Alaskan Impreza Club
Old 04-13-2010, 02:58 PM   #126
retrac
Member#: 217208
I have a leak tester that I made last week if you need to use it.
retrac is offline   Reply With Quote
Old 04-13-2010, 03:02 PM   #127
Brando5185
Member#: 189926
2006 Jeep GC Limited
It's a HEMI!! Yee-haw
Awesome. Would you mind helping me then? Buddy? Pal?
Brando5185 is offline   Reply With Quote
Old 04-13-2010, 03:06 PM   #128
retrac
Member#: 217208
Got an air compressor to use with it?
Old 04-13-2010, 03:20 PM   #129
Brando5185
Member#: 189926
No compressor... how hard is it to put on and get ready?
Old 04-13-2010, 03:22 PM   #130
retrac
Member#: 217208
Just clamp it on, but you need a pressure source and a bike pump don't cut it volume wise.
Old 04-13-2010, 03:28 PM   #131
06gtleg
Member#: 197928
95 Outback
Green
I have an air compressor but wont be back until friday afternoon
06gtleg is offline   Reply With Quote
Old 04-13-2010, 03:37 PM   #132
AK SloPok
Member#: 56464
12 Ram
I would suggest some basic mandatory parts as well as the basic short block, things like timing belt, upgraded oil pump, water pump, pulleys, KillerBee oil pickup, factory gasket set etc. The majority of time spent on a build is getting all the little parts together.
AK SloPok is offline   Reply With Quote
Old 04-13-2010, 03:49 PM   #133
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
Ok good idea. Most of those parts I can get the next day from my vendor or dealer even as well. We did land on the upgraded oil pump but you mentioned the oil pickup that should also be part of our basic build. Thanks!
P3Auto is offline   Reply With Quote
Old 04-13-2010, 03:51 PM   #134
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
Gas station....Has air pump.
Old 04-13-2010, 03:53 PM   #135
retrac
Member#: 217208
That's what we were lookin at, LOL.
Old 04-13-2010, 04:58 PM   #136
ridestreet84
Member#: 132030
2007 obp STI
95 impreza (rally beater)
i has air compressor brando, wouldnt be able to help thou until thursday
ridestreet84 is offline   Reply With Quote
Old 04-13-2010, 05:11 PM   #137
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
There was a topic retrac and I were pondering a while back and I want to ask.
On a target boost chart, if it is set up so that it's targets are linear throughout a throttle position and you use the boost controller to then vary the boost, is there a benefit to this?
basically 50%+ throttle was set at 19.81 for all rpm ranges and under 50% was set to a different number, the adjustment was then done by the boost controller. I tried this tune, it boosted like a raped ape and seemed to bring lag way down, however we didn't play with it long because for some reason the tune we jacked had some idle issues cause 10:1 afrs at idle and IAM's of 1 or 0 at times (16 bit). So have you ever set a boost chart up like this, and could you make it work like that at all?
greenspeed is offline   Reply With Quote
Old 04-13-2010, 05:20 PM   #138
retrac
Member#: 217208
^^ That was a canned tune from the guy with the same mods. You never tried to adapt similar changes to YOUR tune instead of the canned "base-map" one. Might have worked that way.
Old 04-13-2010, 05:23 PM   #139
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
Part throttle boost tuning is an art. I wrote about this earlier in the thread here.
My question to you is why allow any more than spring pressure at part throttle? Set the targets to stock for part throttle ranges. If your running an after market boost solenoid then drop you WGDC tables about 30% from stocku numbers and start with that.
Some problems with some things you wrote. IAM at 0 or 1 with a 16 bit ECU? 16 bit range for the IAM is 0-16. If you were reading 10:1 at idle and had an IAM of 0 or 1 then you had some serious problems with the map. I'm trying to imagine how you even get a 10:1 at idle without changing front O2 sensor scaling while in closed loop. The car can make up to a 40% total change in fueling during closed loop operation. So I guess you could have forced it out of closed loop, had messed up MAF scaling, injector scaling, or some combination.
Nothing personal but ff your able to make mistakes that large I would avoid tuning your car for now until you ask more questions and get back to the fundamentals.
Old 04-13-2010, 05:26 PM   #140
retrac
Member#: 217208
Originally Posted by P3Auto View Post
So I guess you could have forced it out of closed loop.
That's exactly what was done if I recall correctly, but it idled and ran smoother than it ever had before like that which was weird.
My feelings on the map dropping to IAM 1 was the wicked overdriving of the turbo by requesting those crazy targets down low which are undoubtedly way outside the efficiency range.
Old 04-13-2010, 05:54 PM   #141
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
The idle issues are related to physical issues not tunes in my opinion. Running a car rich at idle will almost always smooth out rough spots.
The IAM dropped because you had high timing in the cells for that part throttle boost region. The turbo actually was spinning less since the thottle was part shut and I assume lower rpms; the only time this doesn't ring true is if the BPV is cracking open, then the turbo would over spin real fast. Blow dryer style!
There is no reason to run high boost at part throttle, but if you choose to you need to log load/rpm/boost/fbkc/iam figure out where the timing is getting pulled and pull it out yourself from the base timing tables first. Then you should review the advance timing tables to check for hot spots. Remember the stock tune was never designed for that kind of boost at part throttle. You will find some seriously advanced timing where your knocking. You will also see some very lean fuel trims perhaps as well.
Keep in mind I am speculating here since I don't know what you guys actually did.
Old 04-13-2010, 05:58 PM   #142
retrac
Member#: 217208
Know the real problem? I was just a junk map with weird stuff going on all over. And of course we know that idle is mechanical on that car, but he's gotta get the kinks worked out.
Old 04-13-2010, 06:07 PM   #143
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
I'm not really sure what your saying. He asked me as a favor to look at the tune quickly last year. The only thing I ever looked at on this car was his boost after he changed the solenoid... At the time he asked for 15psi and thats what he got. Since then I know he has made changes to the maps. I don't claim any responsibility for his tune...lol
Old 04-13-2010, 06:35 PM   #144
retrac
Member#: 217208
Right, the change Rob is talking about was an opensource base map that was applied, not a tweaked version of his existing rom.
Old 04-13-2010, 06:38 PM   #145
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
I see. Well you guys should come over some time and we can go over the tune. What better car to experiment on and learn with then Greeenys!
Old 04-13-2010, 06:48 PM   #146
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
you say that like I care .
as paul said, it was a tune we found with my mods off romraider forum, and I looked at it, was was like, paul lets try it I wanna see what it's like.
Basically it was fun for 2 mins until the IAM's went to 1 on the first pull and the afr's sat around 12.7 at full boost. (personally like a lot richer) .
when I looked at the tune I was hoping for some better boost marks on throttle roll on, along with a bit of lag decrease, each I felt, but the problem was the IAM's and really messed up idle.
Ps, my idle issue is fine, as long as the temp is over 20 degrees, under that is when I have the CEL, plus, my cold idle is a bit strange.
Old 04-13-2010, 07:59 PM   #147
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
In terms of boost, throttle, lag; When you put your foot 100% on the pedal the ECU only reads the pedal position and desired boost(for ur version, not all cars). This being said what you set in the ECU at part throttle will have NO effect since the ECU isn't even looking at the cells during WOT. The time it takes your foot to push the pedal from where ever to the floor is faster than any turbo will ever respond. If you found that you suddenly had better spool times then perhaps there is some thing in the tune beside what your looking at that needs to change to improve those times. My hunch is when you went to 0-1 IAM the severely reduced timing and rich condition aided the spool. I could explain why but we can do that another day.
Old 04-13-2010, 10:34 PM   #148
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Amen brother...
Racer Dubya is offline   Reply With Quote
Old 04-13-2010, 11:17 PM   #149
bjcarter2
Member#: 227288
2008 FSXT
Red
Originally Posted by AKSubieDubie View Post
I have roughly 25k miles now on my acl 0.001 oversize bearings...spinning to 8k rpm & maxxed out 30R =) So far so good with them.
Unsure on wear.. haven't heard any "horrible" noises yet. lol
You should contact Blackstone Labs for an oil analysis kit. Draw a sample on your next oil change to see what the wear is like. It'll cost you about $22.50 plus some postage to send the sample to them. They will email and snail mail the results to you.
bjcarter2 is offline   Reply With Quote
Old 04-13-2010, 11:20 PM   #150
bjcarter2
Member#: 227288
2008 FSXT
Red
We are going to stock one or two built engine setups at the shop this year but I wanted to get an idea of what people think are good setups.
Have you thought about a "Core Exchange" program to go along with it? It could help keep costs down too.
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 10 10-28-2009 01:10 AM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
Message Board Statistics All times are GMT -4. The time now is 11:13 PM.
