Old 03-23-2010, 07:48 PM   #1
red civic standard
Member#: 180624
Default Will a 2003 Forester 2.5 be a direct swap into 2002 Impreza Outback Sport
I just recently bought a 2002 Impreza Outback Sport (with the stock 2.5 SOHC) that had a broken timing belt. The heads have bent valves so I was going to get both heads redone, new headgaskets, timing belt, etc.
For about the same cost I can get a used motor out of a 2003 Forester. It is the 2.5 SOHC NA motor.
Can I directly swap this into my '02. I want to retain the stock '02 ecu and wiring. Do I have to use the manifolds from my stock '02 motor?
Thanks.
red civic standard is offline   Reply With Quote
baja front seats into 97 impreza outback sport? oooo Interior & Exterior Modification 0 05-06-2009 01:27 AM
jdm swap into an impreza outback sport pauljds Subaru Conversions 0 10-23-2004 11:23 PM
swapping a jdm engine into an impreza outback sport pauljds Newbies & FAQs 2 10-23-2004 09:28 PM
93 EJ22T direct swap into 93' impreza? ^jynx^ Subaru Conversions 2 10-27-2003 10:35 PM
can i use 1999-1998 impreza RS parts on my 2002 impreza outback sport DXY! Normally Aspirated Powertrain 3 11-16-2001 03:13 PM
