Alaskan Impreza Club
Old 05-21-2013, 02:42 AM   #726
yambeezy23
Member#: 347347
2013 Wrx Hatchback
Originally Posted by Nomadgene View Post
Oh yeah, which local dyno did you use? Where are your printed dyno sheets. Please post them.
I went to Element auto. I didn't get any sheets.
yambeezy23 is offline   Reply With Quote
Old 05-21-2013, 12:44 PM   #727
BackflipJeff
Member#: 291485
2007 Wrx wagon
Satin white
That sounds about right for stage 2 even without a dump sheet there more than enough evidence to show that it should be anywhere 10+/- of that. And to help you out where you should go from here if you want another power upgrade get a methanol kit their worth their weight in gold and is easily one if the smartest and most substantial upgrades you can do to your car!!! But I'd say work on some suspension to help balance the car better!!!!! Either way have fun with your car!
BackflipJeff is offline   Reply With Quote
Old 05-21-2013, 03:04 PM   #728
yambeezy23
Member#: 347347
2013 Wrx Hatchback
Yeah, they were telling me I should go for some 850cc fuel injectors next because I'm almost maxed out with the stock injectors. Just trying to see where my money should go. I'm done paying off my car, and all the mods are paid in cash since i hate buying mods on credit.
Old 05-21-2013, 06:33 PM   #729
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Originally Posted by cosseywrx View Post
Romraider or the Ap i assume. I dont mind the romraider software. I beleive it gets pretty close to the right numbers
no where close, go log it up hill and take a reading then try it down hill. its way off, i got it to read 355 hp on my stage 2 stock engine forrester with a td04. If you want a real reading of power over stock you should have gotten a base dyno before mods and then run the same dyno after mods to see the gains.
Alaskan EJ20 is offline   Reply With Quote
Old 05-21-2013, 11:40 PM   #730
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
You are not suppose to do it on a hill. Flat road as possible. Says that right on romraiders website.
cosseywrx is offline   Reply With Quote
Old 05-22-2013, 01:15 AM   #731
bjcarter2
Member#: 227288
2006 MCS JCW
Pepper White
I did a standing start pull to 70 once and Dynolicious rated my FSXT at 455hp. I think it's a little off.
bjcarter2 is offline   Reply With Quote
Old 05-22-2013, 01:17 AM   #732
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Talking
Made my millennium.
Nomadgene is offline   Reply With Quote
Old 05-22-2013, 01:25 AM   #733
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
Drivers mod. Added power.
Subtract 20 whp if coming back from lunch.
EvolvedAK is offline   Reply With Quote
Old 06-05-2013, 04:26 AM   #734
AKGC8
Member#: 1305
2000 Impreza
Any idea if DBA slotted rotors and Hawk HPS pads will give off sparks under braking? I know some of the more metallic race pads will but not sure about HPS.
Had a guy flag me down at a stop light just now saying he saw sparks in my front wheel, like a little sparkler going off in there. I haven't heard any weird sounds and looked everything over and didn't find anything that would cause sparks. Brake pads have plenty of life so no metal on metal. Only thing I can think of is the pads just doing it normally, or under heavier braking. The light was on a 55 mph road and I was expecting the light to change so held my speed a little closer than I would have if I was planning to stop(ie, slightly heavier braking than usual).
AKGC8 is offline   Reply With Quote
Old 06-07-2013, 03:48 PM   #735
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
This thread is really for tuning related questions. To answer quickly I would say it sounds like something is dragging or you may have debris like rocks or other items caught in the dust shields or around the pads. I really doubt HPS pads would do that but its possible. My suggestion would be to take everything apart up front and clean and lubricate where applicable, check for stuck parts.
Seth P3 Import Autowerks 907-355-6655
P3Auto is offline   Reply With Quote
Old 06-07-2013, 03:53 PM   #736
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
If you are making those numbers then I would be happy with that on a stock setup motor.
For a good upgrade we recommend to most of our customers a water/meth injection system to help deal with the poor fuel we have here. With a meth/water setup even running less boost we can actually get more power and torque safer. Many of our customers see about 300whp on our Mustang Dyno with a car like yours and your mods..
Seth
P3 Import Autowerks --- 907.355.6655
Originally Posted by yambeezy23 View Post
I have a 2013 base model hatch and now with the invidia n1 single exit, invidia catless downpipe, and cobb short ram intake.
I was hoping to just barely hit the 300 hp mark but i fell a little short.
im running 288 hp at the wheels now and I can feel the difference =)
What direction should I go now??
Old 06-26-2013, 09:41 PM   #737
exogen
Member#: 355393
03 wrx 4eat
psm
Sorry if this question is quite common but I couldnt find any answers.
Currently I am all stock but in the next few weeks I'll be getting a full exhaust, intake and possibly a bov/dv. Is it bad for me to run this all on a stock motor without a tune?
Will be on a 03 wrx 4eat.
Thanks!
exogen is offline   Reply With Quote
Old 06-26-2013, 10:06 PM   #738
cosseywrx
Member#: 276443
Yes it will be bad. Your maf will be off and your rear o2 sensor will be off if there wont be any cats. You will most likely run your system lean.
Goes kinda like this....
Part then tune
Part then tune
Etc
Etc
Etc!!!
In the end its your car and good luck. Im not a tuner so ya dont gotta believe me!
Old 06-27-2013, 04:00 AM   #739
exogen
Member#: 355393
03 wrx 4eat
psm
OK, Thanks for the info!
Old 06-27-2013, 04:14 AM   #740
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
On an 02/03 you'll be fine with exhaust and an intake. Theyre much more flexible than the 04+
You'll get a slightly noticeable difference in power, throttle response and spool but would gain much more with a tune.
You don't need a bov or upgraded bpv. Spend the money elsewhere, for example towards a tune.
Edit: Some good basic reading material to enjoy
http://forums.nasioc.com/forums/showthread.php?t=533787
Old 06-27-2013, 07:23 AM   #741
exogen
Member#: 355393
03 wrx 4eat
psm
Thanks, guess I'll spend it towards a access port or a custom tune. I'll do some research and see whats best for my needs.
Thanks guys.
Old 06-27-2013, 01:55 PM   #742
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
A custom tune would be about $200 at our shop. Your car will like you more if you tune it. You probably should also look into a 3 port grimmspeed (or whatever) EBCS. The stock boost control solenoids on the older cars are usually pretty shot by now.
Seth.
Thanks guys.
Old 07-01-2013, 10:48 PM   #743
Medic_538
Member#: 304355
Could a tune cause a misfire on a cylinder? I have been having a misfire on the #1. Changed plug's, injectors, coil pack, o2 sensor and cleaned the maf sensor. Compression test 135 across all cyl. Tuned for E85. Thanks
Medic_538 is offline   Reply With Quote
Old 07-02-2013, 12:46 AM   #744
joshcuerdo
Member#: 361156
2010 impreza
dark gray
searched the crap out of this fourm as well as google. bought my gf a 2010 2.5 impreza last year, and it seems i drive it more than she does. seems that ive converted myself lol. anyways, im sick and tired of staring at the stupid plastic hubcabs on my car. im thinking of purchasing some rims from a dealer. they came off a 2009 impreza. they look like this, http://www.finishlinewheels.com/prodimg/ALY68762U.jpg
i honestly like the simplistic look of them. nothing flashy. they're 17 x 7, someone told me there might be some disadvantages of going with a bigger rim. can someone confirm that?
-im about as car savvy as your dead grandmother.
joshcuerdo is offline   Reply With Quote
Old 07-02-2013, 01:52 PM   #745
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
What year, make, model? Its possible that a tune can cause some issues but its unlikely that it would be on the same cyl every time. Can you describe the conditions that cause the miss? (idle, part throttle, WOT) .
Old 07-02-2013, 03:47 PM   #746
Medic_538
Member#: 304355
2007 impreza wrx. It has upgraded turbo and injectors and pump and IC and intake. All work done prior to this issue. It ran fine with all this on so nothing I added caused this. I also had the block rebuilt due to ringland failure. 15k on the motor at this point.
It is under all loads, slight throttle, idle, full throttle. The funny thing is it only does it when the car is warm. If I start it up after sitting for a bit (hours), then it runs good. But once it is up to operating temp..... then it runs with a miss.
Old 07-02-2013, 10:16 PM   #747
bjcarter2
Member#: 227288
2006 MCS JCW
Pepper White
Nice wheels!
Not sure what disadvantages there would be except more expensive tires.
Those wheels will work just fine.
A 17x7 was an option for the Impreza in '09. There may be a difference in offset from your steelies to those but not a whole lot.
Check out www.cars101.com
Old 07-03-2013, 06:15 AM   #748
joshcuerdo
Member#: 361156
2010 impreza
dark gray
Nice wheels!
Thanks a bunch! Is it untrue then that a larger rim size (like the 18's that come on newer subs) and a larger offset can damage your vehicle? The gentleman at my local Subaru dealership said it was a bad idea.
Old 07-07-2013, 11:24 PM   #749
soccerandpingpong
Member#: 326362
2004 Baja Turbo
white
So, I am a beginner to the world of tuning cars. I currently have an '04 baja turbo manual and I am looking for a map to put on my car because i can't make my own obviously. My buddy has a tuner and we are looking to increase my horsepower a little bit. Everything is stock except for a short throw shifter. Any suggestions for a beginner!?
soccerandpingpong is offline   Reply With Quote
Old 07-07-2013, 11:39 PM   #750
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
You should invest in a used unmarried cobb access port then hit up a tuner after. Cobb has off the shelf maps specific for your car so make sure its for a baja if you buy used new is $500ish used is 150 lessish. But its a grest upgrade
T_woot is offline   Reply With Quote
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 16 11-06-2014 02:12 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
