Closed Thread
Old 03-23-2010, 08:09 PM   #1
EJispro
Member#: 205341
Default 06 wrx tr FP HTA68 317 hp 316 tq
Recently did some work to my subie parts added:
Biggest top mount I could find
FP HTA 68
DW 750 cc injectors
New fuel pump
Fujita F5 intake
Equal length headers
Catless HKS Turbo back
EJispro is offline
Old 03-23-2010, 08:18 PM   #2
HSBabyFace
Member#: 130204
14 JKUR
I would have expected to see more power with that setup...
HSBabyFace is offline
Old 03-23-2010, 08:28 PM   #3
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
where's the rest of the dyno sheet? peak numbers dont mean shiat, we want to see the curve as well...
wrxtremeWGN is offline
Old 03-23-2010, 08:34 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Please copy and paste the format from the following quote, and send it to me via PM with your details. Normally I would leave the thread open, but this thread doesn't have anywhere NEAR enough info to simply 'fix.'
In the future, please read the Stickies before posting.
Originally Posted by Scooby921 View Post
Due to the incredible number of variables that exist in the world it is very difficult to compare one tune to the next or one 1/4 mile sprint to another. In an attempt to make the threads a little easier to sort through and a little easier for others to read and compare we have decided to implement a specific format for creating new threads in PPB. If you are going to create a new thread regarding your new dyno tune or your latest trip to the drag strip you MUST use this format. Failure to do so will result in your thread being deleted. Failure to list or include the required information will result in your thread being locked and the 1st post edited such that people know immediately that there is missing information and you're results may not be valid for review and comparison. This applies to all threads created after 6-October-2009.
We apologize for being so strict about this, but its evident we need some type of regulations around here to increase the utility of posts and cut down on the amount of potentially false and useless information. We are also hoping to reduce the amount of bickering, arguing, and flaming that occurs. This is supposed to be a cool place where people can be proud of what their car has done and pass on useful information regarding builds and results. Please don't post false info just to make your e-dick feel bigger. Its cool to see big numbers and great performance, but its still the internet and no one is any more significant than the next n00b to piss off Uncle Scotty by asking about a BOV.
This is the new required format. Thead title and 1st post of your new thread must contain the following information as it applies. Copy and paste into your new thread and fill out as noted.
Thread Title: Must contain engine displacement and turbo type (intent is to make it easy for others to search for setups they are interested in). You can include other info in the title if you choose. Just include those couple items to help others search and find your thread.
examples:
Dyno Tune: 2.5L + Blouch Dominator 2.0 makes XXXwhp
or
Dyno Tune: (insert shop name here) makes 450whp on a 2.5L + FP Red @ 25psi
or
Quarter Mile: 2.5L + GT35r goes XX.Xsec @ XXXmph
1st Post: Your 1st post must contain the following items. If you are a vendor posting a customer car and do not know the full extent of modifications please make note of that. If anyone doesn't have the ability to measure the temperature, can't look up city elevation on the internet, or doesn't remember the weather that particular day please list it as "unknown".
Event: dyno pull / quarter mile
Location: shop name for dyno pull / track name for quarter mile...include city and state
Ambient Temp: in degrees Fahrenheit
Elevation: feet above sea level
Weather: sunny, cloudy, wet, dry, hot, cold, etc...
Track and Conditions: concrete or asphalt, clean or dusty, flat or running slightly up or downhill (for 1/4 mile only)
Tires: brand, model, size
Car: year, model
Tuner: name of person who tuned the car (add shop name and location if posting 1/4 mile time)
Dyno Info: brand
Peak HP at RPM: note whether or not it is SAE corrected
Peak Torque at RPM: note whether or not it is SAE corrected
Baseline hp/tq for a stock on same dyno: list numbers and note whether its WRX or STi and 2.0L or 2.5L
Target Boost: preferably in psi
Target AFR:
Fuel: not just pump gas or race gas...list octane rating and leaded or unleaded
Engine/Power Modifications: internal, external, or electronic components that directly affect power made by the engine
Driveline Modifications: transmission/gearing changes, final drive/differential changes, driveshaft changes, clutch, flywheel, etc.
Suspension Modifications: struts, springs, coilovers, braces, bushings, and other items that reduce body motion and increase power transfer to the ground
Other Modifications: weight removal, addition of a roll cage, lighter wheels or rotors, smaller than OE diameter tires, and other items that affect vehicle weight, rotational inertia, and power delivered to the contact patch
-If posting a 1/4 time you MUST post a copy of the time slip. Slips containing the facility name and date are great. If you can find a track that also lists car make and model its certainly a bonus for you.
-If posting a dyno pull/tune you MUST post a copy of the hp/tq curves. If possible it would be nice to have your new pulls shown vs. a stock WRX or STi on the same dyno so the difference/change is easy to visualize.
-Inclusion of video is not required, but we are sure it would be appreciated for many of the 1/4 mile posts.
*If you feel we have missed an important item regarding dyno tunes and quarter miles, or feel we are asking too much please PM MPREZYA, Kevin Thomas, Leonardo, Scooby921, or Audiosavvy regarding the issue and we will review as necessary.
Audiosavvy is offline
Closed Thread
Bought my 06 WRX TR today! balls2dawalls Newbies & FAQs 18 06-08-2010 10:57 PM
06 TR FP HTA68 Dyno EJispro Proven Power Bragging 2 03-24-2010 01:52 AM
06 WRX TR VF-43 -- Agile Tuned -- 311 HP / 354 TQ brain juice Proven Power Bragging 22 10-28-2008 09:36 AM
05 WRX 291 hp / 316 tq snwman Proven Power Bragging 4 03-22-2008 06:47 PM
FP Green on an 06 WRX/TR Boost_Junkie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 02-12-2006 01:12 PM
