later. What are a good injector to go with for the 20g ?2.5 xtr ? Would a evo 3 16 g not be to
much of a difference compared to stage 2?
Old 06-17-2010, 03:35 PM   #246
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
I would skip the 16g at this point. It would be an upgrade but you would grow tired of it quickly.
DW 740CC side feeds are good injectors and will be more than enough for your requirements. If you plan to build up later and break the 400whp level then 850cc might be better especially if your not running water/meth, more fuel required.
Old 06-17-2010, 04:28 PM   #247
iLuv-Bo0st
Member#: 198200
2006 STI
Okay I may run water/meth down the road. Will
I need a new downpipe since mine is not bellmouth ?
Old 06-17-2010, 06:25 PM   #248
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Which pipe do you have exactly now?
Old 06-17-2010, 08:04 PM   #249
iLuv-Bo0st
Member#: 198200
2006 STI
Hks downpipe
Old 06-17-2010, 08:26 PM   #250
Brando5185
Member#: 189926
2006 GC 5.7L
I run an HKS downpipe with a 20g.
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 16 11-06-2014 02:12 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
