Alaskan Impreza Club
Old 04-15-2010, 05:38 PM   #176
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Haha better hurry I'm already looking at two built motor jobs this month and next.
Just be careful, Once you step over the 350+ line on your motor it only takes a little blip to knock out a ring landing. The water injection if used as a safety net helps a lot though.
All good times!
P3Auto is offline   Reply With Quote
Old 04-15-2010, 05:40 PM   #177
Brando5185
Member#: 189926
2006 GC 5.7L
It will be an assembled short block right? So I buy it and drop it in and put all my stuff on it?
Or is it just a short block kit that comes with the parts and we have to assemble?
Brando5185 is offline   Reply With Quote
Old 04-15-2010, 05:42 PM   #178
Brando5185
Member#: 189926
2006 GC 5.7L
Def gonna have water/meth injection if I am going above 350 whp. Won't deploy till closer to end of this year.
Old 04-15-2010, 05:48 PM   #179
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
It will depend on your choice of pistons and additional mods.
The short block comes fully built with all factory STI internals. The idea is if you want to upgrade say the pickup tube, oil pump, and pistons then this is a fairly simple deal. Depending on the piston choice there are some basic drop in choices and require only a bore check for spec and if out of spec some light machining. Valley machines has the same equipment ADB does but at a fraction of the cost(another saver).
Remember were talking about a block that takes care of the normal weak points over stock, there is a price to pay for cheap though. This engine won't be spinning 9500rpm and make 600WHP+, it will however be very strong and reliable as a 400WHP daily driver with the right supporting mods.
Old 04-15-2010, 06:36 PM   #180
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
Any further discussion can be done in the vendor forum or this thread
Kiwi Fella is offline   Reply With Quote
Old 04-16-2010, 02:15 PM   #181
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Thanks Kiwi.
Old 04-16-2010, 02:26 PM   #182
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
Let me know if you want to change the title
Old 04-18-2010, 08:57 PM   #183
DCrider44
Member#: 244413
2003 Impreza 2.5 Rs
Question for anyone that has their Subaru chipped. I drive an 03' impreza Rs. I'm looking for a performance chip, but am not sure on any reliable makes or models. Any recommendations?
DCrider44 is offline   Reply With Quote
Old 04-19-2010, 02:59 PM   #184
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
^^you have a lot of searching to do about our ecus^^
Alaskan EJ20 is offline   Reply With Quote
Old 04-19-2010, 03:22 PM   #185
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
I have not personally chipped an RS of that year. Depending on what your trying to do mods wise there are different options. The most a chip with no mods will do for you is maybe pickup a few HP. Take a look at your basic power adds like headers, exhaust, intake, etc first. I know the 2005 2.5rs can be reflashed and tuned via laptop but I don't think any prior years can be. More research required here.
Old 04-19-2010, 04:09 PM   #186
AKSTIDAD
Member#: 205902
2008 sti - all year
08 CBR1000RR-summer- Sold
So it it normal,
that i never see my MAF volt higher then 4.6v?
Also i noticed my A/F ratio at WOT is always at 11.0 but idles at 14.6.
I have noticed that my MAF grams have hit 302, but normaly is around 290 ish..
AKSTIDAD is offline   Reply With Quote
Old 04-19-2010, 04:39 PM   #187
Brando5185
Member#: 189926
2006 GC 5.7L
Originally Posted by AKSTIDAD View Post
So it it normal,
From what I have heard. 14.7 AFR is stioch and is right for idle. You want richer at WOT. Mine is tuned for 10.5-11 at WOT to be on the safe side.
Old 04-19-2010, 05:20 PM   #188
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
So it it normal,
Sounds ok to me 11:1 is about the best you can get on our gas and still run decent boost and timing. More power can be had taking it up to 11.8 or so but you would have to run a fuel additive or water injection to really benefit. A neat trick is you can estimate the WHP based on the "G/s" air flow measured on the WRX/STI. So your car is doing approx 290WHP.
Old 04-19-2010, 05:22 PM   #189
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Oh..You should see 14.7 during cruise and idle. That is what the ECU is tuned to do by default.
Old 04-19-2010, 05:31 PM   #190
AKSTIDAD
Member#: 205902
2008 sti - all year
Seth, can you check your pm's
Old 04-21-2010, 02:13 PM   #191
mtondi91
Member#: 232856
2006 WRX
CGM
I am going to be buying a downpipe and cobb AP2 to go stage 2 pretty soon. in the long run i am thinking of a blouch 18G but not anytime soon cuz of money. Will i need injectors for stage 2? if not will it help if i put them in before i get the car protuned? also what size would be good for an 06 wrx? 750cc?
mtondi91 is offline   Reply With Quote
Old 04-21-2010, 02:18 PM   #192
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
You do not specifically need injectors for a Cobb stage 2 however the stock ones will be basically running at max. 750CC would be more than enough for an 18G even at high boost. If your going to get protuned you could save a lot by skipping the AP2 unless you need to switch maps all the time on the fly.
Old 04-21-2010, 03:59 PM   #193
mtondi91
Member#: 232856
2006 WRX
CGM
im going stage 2 over the summer but im going to have to save up money to get the bigger turbo. i will probably get it protuned after i go stage 2 so i wont need injectors for that? and then when i get the bigger turbo i should get 650 or 750cc injectors and then get it tuned again probably. i guess what im asking is what kind of supporting mods would help with stage 2 before i get it protuned the first time and also be good for when i get the bigger turbo later on?
Old 04-21-2010, 04:15 PM   #194
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
One step colder plugs, a better fuel pump and a lighter front pulley come immediately to mind. A set of gauges (to see what is going on in there). I did all of this folowing the same pathway you have outlined for yourself.
Nomadgene is offline   Reply With Quote
Old 04-21-2010, 04:26 PM   #195
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Each part and its specs will depend on exactly what others parts are installed and what your goals are. The size of the injectors is based on how big of a turbo and more important how much air will you be moving, what is your goal WHP, etc. 750cc are good and at that size your fine well above 400WHP although your stock internals engine is not. 750cc will still idle ok as well.
Old 04-21-2010, 04:27 PM   #196
mtondi91
Member#: 232856
2006 WRX
CGM
right now i have a catback exhaust, cobb intake and i do have gauges. Lighter front pulley and fuel pump before injectors? I just dont wanna go stage 2 and get it tuned and then when i go to buy a bigger turbo down the road have to get a bunch of supporting mods that i could have put on the stage 2 and help my car be as good as it can at stage 2 because id rather drop 400 on injectors and it help stage 2 and it also be good for the bigger turbo down the road. Basically i want to do everything i can with the stage 2 on the stock turbo cuz its gonna be a while until i can get a bigger turbo and i want to be pushin as much hp as i can until then.
Old 04-21-2010, 04:30 PM   #197
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Your tuner will have to tell you if your injectors need to be replaced or you could log fuel injector duty cycle... There are no direct power gains with bigger injectors. Again a Cobb stage 2 off the shelf tune does not call for them.
Old 04-21-2010, 04:41 PM   #198
mtondi91
Member#: 232856
2006 WRX
CGM
okay so i will wait to determine whether or not i need injectors when i get it tuned. Should i get the lightweight front pulley when i go stage 2? im assuming injectors and fuel pump will be good when i get the bigger turbo. Will an sti tmic be sufficient for a blouch 18g or 20g? I dont want to have to get a fmic, cut my bumper, and have more turbo lag. To your question about my whp goal, Id like to get to about 300.
Old 04-21-2010, 04:53 PM   #199
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
STI TMICSTI Stock turbo (VF39) or 18g (smaller version)
650CC injectors
Walboro fuel pump
Pro-Tune
^^ This will do 300WHP on your wrx.
Old 04-21-2010, 05:09 PM   #200
mtondi91
Member#: 232856
2006 WRX
CGM
alright thanks so much man. you have an opinion on vf39 or blouch 18g? which would you recommend?
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 16 11-06-2014 02:12 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
