Alaskan Impreza Club
Old 07-01-2011, 03:02 PM   #451
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Sounds like you blew a hose or created a boost leak. Check all hoses first before you get to crazy.
Originally Posted by 02SportWagon View Post
Alright. So here's the deal I was dialing in my settings for my stage 2 map and I was pulling hard in 3rd gear. Hit target boost of 17.3psi, Then it knocked hard, cut timing and fuel. Now im running only 7psi of boost even after I reset the ECU and flashed it back to the Cobb stage 1 map. Please help?
P3Auto is offline   Reply With Quote
Old 07-01-2011, 08:28 PM   #452
02SportWagon
Member#: 224751
2002 WRX Wagon STG 2
Alright. I'll check. Should I do a pull and log to see what it could be after I check? But I'll start simple first.
02SportWagon is offline   Reply With Quote
Old 07-02-2011, 07:59 PM   #453
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Don't do any pulls until you find out what is wrong. You could do much more damage.
Old 07-05-2011, 11:26 AM   #454
02SportWagon
Member#: 224751
Yeah. No boost leaks...
Old 07-24-2011, 09:26 PM   #455
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Check it out Seth! I know we talked about it a little while I was getting the windshield changed. Let me know.
http://forums.nasioc.com/forums/show....php?t=1996741
The family mover needs to be faster! lol
LiLpNoY is offline   Reply With Quote
Old 07-25-2011, 01:48 PM   #456
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
If you are willing to try and tune it we would take a shot at it. I have some experimental stuff from my B9. You would just have to be willing to provide feedback and understand it would be a project that will take some time to perfect.
Old 08-16-2011, 01:27 AM   #457
BackflipJeff
Member#: 291485
2007 Wrx wagon
Satin white
What type of exhaust would everyone recommend? I've been looking at some Cobb or hks hi-power any other suggestions
BackflipJeff is offline   Reply With Quote
Old 08-16-2011, 01:36 AM   #458
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
I recommend watching lots of YouTube videos, meeting up with other Subaru drivers and listening to what they all sound like and figure out which you like best. Also which design slanted, straight, canister, etc... Also how much your willing to spend, if I run a Greddy Ti. If I were to do it again, I'd spend the extra cash on a pure titanium for the weight savings.
Old 08-16-2011, 01:48 PM   #459
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Pay attention to details on exhaust systems. Some of them are not true 3in systems, others have 2.5in flanges that open into a 3in. Some cobb systems taper down at the muffler, etc, etc.
If your running a stock turbo then looks and sounds may be all you need to worry about.
Downpipes are very important to pay attention to. We have actually swapped down pipes around on the same car to test different ones. There can be noticeable differences in spool times between various pipes. Power wise I cannot say for sure without a dyno.
The best spooling downpipes we have found are the really large turboxs bellmouth or the invidia divorced pipe. Worse pipe so far has been the ebay knock offs that use blocking plates or ones that are just 3in pipe straight out.
Old 08-16-2011, 02:38 PM   #460
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
The downpipes that look like the HKS (blocked wastegate) work great for when you do an external wastegate setup but not so great for internally gated, bellmouth or divorced downpipes are going to work great but that is depending on quality of manufacture , alot of the eBay knock offs I've seen are crap
tribalwrx is offline   Reply With Quote
Old 08-18-2011, 12:42 AM   #461
Grooveygrover
Member#: 291774
2011 wrx s.t.i.
charcoal grey/silver
Post understanding terminology
I have just purchased my first ever wrx sti and I am very uneducated on most aspect of the car and the terminology. I would appreciate any tips or info any one can share. For instance, what exactly is a cat-back exhaust? I understand the exhaust part, it's the cat back part that has me guessing. Does this mean that when installing the upgraded exhaust that you permanently removing the catalytic converter? Please forgive me, I don't know much yet but I learn quick. Is there anything special i need to know about the car when it comes to driving it in the winter, other than your basic winterization and change out to siped or studded tires? I live in Fairbanks alaska and as most Alaskans know we can easily see 50 below for a week or two at a time. Also I am looking for advice on some basic mods for the car, like air intake, and exhaust, and basic chip programing upgrade packages. And finally the fuel issue, with the car in stock mode and running premium pump gas, do I still need to add an additive and if so what kind.
Grooveygrover is offline   Reply With Quote
Old 08-18-2011, 12:53 AM   #462
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
I'll save you lots of time and trouble. This thread is about the easiest way to learn fast.
http://forums.nasioc.com/forums/showthread.php?t=533787
retrac is offline   Reply With Quote
Old 08-18-2011, 01:06 AM   #463
Grooveygrover
Member#: 291774
2011 wrx s.t.i.
wow, that was fast, thank you!
Old 08-18-2011, 01:21 AM   #464
Grooveygrover
Member#: 291774
2011 wrx s.t.i.
Thanks again for the tip, I got all of my questions answered and more :-))
Old 08-18-2011, 01:34 AM   #465
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Anytime.
Old 08-19-2011, 03:53 PM   #466
Tripster
Member#: 226944
2009 Subaru SSM
Element Auto Sponsored
Looking to get a Grimmspeed EBCS and they require a tune. How do I go about the tune. I currently am using a Cobb AP Stage 2 tune.
Thanks,
Dustin
Tripster is offline   Reply With Quote
Old 08-19-2011, 04:01 PM   #467
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Thanks,
Dustin
call Seth, P3 Auto. Last time I talked to him, he had them in stock.
Old 08-19-2011, 04:17 PM   #468
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Tripster,
We can do that for you no problem. Do not try to install it without a tune though the boost control duty cycles will be about 30% over what you need and can cause some serious over boost.
Old 08-29-2011, 02:01 PM   #469
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
Hey Seth,
My car is arriving here in early October, and I'm looking into switching in a VF39 with supporting mods. Can you do a tune for me. Mod list is: 04 WRX, 3" Catless Exhaust, VF39, STi pinks, FMIC, Perrin Turbo Inlet w/ Cobb Short Ram.
Ethan_Drift is offline   Reply With Quote
Old 08-29-2011, 02:04 PM   #470
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
No problem at all.
Originally Posted by Ethan_Drift View Post
Hey Seth,
Old 09-05-2011, 12:49 AM   #471
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Is a wideband needed for a tune? Thinking about picking this up: http://www.innovatemotorsports.com/products/MTXL.php
But would rather spend on other other areas if it's not needed.
kyletakahero is offline   Reply With Quote
Old 09-06-2011, 01:24 PM   #472
STi_Miller
Member#: 285724
2006 STi
Seth, just did a pull yesterday where I hit 21.5 psi boost in 3rd gear @ 5k rpm. Fuel cut and CEL popped saying external wastegate solenoid a range/performance. Just been running the Cobb AP stage 1 tune. Would getting a specific tune help solve this overboosting problem? Currently running Invidia 3" cattback, and K&N typhoon SR, stock turbo.
STi_Miller is offline   Reply With Quote
Old 09-06-2011, 01:51 PM   #473
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
You do need a wideband to tune your own car... Having a permanently installed wideband gauge is a good idea for a number of reasons. Being able to see your AFR allows you to see problems such as, boost leaks, vac leaks, fuel system issues, ignition problems, etc. The only problem with wideband gauges is the sensor which has a short lifespan. Most innovative products use a very common wideband sensor that you can get locally however for about $90.
Old 09-06-2011, 02:06 PM   #474
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
The over boosting issue may be what is referred to as "boost creep". True boost creep is a mechanical issue and cannot be fixed with a tune, however you can be tuned to handle the additional boost as long as its not excessive. Typically with a car like yours and those mods you would benefit from a good custom tune. You may also want to try switching to the Cobb AP stage 2 tune for a quick fix maybe.
Keep in mind there are many possible causes for your over boosting including faulty or failing components or boost control line leaks or breaks.
Old 09-14-2011, 10:22 PM   #475
bornready30
Member#: 288364
is the fuel here in anchorage sufficient enough to run a cobb stage 2 map?
bornready30 is offline   Reply With Quote
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 16 11-06-2014 02:12 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
